Undergrad Nonlinear Pendulum: Calculating Angular Displacement
To calculate angular displacement for a nonlinear pendulum using elliptical integral equations, one must first determine the time period of the pendulum, which can be derived from the complete elliptic integral of the first kind. The discussion emphasizes that there is no straightforward analytic solution for angular displacement, θ(t), in nonlinear cases. Instead, numerical methods or simulations may be employed to model the relationship between angular displacement and time. Additionally, resources such as Wikipedia and various articles provide insights into the mathematical foundations and potential methods for plotting θ(t). Ultimately, understanding the period is crucial, but deriving θ(t) remains complex without simple formulas.
Saim
If I calculate the time period of a non linear pendulum using elliptical integral equation, then how can I find out the angular displacement.
Welcome to the PF. :smile:
What reading have you been doing on this question so far? I did a Google search on the phrase from your post and got a lot of useful hits: nonlinear pendulum using elliptical integral equation
https://www.google.com/search?clien...HHrYTgAhX1HzQIHbKWD9EQBQgpKAA&biw=807&bih=572
The differential equation which represents the motion of a simple pendulum is
36e0d601a33a7562dfb162abd7e58859a40ccff1
If it is assumed that the angle is much less than 1 radian
e631c25b3635b429ab40642a8c2e2c23ff28fa87
and
above equation becomes
a4a67eb92d55d29ed4df138689010456418a3b15
Given the initial conditions θ(0) = θ0 and /dt(0) = 0, the solution becomes
c87ee425bd0a91e0e2b11316a3fa755c474e6e77
The period of the motion, the time for a complete oscillation is
93d0e7e6fb1df1c2541d6fabbfba15924e35cde4
For amplitudes beyond the small angle approximation,time period can be calculated using formula:
9b33d77af48c6b672509da8394e0e7387675db8e
K is the complete elliptic integral of the first kind defined by
7b79d77a3118e9cd02c82ee78498c50d71405646
So, If somehow I am able to calculate the Time period for non linear Pendulum, then how can I plot the angular displacement θ(t) against time.
I'm not certain exactly what you want but there are some interesting articles here on the period of extreme precision pendulum clocks. The articles include useful references.
http://www.leapsecond.com/hsn2006/
This is a discussion of the circular error correction of period using AGM.
http://www.leapsecond.com/hsn2006/pendulum-period-agm.pdf
You may be able to invert the equation in his conclusion.
Unfortunately they appear to be transcendental solutions.
Following that are pendulum simulations that model displacement against time.
http://www.leapsecond.com/hsn2006/pendulum-simulation-1.pdf
Perhaps there is a solution using the model, conversion between PE and KE.
There is no simple analytic formulation of ##\theta(t)## for the non-linear pendulum.
Check out https://en.wikipedia.org/wiki/Pendulum_(mathematics). You will find there how the period is found to be an elliptical integral, without having to know ##\theta(t)##. There is also an expression for ##\theta(t)## in terms of a Fourier series.
  • · Replies 27 ·
