"No tally, no plot" error MCNP6
In summary: For the relative uncertainty, you can use the following formula:relative uncertainty = (error/fluence) * 100%In summary, the conversation is about using the TMESH tally to calculate the flux of a 1 MeV point source through a spherical MESH a distance of 1cm away from the origin and covering all polar and azimuthal angles. The user is having trouble plotting the results and is seeking help from experienced users. They are also discussing the use of the PRDMP and MCTAL cards to print and analyze the tally data. They also discuss ways to calculate the relative uncertainty of the data.
khary23
93
I am using the TMESH tally to try and get the flux of a 1 MeV point source through a spherical MESH a distance of 1cm away from the origin and covering all polar and azimuthal angles. When I try to plot using the RUNTPE function I get the error "no tally no plot". I also do not see tally results in the MDATA file. I am teaching myself MCNP6 and find the manual to quite difficult as it seems to presuppose knowledge of older versions of MCNP. I would appreciate it if someone could look at my output file that has the tally cards and help me figure out what I am doing wrong.
  • F4testout.txt
Hi,
in cora, corb, corc you must put the number of step.
For example :
TMESH
SMESH1:p
CORA1 0 10i 1
CORB1 0.01 10i 180
CORC1 0.01 10i 360
ENDMD
note that you have a cukkie cutter.
Put
120 0 2 IMP:P=0 $Graveyard
instead of 120 0 -12 2 IMP:P=0 $Graveyard
it gives Something like that (with vised)
242841
Likes khary23
Thank you for the response and help! Wjats do you mean by cookie cutter?
a cookie cutter is a geometry error :
Each region must be uniquely defined. If not it gives a cookie cutter
Likes khary23
Ahh that makes sense. What software are you using to visualize?
I used vised or xming
Likes khary23
Thanks!
I have changed the deck with your suggestions and I am still getting the no tally no plot error. The mdata file does contain information so I don't know why its not plotting. Using Xming.
  • F4test.txt
When you are in xming I suppose you are in "MCPLOT"
if yes, type "PLOT" and try again.
Another suggestion, instead of "CORA1 0 10i 10" try with "CORA1 0 10i 1" because the radius of your sphere is 1 cm not 10 cm.
Tried what you advised and still nothing. I attached a screen shot of what the plot window shows
I will try to write a tutorial
Likes khary23
Oh wow Thank you!
One more question. How does one get the tally data from the TMESH in a way that is similar to the output of a normal F4/F6.. tally. What I need is flux in each mesh bin for example what is the flux at each cm from 0.5 to 10 cm or the angular flux in 1 degree increments.
Try with this tuto
  • meshonxming.pdf
Likes khary23
Awesome thank you so much! So is there a way to get the angular bin data in a table form?
yes, you can use "Gridconv" for that
I used it, but the output is not in a form that makes sense. No descriptors or labels on the data just unformatted numbers.
Yes ! Mesh tally files are not well documented
To understand the file it is necessary to work in 1D (and not in 3D)
For that you can put in your MCNP file :
SMESH1:p
CORA1 0 100i 1
CORB1 .0001
CORC1 .0001
ENDMD
In this MESH tally you will have 100 intervals for the radius and only one in phi and theta.
with "gridconv" the ASCII file is essak.txt
the file essakcomment.txt is commented.
It gives :
2,44E+03
9,90E-03
3,48E+02
1,98E-02
1,28E+02
2,97E-02
6,58E+01
3,96E-02
3,99E+01
4,95E-02
2,68E+01
5,94E-02
1,92E+01
6,93E-02
1,44E+01
7,92E-02
1,12E+01
8,91E-02
8,99E+00
9,90E-02
7,36E+00
0,108911
6,13E+00
0,118812
5,19E+00
0,128713
4,45E+00
0,138614
3,86E+00
0,148515
3,38E+00
0,158416
2,98E+00
0,168317
2,65E+00
0,178218
2,37E+00
0,188119
2,13E+00
0,19802
1,93E+00
0,207921
1,76E+00
0,217822
1,60E+00
0,227723
1,47E+00
0,237624
1,35E+00
0,247525
1,25E+00
0,257426
1,16E+00
0,267327
1,07E+00
0,277228
9,99E-01
0,287129
9,33E-01
0,29703
8,73E-01
0,306931
8,18E-01
0,316832
7,69E-01
0,326733
7,23E-01
0,336634
6,82E-01
0,346535
6,44E-01
0,356436
6,09E-01
0,366337
5,77E-01
0,376238
5,48E-01
0,386139
5,20E-01
0,39604
4,95E-01
0,405941
4,71E-01
0,415842
4,49E-01
0,425743
4,29E-01
0,435644
4,10E-01
0,445545
3,92E-01
0,455446
3,75E-01
0,465347
3,60E-01
0,475248
3,45E-01
0,485149
3,31E-01
0,49505
3,18E-01
0,50495
3,06E-01
0,514851
2,95E-01
0,524752
2,84E-01
0,534653
2,73E-01
0,544554
2,64E-01
0,554455
2,54E-01
0,564356
2,46E-01
0,574257
2,37E-01
0,584158
2,29E-01
0,594059
2,22E-01
0,60396
2,15E-01
0,613861
2,08E-01
0,623762
2,01E-01
0,633663
1,95E-01
0,643564
1,89E-01
0,653465
1,84E-01
0,663366
1,78E-01
0,673267
1,73E-01
0,683168
1,68E-01
0,693069
1,63E-01
0,70297
1,59E-01
0,712871
1,54E-01
0,722772
1,50E-01
0,732673
1,46E-01
0,742574
1,42E-01
0,752475
1,39E-01
0,762376
1,35E-01
0,772277
1,32E-01
0,782178
1,28E-01
0,792079
1,25E-01
0,80198
1,22E-01
0,811881
1,19E-01
0,821782
1,16E-01
0,831683
1,14E-01
0,841584
1,11E-01
0,851485
1,08E-01
0,861386
1,06E-01
0,871287
1,04E-01
0,881188
1,01E-01
0,891089
9,91E-02
0,90099
9,70E-02
0,910891
9,49E-02
0,920792
9,29E-02
0,930693
9,09E-02
0,940594
8,90E-02
0,950495
8,72E-02
0,960396
8,54E-02
0,970297
8,37E-02
0,980198
8,20E-02
0,990099
8,04E-02
  • essak.txt
  • essakcomment.txt
Likes khary23
Wow this was incredibly helpful! I gave it a try for a grid with radii of 1cm and 5cm and polar angles running from 10-180* . If my understanding is correct after the list of angles there is the flux associated with that grid and after that the error ?
  • mdatg.txt
Yes first you have the fluence value and after the error.
You have the value for the radius between 1 to 5 cm every 10 °
Likes khary23
Thank you for the clarification.
I am also trynig to print a MTCAL file using the PRDMP card and wanted to ask if this looks correct. The syntax I am using is
PRDMP NDP NDM MCT NDMP DMMP
PRDMP 100000 -1 1 100000 0
Where NDP= 100000 is to print tallies after 100000 histories
NDM = -1 dump after every minute
MCT = 1 create MCTAL file
NDMP = 100 keep a hundred data dumps
DMMP = 100000 write fluctuations for every 100000 histories
Sorry I'm not an user of MCTAL or PRDMP. I cannot help you !
SMESH1:p
CORA1 0 100i 1
CORB1 .0001
CORC1 .0001
ENDMD
It gives :
2,44E+03
9,90E-03
3,48E+02
1,98E-02
1,28E+02
2,97E-02
6,58E+01
3,96E-02
3,99E+01
4,95E-02
2,68E+01
5,94E-02
1,92E+01
6,93E-02
1,44E+01
7,92E-02
1,12E+01
8,91E-02
8,99E+00
9,90E-02
7,36E+00
0,108911
6,13E+00
0,118812
5,19E+00
0,128713
4,45E+00
0,138614
3,86E+00
0,148515
3,38E+00
0,158416
2,98E+00
0,168317
2,65E+00
0,178218
2,37E+00
0,188119
2,13E+00
0,19802
1,93E+00
0,207921
1,76E+00
0,217822
1,60E+00
0,227723
1,47E+00
0,237624
1,35E+00
0,247525
1,25E+00
0,257426
1,16E+00
0,267327
1,07E+00
0,277228
9,99E-01
0,287129
9,33E-01
0,29703
8,73E-01
0,306931
8,18E-01
0,316832
7,69E-01
0,326733
7,23E-01
0,336634
6,82E-01
0,346535
6,44E-01
0,356436
6,09E-01
0,366337
5,77E-01
0,376238
5,48E-01
0,386139
5,20E-01
0,39604
4,95E-01
0,405941
4,71E-01
0,415842
4,49E-01
0,425743
4,29E-01
0,435644
4,10E-01
0,445545
3,92E-01
0,455446
3,75E-01
0,465347
3,60E-01
0,475248
3,45E-01
0,485149
3,31E-01
0,49505
3,18E-01
0,50495
3,06E-01
0,514851
2,95E-01
0,524752
2,84E-01
0,534653
2,73E-01
0,544554
2,64E-01
0,554455
2,54E-01
0,564356
2,46E-01
0,574257
2,37E-01
0,584158
2,29E-01
0,594059
2,22E-01
0,60396
2,15E-01
0,613861
2,08E-01
0,623762
2,01E-01
0,633663
1,95E-01
0,643564
1,89E-01
0,653465
1,84E-01
0,663366
1,78E-01
0,673267
1,73E-01
0,683168
1,68E-01
0,693069
1,63E-01
0,70297
1,59E-01
0,712871
1,54E-01
0,722772
1,50E-01
0,732673
1,46E-01
0,742574
1,42E-01
0,752475
1,39E-01
0,762376
1,35E-01
0,772277
1,32E-01
0,782178
1,28E-01
0,792079
1,25E-01
0,80198
1,22E-01
0,811881
1,19E-01
0,821782
1,16E-01
0,831683
1,14E-01
0,841584
1,11E-01
0,851485
1,08E-01
0,861386
1,06E-01
0,871287
1,04E-01
0,881188
1,01E-01
0,891089
9,91E-02
0,90099
9,70E-02
0,910891
9,49E-02
0,920792
9,29E-02
0,930693
9,09E-02
0,940594
8,90E-02
0,950495
8,72E-02
0,960396
8,54E-02
0,970297
8,37E-02
0,980198
8,20E-02
0,990099
8,04E-02
Is the end of the tally output the error or uncertainty?
it is the error
Is there way to get the relitive uncertainty?
1. What does the "No tally, no plot" error in MCNP6 mean?
The "No tally, no plot" error in MCNP6 means that the user has attempted to plot a graph without specifying any tally data. Tally data is necessary to create a plot in MCNP6, so this error indicates that the user has not set up any tallies for the simulation.
2. How can I fix the "No tally, no plot" error in MCNP6?
To fix the "No tally, no plot" error in MCNP6, the user must first set up tallies for the simulation. This can be done by adding tally cards to the input file, specifying the desired tally type and location. Once the tallies have been set up, the user can then plot the desired graph without encountering the error.
3. Can the "No tally, no plot" error in MCNP6 be caused by other factors?
Yes, the "No tally, no plot" error in MCNP6 can also be caused by specifying an incorrect tally number or by not specifying a tally number at all. It can also occur if the tally data is not available in the output file due to an error in the simulation.
4. Is there a way to prevent the "No tally, no plot" error in MCNP6?
Yes, the "No tally, no plot" error in MCNP6 can be prevented by carefully setting up tallies for the simulation and ensuring that the tally number is correctly specified when plotting a graph. It is also important to check the output file for any errors that may prevent the tally data from being available.
5. Are there any resources available to help with troubleshooting the "No tally, no plot" error in MCNP6?
Yes, there are several resources available to help with troubleshooting the "No tally, no plot" error in MCNP6. The MCNP6 user manual provides detailed instructions on how to set up tallies and plot graphs, and there are also online forums and user groups where experienced users can offer assistance and advice.
  • Nuclear Engineering
