How Do You Calculate Photon Number Density in a Specific Wavelength Range?
  • Thread starter Thread starter xdrgnh
    Density Photons
The discussion centers on calculating the photon number density in the sun's core for wavelengths between 599 nm and 601 nm using Planck's distribution function. Participants clarify that the formula for number density, which involves a constant times T^3, is inappropriate for this specific wavelength range. Instead, the correct approach involves integrating Planck's distribution function to find energy density and then converting that to photon density using the energy of individual photons, expressed as hc/λ. The approximation of using dλ ≈ Δλ is emphasized for simplicity in calculations.
  • Understanding of Planck's blackbody radiation formula
  • Knowledge of photon energy calculation (E = hc/λ)
  • Familiarity with concepts of energy density and photon number density
  • Basic integration techniques for continuous functions
  • Study Planck's distribution function in detail
  • Learn how to derive photon number density from energy density
  • Explore the implications of integrating over specific wavelength ranges
  • Review examples of photon density calculations in astrophysics
Students and professionals in physics, particularly those focusing on astrophysics, thermodynamics, and quantum mechanics, will benefit from this discussion.
xdrgnh
In Problem 1 find the number density of photons in the sun’s core for the region of wavelengths between 599 nm and 601 nm. In problem 1 temperature is given.
Planck blackbody formula and number density= constant times T^3 where T is temperature.
Everyone is telling me to use the constant times T^3 formula but that makes no sense in this problem. The constant times T^3 is only when all frequencies are integrated. However only a slice of frequency is considered. Is this question an error or something. A lot of questions and slides had errors in this class so far.
You are right, you can't use that formula. You need to use Planck's distribution function for the energy per unit volume for radiation that has a wavelength between λ and λ + dλ. See equation 5 here: http://www.oocities.org/vhsatheeshkumar/ModernPhysics.pdf.
Then think about how you would use this to get the number of photons per unit volume with wavelengths in the specified range.
I know I got to integrate the wavelengths to get the energy density. However I'm having a problem finding a way to get from energy density to photon density. I know the energy of each photon is hc/(wavelength).
You won't need to integrate. Note that you are considering a range of wavelengths Δλ that is very small. So, to a very good approximation you can let dλ ≈ Δλ.
To go from energy density to photon number density, consider the approximate energy of anyone photon in the range of wavelengths that your are dealing with.
So once I apply the approximation and plug in 599nm with my dλ ≈ Δλ equaling 2nm I divide by hc/599nm
Yes, that should do it. (You could also use 600 nm as a good average wavelength in the interval you are working with, but it won't make much difference.)
Thanks a lot. I think what got me was that I never had a expression with df in it before where I did not integrate. I thought a infinitesimal was so small that you can't put a number on it. I knew I had to find the energy density and then divide by something. However because I thought I was was integrating from 601 nm to 599 nm and the wavelength was changing I didn't really have a hc/v to divide by and that got me hooked up for hours today.
  • · Replies 19 ·
