Newton's First Law to explain Washing Machine Spin Cycle
23 replies · 5K views
thomas_shvekher
Use inertia and Newton’s first law to explain how the spin cycle in a washing machine removes
water from clothes.
Newton's First Law
I truly am not sure. I assume it is that because everything has inertia, an a tendency to remain in a constant state of motion, when the clothes are quickly spun around they cannot remain in a constant state of motion (of either rest or constant velocity), but the water is "pushed"/spun out of the clothing "with the goal of being in an equilibrium", although I do not think this is correct.
A body remains at rest, or in motion at a constant speed in a straight line, unless acted upon by a force.
Could this mean that water is not acted upon by an external force, meaning it travels our of the clothing in a straight line (into the holes of the washer), while the clothing ocntinues to spin aound as an external force acts upon them?
The question is why don't your clothes leave the washing machine and why you don't end up with a drum full of water?
So the idea behind the question is that Newton's First Law states that the wet clothing will try to move in a straight line, and the holes on the drum will allow the water to espace, but not the clothes?
kuruman said:
It seems that wet dogs understand how this works. What do you see the water do?
It looks like the water "flies" off in a straight line
The spinning drum physically forces the clothes to deviate from the natural straight line that they would follow, according to the Newton's enunciate.
That drum can induce a centripetal acceleration to the solids, but the liquid would scape that effect.
The perforated walls of the drum are unable to "grab and drag" the water into a circular movement.
Thank you so much!
And if you put a put a soaked jacket on the dog, the water would still fly off, no?
And if you put the soaked jacket in a washing machine's spin cycle instead of on the dog, then ##~\dots##
Lnewqban said:
How was this picture made and what is it of? It seems to me that the likeness of a single leaking bucket was cut and pasted in a symmetric pattern with an arrow added to suggest clockwise rotation. If that is the case, I think that the stuff coming out should be following not leading the bucket.
The drawing is confusing. I think it is intended to depict the forward progress of a particular bit of each of the four water sprays over a time lapse. However, the buckets from which those four sprays emerged are depicted as a frozen snap shot from the time that the bit was sprayed.
A more faithful depiction of that concept might have used a single droplet at the bottom of each bucket and dotted lines (perhaps decorated with series of equally spaced dotted droplets) depicting the future paths of each of those four droplets.
Each of the sprays would properly have been a straight line leading trajectory nearly tangent to the circle of buckets if depicted in this manner. It would not have the curve that is improperly shown in the drawing from #12. The departure from an exact tangent would be due to a non-negligible exit velocity from the spout at the bottom of each bucket.A set of four concentric trailing spiral curves broken into water droplets due to Plateau-Rayleigh instability would be characteristic of an actual photograph.
Here is a slow-motion demo.
So interesting!
It is just a picture that Google found for me.
Thank you for the correction, the rotation arrow has the wrong direction.
I will try to fix it later.
Did Google say what this is supposed to depict? I am curious.
Lnewqban said:
Revised picture regarding rotation direction:
Now we have the question: What do those arrows at the outer ends of the spray streams denote?
What they do not correctly denote is the flow direction.
Agree.
What about revision 2?
Lnewqban said:
Agree.
Plausible. A droplet's direction should be a combination of radial (from the ejection velocity) and tangential (from the bucket velocity at the time of ejection).
