Non Ideal Batteries in Electric Current
5 replies · 6K views · last reply
h2obc33
A circuit is constructed with five resistors and one real battery as shown above right. We model. The real battery as an ideal emf V = 12 V in series with an internal resistance r as shown above left. The values for the resistors are: R1 = R3 = 57 Ω, R4 = R5 = 75 Ω and R2 = 133 Ω. The measured voltage across the terminals of the batery is Vbattery = 11.62 V.
Left: circuit schematic with a dashed box around an ideal emf V in series with internal resistance r, feeding resistors R1, R2, R3, R4 and R5, with currents I1 and I3 marked. Right: the same circuit with a real battery in place of the dashed box, and a grey arrow pointing from right to left between them.
1) What is I1, the current that flows through the resistor R1?
Ohm's Law V=IR
Kirchoff's Laws: At Junction Iin = Iout and loop ΣVn=0
To solve for I1 I did Vb/Requivalent. That would be R345 = R3+R4+R5 then I1 = Vb/(R1+(1/R345+1/R2)^-1) = 87mA
I got the message "It looks like you've calculated the current through R1 by dividing the emf of the battery (12 V) by the equivalent resistance of the external resistances in the circuit. This is not quite right. Look at the circuit more carefully to correct your mistake."
I made sure to used 11.62V instead of 12V so I still don't understand what I did wrong.
Left: circuit schematic with a dashed box around a voltage source V in series with internal resistance r, resistors R1, R2, R3, R4, R5 and currents I1 and I3 labelled. Right: the same circuit with a physical battery drawn in place of the source; a grey arrow points from right to left between them.
Ohm's Law V=IR
Your method is correct, Your equivalent resistance might be is wrong, or you really divided 12 V with it. What did you get as equivalent resistance?
For my equivalent resistance I got 133.5606Ω and I checked I divided 11.62/133.5606 = 0.087A (87mA)
Your equivalent resistance is not correct, I am afraid.
Thank you so much, I have it right now. I realized my error, I mistook the R values for those of a previous problem. I even checked and if I had used 12 with the correct R equivalence it would have been nearly the same as my original answer.
Yws
Yes, it was funny, that your result was as if you divided 12 V with the correct resistance :)
