Newton's laws -- Block sliding on a Prism
12 replies · 5K views · last reply
Prathamesh
All the surfaces shown in fig. are assumed to be frictionless. The block of mass m slides on the prism of mass M which in turn slides backwards on horizontal surface with acceleration of ao. Find the acceleration of smaller block with respect to prism.
Physics textbook figure 5-W14: a wedge-shaped prism of mass M with angle θ on a horizontal surface, a block of mass m on its incline, and an arrow pointing left showing the prism's backward acceleration.
As we are working from the frame of reference of prism which is non inertial
we have to include a pseudo force in opp. direction of acc of prism.
Now , forces on the block are
1)mg downwards
2)Normal force N
3)pseudo force (mao)
When I resolved these forces using force body diagram , it gave me 2 equations
maocosθ+mgsinθ=ma
i.e aocosθ+gsinθ=a
and
N+maosinθ=mgcosθ
I m stuck here...
How to eliminate N and ao ??
Please help
Ans is
(M+m)gsinθ / M + msin2θ
Prathamesh said:
I m stuck here...
Please help
Ans is
how the prism M moves Ma0 = some force, think about it
i feel a component of N must be responsible for its motion.
Prathamesh said:
Is it Nsinθ??
please draw a free body diagram
i think you are correct - M.acceleration of the prism=Nsin (theta)
I am not sure, but here's my two cents:
The angle between the line of acceleration of the prism and the line of acceleration of the block is equal to 90+theta degrees. Use vectors to work out the acceleration of the block with respect to the prism.
so it can be written
-M* a (0) = N sin ( theta)
No, M*a0=Nsin(theta).
The block and the prism interact with the normal force of magnitude N. See picture. If ##\vec N## is the normal force acting on the block, then it is ##-\vec N## acting on the prism.
The normal force exerted on the prism has a backward component, accelerating the prism horizontally, to the left. @Prathamesh was right.
  • Free-body diagram of a block of mass m sliding down a wedge-shaped prism inclined at angle theta on a horizontal surface; red arrow shows normal force N on the block perpendicular to the incline, blue arrow shows the opposite normal force N on the prism, and an arrow labelled a0 points left along the prism.
Prathamesh said:
maocosθ+mgsinθ=ma
i.e aocosθ+gsinθ=a
and
N+maosinθ=mgcosθ
if a0 is taken as +ve directed on the right side , then naturally
-Ma0 can be seen as vector going to the left.
The force causing this acceleration of the block is -N. -Mao=-Nsin(theta), and you can eliminate the minuses.
Try to do without pseudo forces, which will enhance your understanding further.
1)mg downwards
2)Normal force N
maocosθ+mgsinθ=ma
i.e aocosθ+gsinθ=a
and
N+maosinθ=mgcosθ
I m stuck here...
Please help
Ans is
You missed the parentheses from the answer. Correctly it is (M+m)gsinθ / ( M + msin2θ)
Together with the equation for the block,
Mao=Nsin(θ)
you have three equations with three unknowns. Just go ahead.
The problem wants the acceleration of the block with respect to the prism. The OP's method is correct and the solution is easy that way.
