Noetherian Modules - Bland, Example 3, Section 4.2 ....
This discussion focuses on Example 3 from Section 4.2 of Paul E. Bland's book "Rings and Their Modules," specifically addressing Noetherian and Artinian modules. Participants seek clarification on the nature of the sets ##V_1##, ##V_2##, and ##V_3##, and the relationships between them, particularly that ##V_n \subset V_{n+1}##. The conversation also critiques the author's notation for indexing basis elements, suggesting that a simpler notation would enhance readability and comprehension.
  • Understanding of Noetherian and Artinian modules
  • Familiarity with direct sums in module theory
  • Knowledge of basis sets and indexing in algebra
  • Proficiency in LaTeX for mathematical notation
  • Study the properties of Noetherian modules in detail
  • Explore the concept of internal direct sums in module theory
  • Learn about basis sets and their indexing in algebraic structures
  • Review LaTeX best practices for mathematical writing
Mathematicians, algebraists, and students studying module theory, particularly those interested in Noetherian and Artinian modules and their applications in abstract algebra.
Math Amateur
MHB
I am reading Paul E. Bland's book "Rings and Their Modules" ...
Currently I am focused on Section 4.2 Noetherian and Artinian Modules ... ...
I need some help in order to fully understand Example 3, Section 4.2 ...
Example 3, Section 4.2 reads as follows:
My questions are as follows:Question 1
Can someone please explain/illustrate the nature of ##V_1## ... ?
Question 2
Can someone please demonstrate exactly how ##V_1 \subseteq V_2 \subseteq V_3 \subseteq## ...
Help will be appreciated ...
Peter
$$V_1\triangleq x_{\alpha_1}D\triangleq \{x_{\alpha_1}d\ :\ d\in D\}$$
and recall that ##x_{\alpha_1}## is the first element of the set ##\Gamma## and 'scalar' multiplication of module elements by division-ring elements occurs on the right.
The direct sum referred to is an internal direct sum.
For ##n\geq 1## we have:
$$V_n \triangleq \bigoplus_{k=1}^n x_{\alpha_k} D
\triangleq \left\{\sum_{k=1}^n x_{\alpha_k}d_k\ :\ \forall k\ (d_k\in D)\right\}$$
To see that ##V_{n}\subset V_{n+1}## observe that ##V_n## is just the set of elements of ##V_{n+1}## with ##d_{n+1}=0_D##.
I can't help adding that it strikes me as unfortunate that the author uses this (in my opinion) ugly method of double-indexing the elements of ##\Gamma##, as ##x_{\alpha_i}##. It is much cleaner and less confusing to make ##\Delta## the basis, rather than an index set for a basis, and just write ##x## for an arbitrary element of the basis, and ##x_i## for an element of the countable subset ##\Gamma## of the basis set. With the double-indexing it is harder to read, harder to conceptualise and it takes longer to write the latex code.
and recall that ##x_{\alpha_1}## is the first element of the basis and 'scalar' multiplication of module elements by division-ring elements occurs on the right.
I can't help adding that it strikes me as unfortunate that the author uses this (in my opinion) ugly method of double-indexing his basis, as ##x_{\alpha_i}##. It is much cleaner and less confusing to just write ##x_i## if the index set ##\Delta## is known to be countable, and ##x_\alpha## with ##\alpha \in\Delta## where ##\Delta## is not known to be necessarily countable. With the double-indexing it is harder to read, harder to conceptualise and it takes longer to write the latex code.
Thanks for the help and guidance Andrew ...
But ... just a clarification ...
You write:
" ... ... ##x_{\alpha_1}## is the first element of the basis ... ... "
But the basis is ##\{ x_\alpha \}_\Delta## not ##\{ x_\alpha \}_\Gamma## ... ##\alpha_1## is the first element of the index set ##\Gamma## ...
Isn't it possible that ##\Delta## is an uncountably infinite set with no first element ... but ... not sure what this would mean for the basis ...
Can you clarify ...?
Peter
Yes, sorry, I should have written "first element of the set ##\Gamma##", which is prescribed as a countable, indexed subset of ##\Delta##. I'll go back and correct my post.
Thanks Andrew ...
Peter
