Understanding Net Energy Transfer Rate in Parallel Plate Setup
  • Thread starter Thread starter Silviu
    Blackbody
The discussion focuses on calculating the net energy transfer rate per area between two parallel plates at temperatures ##T_L## and ##T_R## with emissivities ##\epsilon_L## and ##\epsilon_R##. The net transfer rate is derived using the equations $$I_R=\epsilon_L\sigma T_L^4+(1-\epsilon_L)I_L$$ and $$I_L=\epsilon_R\sigma T_R^4+(1-\epsilon_R)I_R$$, leading to the net energy transfer rate $$I_{net}=I_R-I_L$$. The term ##(1-\epsilon)I## represents the reflectivity of the opposite surface, allowing for simplification by avoiding multiple reflection calculations. This approach effectively utilizes Kirchhoff's law, establishing a clear method for determining the energy flux between the plates.
  • Understanding of thermal radiation principles
  • Familiarity with Kirchhoff's law of thermal radiation
  • Knowledge of the Stefan-Boltzmann law
  • Basic algebra for solving simultaneous equations
  • Study the Stefan-Boltzmann law in detail
  • Learn about Kirchhoff's law and its applications in thermal radiation
  • Explore the concept of reflectivity in thermal systems
  • Practice solving simultaneous equations in thermal transfer problems
Students and professionals in thermal engineering, physicists studying heat transfer, and anyone involved in designing systems with radiative heat exchange between surfaces.
Silviu
Two parallel plates plates are maintained at temperatures ##T_L## and ##T_R## respectively and have emissivities ##\epsilon_L## and ##\epsilon_R## respectively. Given the Stephan-Boltzmann constant ##\sigma##, express the net energy transfer rate per area from the left plate (L) to the right plate (R).
The way they solve it is by calculating the transfer rate to the right and left like this: $$I_R=\epsilon_L\sigma T_L^4+(1-\epsilon_L)I_L$$ and $$I_L=\epsilon_R\sigma T_R^4+(1-\epsilon_R)I_R$$ and the net transfer is $$I_{net}=I_R-I_L$$ I am confused about the ##(1-\epsilon)I## term. Where does that come from? How can ##I_L## which is the energy leaving the right plate, contribute to the flux of energy TO the right plate? It is already there, within the right plate.
There are multiple reflections that occur if just the radiated energy is considered. The ## (1-\epsilon)I ## is a reflectivity term from the opposite surface. (By Kirchhoff's law, ## \rho+\epsilon=1 ##. Reflectivity ## \rho=1-\epsilon ##). ## \\ ## This makes it possible to avoid computing multiple reflections. Two equations and two unknowns allows also for solving for ## I_R ## and ## I_L ## separately. ## I_R ## and ## I_L ## are the incident intensities onto the right and left surface, respectively, and they each include energy that may result from multiple reflections. ## \\ ## I think if you compute it, you will find ## I_R \epsilon_R-\epsilon_R \sigma T_R^4=-(I_L \epsilon_L-\epsilon_L \sigma T_L^4)=I_R-I_L ##. The net flow from left to right is what is absorbed minus what is radiated by the right surface, and it is the minus of what is absorbed minus what is radiated by the left surface. And, yes, this result follows with just a little algebra on the two equations that you presented in part 3 above.
  • · Replies 30 ·
9K
