cmb said:
Sorry, I don't understand that diagram. (What are the dots meant to represent, a clock tick? Why are they at different gap lengths on the lines, what is the significance of the angle chosen for the red line? I'd have thought the way to draw it would be dots of equal separation along each path, then the 'observation' line is one that intersects the other path at 90deg, no?)
Yes, the dots represent a clock tick. The detailed reasoning for the spacing of the dots is not necessarily required to understand why the twin pardox isn't a pardox, but it's interesting, I think.
Relativity tells us that [itex]\Delta t^2 - \Delta x^2[/itex] is constant for all observers (using units where c=1, and light moves at a 45 degree angle on the graph).
The spacing of the dots is 4 graph units for the stationary observer making [itex]\Delta t[/itex] =4. Since [itex]\Delta x[/itex] is zero, the interval is [itex]\Delta t[/itex]^2 =16 in this case, For the moving observer, the spacing is [itex]\Delta x[/itex] = 3 and [itex]\Delta t[/itex] =5, and 5^2 - 3^2 = 25-9 = 16. So the dots are spaced at equal 4 unit intervals. The dots which occur at [itex]\Delta t[/itex] =4 have an identical spacing of "proper time", computed by the formula above, said formula giving the results which an actual clock would measure, as the dots which have [itex]\Delta x[/itex] = 3 and [itex]\Delta t[/itex] =5.
The angle of the red-line can be derived by another space-time diagram, I'll do that in another post since you're interested. Again, while it is interesting to know why the lines are drawn the particular way they are, the exact reasoning isn't needed to be known to understand why the twin paradox isn't an actual paradox.
1) OK, let's deal with the 'real world' example above. So a satellite is launched with clock correction factors of 45,900 ns/day retardation, to counter the gravitational field effect
and 7,200 ns/day advance to account for the kinematic effects. It is launched into space and after 10 years an observer on the ground is still receiving time-stamped messages (inclusive of time-of-flight correction) from it that match the ground-based clocks, because the correct correction factor was fed in at launch. This appears to be what actually happens today, in real life. So, firstly, is my understanding of any of that incorrect?
I haven't gone through the numbers you quote in detail, but it sounds basically correct. However, you are moving into the grounds of general relativity when you talk about gravitational effects, it would be best to postpone that until you understand special relativity fully.
2) But now for the thought experiment; a satellite is launched tomorrow with an astronaut on board with a life-support capsule sufficient for a 10 year mission, and he stays there for 10 years. He has no audio connection with the ground, he is a space-hermit! Each and every day, as far as he is concerned, he checks the signal from the ground based clock (inclusive of tof correction). He notes that it is losing 14,400ns/day relative to his clock, because the ground based one is running 7,200 ns/day slower, plus his clock has already been set to run 7,200 ns/day faster as well.
I'm getting confused by the space-traveler using a tweaked clock. If he's a hermit, and not communicating with the ground, I'd give him a standard clock. I'm not positive I understand how you intended his clock to be tweaked, (or why you'd even want to tweak it in the first place, unless he communicates with the ground constantly).
3) At the end of his 10 year mission he comes back to Earth and says to his flight director "over the 10 years, I observed the ground based clock gradually fall behind mine by 14,400ns/day, and the signal I got from it before I left orbit was 52 milliseconds behind mine" and the flight director says "that's funny, your clock matched ours for all of the 10 years". They compare clocks and find ...? What do they find? Did the astronaut's clock correct itself during the descent back to earth, or are the clocks at different times?
I presume paragraph 2 is where there must be an error, but I cannot see it? You might argue paragraph 3 but, obviously, we could do the thought experiment for a million years and end up with an hour's difference before he came back down to ground. The act of coming back down surely can't have a 'variable' effect on the astronaut's clock, according to how long he's been up, can it!?
So, my question boils down to: When the astronaut and flight director compared clocks, what did they find?
I can answer that for a non-tweaked clock, which represents proper time, easily enough, and hopefully if you know how you intended your clocks to be tweaked (though I still don't see why you'd want to), you can perhaps figure out the answer to your question.
Perhaps you are assigning some sort of special philosophical significance to the clock-tweaking? As far as I'm concerned what is of interest is what an untweaked clock would measure, as this would represent the actual passage of time for an astronaut. If I'm reading Neil Ashby right, tweaking the clocks isn't even done directly nowadays, they let the clock keep it's own proper time, and send a polynomial back and let the calculator at the receiver due the necessary corrections.
If we use
http://relativity.livingreviews.org/Articles/lrr-2003-1/ as a source, and we assume a geostationary orbit, then the orbiting clock is too fast, by a factor of 4.4647*10^-10. A year is approximately 3.1557 10^7 seconds, so if we take a 10 year period, the astronaut's clock will gain .14 seconds over those ten years. Nothing special happens when the astronaut lands, he's just .14 seconds older than his twin on Earth - I'm not sure why this is confusing you, or what's confusing about it.
