Now, does A always cause C?Does A always lead to C?
  • Context: Undergrad
  • Thread starter Thread starter jaketodd
12 replies · 12K views
jaketodd
I know this is very basic but it has been awhile since my logic course in college. If A causes B and B causes C, does A cause C? And if the answer is "sometimes," then what requirements are there for A to cause C?
I did some research on Google and most of what I found agrees that A causes C, but then I ran into some gray area.
Thanks,
Jake
The property where : If A 'causes' B, and B 'causes' C, then A 'causes' C, is known as transitivity.
In this case it really depends what do you mean by 'cause'.
Many relations are transitive. Indeed, all equivalence relations are transitive..so are simple order relations as well.
Thanks,
Jake
Causality is an empirical concept, not a logical relation. There are a number logical (or formal) relations which are transitive such as (>)where if a>b>c, then a>c. However this would apply to causality only in specific situations, and only as observations from which certain empirical relations might be inferred as opposed to proved.
If A causes B through an equation and B causes C using the same equation, then does A cause C?
Thanks for the help,
Jake
Jake
Show me an equation where A causes B and B causes C.
sw vandecarr said:
show me an equation where a causes b and b causes c.
b=ax
c=bx
jaketodd said:
b=ax
c=bx
That's two different equations. You've just shown that:
x=b/a; and x=c/b
How does this show transitivity and what's it got to do with causality?
First: Causality is sometimes incorrectly confused logical implication. For example P -> Q and Q -> R. than you can conclude that P ->R where -> means 'implies'.
Now let's say c is the relation of causation. Then what does A c B; B c C mean?
Does it mean A is the sole cause of B?
Does it mean A always causes B?
Does it mean A can be the sole cause of C as well?
Does it mean A always causes C?
Does it mean that A will cause C only by causing B which causes C?
Discussions of causality really belong in the philosophy forum. It's much more complicated than I indicated here. For example, it involves the notion of necessary and sufficient conditions.
So if A causes B and B causes C, then A is not causally connected to C?
A lighted match lights a fuse which detonates some dynamite. The dynamite detonation causes the old bridge to collapse. Did the lighted match cause the old bridge to collapse?
I believe that by "causes" you mean "implicates".
well, in fact
((A => B) ∧ (B => C)) => (A=>C)
Is always true
Is always true
Of course. So? jaketodd continued to use the word "cause". Do you know the difference between empirical relations and logical relations? In post 7 I gave an example of logical implication and questions related to empirical causal reasoning.
How would you answer my previous example of a lighted match causing a bridge to collapse? This obviously only applies to a specific set of circumstances.
Sir, please stand calm and don't be hostile. by "you" I was referring to the person who started this topic. Besides I only wanted to give my good-willed contribute so the eventual doubty thoughts of jaketodd could be cleared.
And yes, I know the difference between logical and empirical relations.
Don't let the 8 hundred posts of difference between you and me be an argument for making any kind of assumptions about who I am or what I know. Because... A doesn't cause B
Sorry. jaketodd seemed to have difficulty understanding this despite my efforts, and you seemed to be following suit. My response wasn't hostile. Just a bit exasperated. If you post here frequently, you will get hostile responses sooner or later, regardless of what you post (although PF is better than most such forums in this regard).
