Noise Whiteness hypothesis in Kalman filtering
The discussion revolves around the role of the whiteness hypothesis in the mathematical treatment of the Kalman filter. Participants explore the implications of removing this assumption and seek clarification on the mathematical validity of certain expressions related to process noise.
  • One participant questions the necessity of the whiteness hypothesis in the derivation of the Kalman filter, asking where the mathematical proof fails if this assumption is removed.
  • Another participant references a thesis that discusses modifications to the white noise hypothesis, suggesting that there may be alternative perspectives on this assumption.
  • A participant shares a specific article and points out that certain formulas were derived without assumptions on process noise, raising a doubt about the necessity of whiteness for expressing the probability density.
  • One participant explains that white noise is defined as uncorrelated noise and discusses how correlated noise could lead to suboptimal estimates, framing this as a modeling question rather than a strict mathematical requirement.
  • A later reply seeks clarification on whether the absence of whiteness would constitute a logical error in writing the equality for the probability density.
Participants express differing views on the necessity of the whiteness assumption in the context of the Kalman filter. There is no consensus on whether the mathematical expressions can be correctly formulated without this assumption, indicating an unresolved debate.
Participants reference specific articles and theses, suggesting that the discussion is informed by various sources, but the implications of removing the whiteness assumption remain unclear and are not fully resolved within the conversation.
Unconscious
In Kalman filter mathematical treatment I have always read that a foundamental hypothesis is represented by the whiteness of the process noise. I have tried to do again the mathematical steps in the Kalman filter derivation but I can't see where such hypothesis is crucial.
Could you help me showing where the mathematical proof fails if I remove such hypothesis?
Thanks.
Thank you for the link, but unfortunately I have not found an answer in that pages.
Anyway, I try to share with you my doubt more precisely.
Let's consider the formulas in Fig. 1 in this article:
https://arxiv.org/pdf/1712.01406.pdf
These two formulas have been obtained without assumptions on the process noise. Then, again without assumptions on the process noise, the author arrives at formula (5), in which appears the probability density ##p(x_k | x_{k-1})##. Taking into account the first equation of the system (1), now he says that if we suppose the gaussianity and the whiteness of the process noise, we can then write such probability density as ##\mathcal{N}(f(x_{k-1}),Q)##.
It is exactly in this point that my doubt arises: it seems to me that I could have written ##p(x_k | x_{k-1})=\mathcal{N}(f(x_{k-1}),Q)## even if I had only assumed gaussianity of the process noise, without whiteness, because ##x_k## is conditioned only by ##x_{k-1}## and not also by ##q_{k-1},q_{k-2},...##.
By definition, white noise is noise that is uncorrelated from sample to sample.
Suppose the actual noise of your sensor was totally correlated - on the first sample, you pick a gaussian, and that's the noise the entire time.
Let's say the first pick is a positive noise.
Then a better algorithm would be able to learn that the noise picked is positive (e.g. it notices that 2/3 of the measurements are higher than its estimate), and could adjust to start making lower estimates given the measurements.
On each step, in some sense you could say ok, I don't know anything about the noise, so since I'm ignorant about it it's a gaussian as far as I can tell, and this kind of works (you can use a Kalman filter in a variety of real world situations that don't fit the theoretical framework and it works pretty well still). But it's not the best estimate you can form if you *are* informed about the noise.This is just a modeling question. If you make 8 samples and all of them return higher measurements than you expect, do you chalk it up to bad luck, bad measuring, or a bad understanding of what the process is? The assumption of the noise being white means the Kalman filter says it's bad luck.
This is clear to me, thank you.
What is not clear to me is the pure math, in particular the step highlighted in my last post.
So, are you saying to me that if the noise is not white, then I can’t correctly write the equality ##p(x_k|x_{k-1})=\mathcal{N}(f(x_{k-1}),Q)##? In other words, this equality would be a logic error?
