Normalization of free scalar field states
6 replies · 2K views
soviet1100
Hi,
if we adopt the convention, [itex]a^{\dagger}_\textbf{p} |0\rangle = |\textbf{p}\rangle[/itex]
then we get a normalization that is not Lorentz invariant, i.e. [itex]\langle \textbf{p} | \textbf{q} \rangle = (2\pi)^3 \delta^{(3)}(\textbf{p} - \textbf{q})[/itex].
How do I explicitly show that this delta function (of 3-vectors) is not lorentz invariant, say for a boost in the p^3 direction ? What is [itex]\langle \textbf{p'} | \textbf{q'} \rangle[/itex] where the primed frame is the boosted frame?
I thought since [itex]\int d^{3}\textbf{p} \hspace{2mm} \delta^{(3)}(\textbf{p} - \textbf{q}) = 1[/itex] is lorentz invariant (integral over all space, so includes q)
and as [itex]\hspace{3mm} d^3 \textbf{p} = \gamma^{-1} d^3 \textbf{p'}[/itex], (primed frame is boosted frame)
so [itex]\hspace{5mm} \delta^{(3)}(\textbf{p} - \textbf{q}) = \gamma\,\delta^{(3)}(\textbf{p'} - \textbf{q'})[/itex].
so that [itex]\int \gamma\,\delta^{(3)}(\textbf{p'} - \textbf{q'}) \gamma^{-1} d^3 \textbf{p'} = 1[/itex] stays Lorentz invariant.
However, Peskin gets for the same calculation (p.22-23, eqn.2.34) the result
[itex]\delta^{(3)}(\textbf{p'} - \textbf{q'}) = \delta^{(3)}(\textbf{p} - \textbf{q}) (\frac{E}{E'})[/itex] using a method that I don't really understand well.
Have I made a mistake somewhere?
Why?
You can't just impose this because you want it to be true. The mathematical relationship between ##\delta^{(3)}(\textbf{p} - \textbf{q})## and ##\delta^{(3)}(\textbf{p'} - \textbf{q'})## has to be investigated mathematically. Peskin and Schroeder does this at the top of page 23.
What don't you understand about the math at the top of page 23.
Sorry, I don't know what I was thinking. Lack of sleep. Of course, [itex]\int d^{3}\textbf{p} \hspace{2mm} \delta^{(3)}(\textbf{p} - \textbf{q})[/itex] does not have to be Lorentz invariant. I deserve a slap for that, please disregard that trail of thought.
Here's what P&S do: They consider a boost in the 3-direction, with the unprimed frame as the boosted frame as:
[itex]p'_3 = \gamma\,(p_3 + \beta E), \hspace{4mm} E' = \gamma\,(E + \beta\,p_3 )[/itex]
and then they use the identity [itex]\delta(f(x) - f(x_0)) = \frac{1}{|f'(x_0)|}\,\delta(x - x_0) \hspace{4mm}[/itex] to get:
[itex]\delta^{(3)}(\textbf{p} - \textbf{q}) = \delta^{(3)}(\textbf{p'} - \textbf{q'}) \frac{dp'_3}{dp_3}[/itex]
The subsequent steps, I follow. It's just the one above that I don't get. Here is my attempt:
First, isn't the delta function identity [itex]\delta[g(x)] = \sum_i \frac{\delta(x-x_i)}{|f'(x_i)|}[/itex], where the xi are roots of the function g(x)?
To get a relation between the boosted [itex]\delta^{(3)}(\textbf{p} - \textbf{q})[/itex] and the unboosted [itex]\delta^{(3)}(\textbf{p'} - \textbf{q'})[/itex], I suspect P&S have used the identity on the former to bring out p'3.
I take [itex]g(\textbf{p'}) = \textbf{p} - \textbf{q}, \hspace{4mm} \textbf{p} = (p_1, p_2, p_3) = (p'_1, p'_2, \gamma(p'_3 - \beta E_p')), \hspace{4mm} \textbf{q} = (q_1, q_2, q_3) = (q'_1, q'_2, \gamma(q'_3 - \beta E_q'))[/itex]. We want the values of p' that will give a zero for g(p') as defined above.
Now, [itex]\textbf{p} - \textbf{q} = (p'_1 - q'_1, p'_2 - q'_2, \gamma[(p'_3 - q'_3) - \beta (E'_p - E'_q)])[/itex]
So [itex]\textbf{p'} = \textbf{q'}[/itex] isn't a sufficient condition for a zero of g(p'), is it? One must also have E'p = E'q, isn't it so?
Are there any flaws in my working? I suspect there obviously are, for I don't know how to get the factor [itex]\frac{dp'_3}{dp_3}[/itex] out.
Yes. (Typo in the denominator.) What happens if you set ##g\left(x\right) = f\left(x\right) - f\left(x_0 \right)##?
But the fact that ##\left( \Delta E \right)^2 - \left( \Delta p \right)^2## is frame-invariant gives you ... ?
Sorry about the typo. [itex]\hspace{2mm} \delta[g(x)] = \sum_i \frac{\delta(x-x_i)}{|g'(x_i)|}[/itex]. I get it now:
Setting [itex]g(x) = f(x) - f(x_i)[/itex] gives the zeros of g(x) as xi and [itex]g'(x) = f'(x)[/itex] so one obtains the form of the identity used by P&S:
[itex]\delta[f(x) - f(x_i)] = \sum_i \frac{\delta(x-x_i)}{|f'(x_i)|}[/itex].
Ah, of course. [itex]\Delta E^2_p - \Delta |\textbf{p}|^2 = \Delta E^2_q - \Delta |\textbf{q}|^2[/itex], and [itex]\textbf{p'} = \textbf{q'}[/itex] implies [itex]E'_p = E'_q[/itex]. So, p' = q' is indeed a sufficient condition for a zero of g(x).
As for the obtaining the factor [itex]\frac{dp'_3}{dp_3}[/itex], I've managed to come up with it using intuition and some mathematics that I'm unfamiliar with. Perhaps you would care to comment if it is incorrect, or if there is a better way?
Computing the factor [itex]|g'(\textbf{p'}=\textbf{q'})|[/itex] :
Now, [itex]\textbf{g}(\textbf{p'}) = \textbf{p} - \textbf{q} = (p'_1 - q'_1, p'_2 - q'_2, p_3)[/itex].
According to the definition in the 'addendum' of the first answer (by user 'joshphysics') on this page (linked), one has:
[itex]\left| \frac{d\textbf{g}}{d\textbf{p'}} \right| = \left| \begin{array}{ccc} \frac{dg_1}{dp'_1} & \frac{dg_1}{dp'_2} & \frac{dg_1}{dp'_3} \\ \frac{dg_2}{dp'_1} & \frac{dg_2}{dp'_2} & \frac{dg_2}{dp'_3} \\ \frac{dg_3}{dp'_1} & \frac{dg_3}{dp'_2} & \frac{dg_3}{dp'_3} \end{array} \right| = \left| \begin{array}{ccc} 1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & \frac{dp_3}{dp'_3} \end{array} \right| = \frac{dp_3}{dp'_3}[/itex].
(Actually, the link above defines the total derivative of a vector valued function w.r.t a vector as a matrix of various partial derivatives. I just assumed that the bars in the denominator when applied to a square matrix meant the determinant.)
Did I get everything right?
Even if I did, I confess that there are two pieces of math here that I haven't studied before (I'm a 2nd year undergrad). One is the identity involving the delta function (of a function), and the other is the definition of the derivative of a vector valued function w.r.t to another vector. Could you perhaps point me to resources (preferably a book for the latter) that discuss these concepts?
Thanks a ton for the guidance!
Sorry, disregard my questions in the last post. I proved the identity myself and found a good book on the latter subject - Hubbard's Vector Calculus, Linear Algebra, & Differential Forms (A Unified Approach).
Thanks again.
Corrected: [itex]\textbf{g}(\textbf{p'}) = \textbf{p} - \textbf{q} = (p'_1 - q'_1, p'_2 - q'_2, p_3 - q_3)[/itex]
