Nuclear Vibrations: Krane pg 141 | 0^+ State
  • Context: Undergrad
  • Thread starter Thread starter Incand
    Nuclear Vibrations
3 replies · 2K views
Incand
In a passage of our book (Krane page 141) they add two quadrupole phonons to a ##0^+## state. So as I understand it these phonon can be written in the form ##Y_{\lambda \mu}## with ##\lambda=2##. It makes sense that this corresponds to two units of angular momenta. Then they talk about the possible ##\mu## values for these phonons and get the list below. But I don't understand how they get the list below. I can understand how ##+\mu = \pm 4## forces ##l=4## but not the rest. Why isn't ##l=1## or ##l=3## permitted?
##l=4 \; \; \; \mu = +4, +3 ,+2 ,+1 ,0 ,-1,-2,-3,-4##
##l=2 \; \; \; \mu = +2 ,+1 ,0 ,-1,-2##
##l=0 \; \; \; \mu = +0##
They also say that if we instead add ##3## quadrupole the possible states are
##0^+, 2^+, 3^+, 4^+,6^+##.
But how is ##3^+## possible? Shouldn't the parity be ##(-1)^l##?
Even parity makes some sense with the total wave function of the phonons must be symmetric since they have integer spins and ##0^+## being symmetric the combination should be symmetric but I don't get why this contradicts the rule above.
Incand said:
They also say that if we instead add 333 quadrupole the possible states are
0+,2+,3+,4+,6+0+,2+,3+,4+,6+0^+, 2^+, 3^+, 4^+,6^+.
But how is 3+3+3^+ possible? Shouldn't the parity be (−1)l(−1)l(-1)^l?
Even parity makes some sense with the total wave function of the phonons must be symmetric since they have integer spins and 0+0+0^+ being symmetric the combination should be symmetric but I don't get why this contradicts the rule above.
i was looking up and found that the allowed states are due to angular momentum correlations...
<Angular-momentum selection rules allow for the values of λ = 0,1,2,3,4.
However, it turns out that not all of these values are possible
the wave functions for odd values of λ vanish: such states do not exist !
The two-phonon states are thus restricted to angular momenta 0, 2, and 4,
forming the two-phonon triplet.
This effect is an example of the interplay of angular-momentum coupling and
symmetrization (or, for fermions, antisymmetrization).>
To get a detail treatment of modes of vibrations (both surface vibrations and spherical vibrations)
one can look up the following...
<http://th.physik.uni-frankfurt.de/~svogel/lecture_ws_2011_12/slides_bratkovskaya_3.pdf>
That would explain it. I've read through the pdf too. I haven't read about Clebsch-Gordan coefficients before so I guess the explanation is a bit beyond me. But at least now I know a reason for why we only have even values of angular momenta. Kind of makes me even more curious about the three quadrupole phonon thought with their non even state.
I now remembered the parity rules explaining the ##3^+## state as well. Parity is ##\pi = \Pi_i \pi_i## so since the quadrupole phonon is even so is the total parity.
I found that the following pdf explain it quite nicely in a simpler way
https://www.icts.res.in/media/uploads/Talk/Slides/Regan-lecture2.pdf
So for example for two phonons we only had a single ##\mu = 3## state that is already accounted in ##l=4## so we got nothing over for ##l=3##. You can see the same reasoning applied to three phonons in the pdf. So just accounting for all the ##\mu## states we arrive at the right conclusion.
