Nonconservative collision - Work
en bloc
An 85kg baseball player is running towards home base at 8.0 m/s when he crashes into the catcher who is initially at rest. the two players slide together along the base path toward home plate. If the mass of the catcher is 95 kg and the coefficient of kinetic friction between the players and the ground is .70, how far will the players slide?
1) Wnc = ΔKE + ΔPE
2) mv + mv = (m+m)v
I found the final velocity using equation 2, and used it to find Δx in equation 1. I'm not sure if this is right.
.70*1764N*Δx*cos180=(1/2)*180kg*(3.78 m/s)^(2) - (1/2)85kg*(8 m/s)^(2)
-1235N*Δx = -1434N
Δx=1.16m
The initial velocity seems correct.
For the next part try this:
[tex]\frac{1}{2}(M+m)v^{2} - W_{f} = \frac{1}{2}(M+m)v^{2}[/tex]
That is, their initial kinetic energy, minus the work done by friction, equals their final kinetic energy. Well, after they are done sliding their final KE is 0 right?
[tex]\frac{1}{2}(M+m)v^{2} - u(M+m)gx = 0[/tex]
Oooooh. That's right. KEf is 0, so equation 1 should've been like this:
Wnc= ΔKE + 0
.7 * 1764N * Δx * cos180 = 0 - 1/2 * 180kg * (3.78 m/s)^2
Δx= 1.04m
Thanks!
