Number of Elements in Finite Fields?
8 replies · 3K views · last reply
mathmari
MHB
Hey! :o
Let $p$ an odd prime and $F=F_{p^n}$ the finite field with $p^n$ elements.
1. Show that the set $F^2=\{a^2, a \in F\}$ has $\frac{p^n+1}{2}$ elements. Conclude that , if $t \in F$ the set $t-F^2=\{t-a^2, a \in F\}$ has $\frac{p^n+1}{2}$ elements.
2. For $t \in F$ show taht the set $F^2 \cap (t-F^2)$ is non-empty and conclude that each element $c$ of $F$ can be written in the form $c=a^2+b^2, a, b \in F$.
3. Show that the equation $x^2+y^2+z^2=0$ has a non-trivial solution in $F$.
I have done the following:
1. $a^2 \in F^2 \Rightarrow a, -a \in F$
That means that $F^2$ contains the half of the elements of $F\setminus \{0\}$, and the element $0$.
So, the number of elements of $F^2$ is $\frac{p^n-1}{2}+1=\frac{p^n-1+2}{2}=\frac{p^n+1}{2}$.
Is this correct?? (Wondering)
How can I show that conclude that if $t \in F$ the set $t-F^2=\{t-a^2, a \in F\}$ has $\frac{p^n+1}{2}$ elements??
2. Let $x \in F^2 \cap (t-F^2) \Rightarrow x=F^2 \text{ AND } x \in t-F^2 \\ \Rightarrow x=a^2, a \in F \text{ AND } x=t-a^2, t, a \in F$
How can I continue?? (Wondering)
3. We set $z=1$, then we have the equation $x^2+y^2+1=0 \Rightarrow x^2=-1-y^2$.
Does $-1 \in F$ ?? (Wondering)
Then we could use the question $2.$, right?? (Wondering)
Hi,
1. Is correct
In 2. you haven't proved that the intersection is non-epmty, but it's just the pidgeonhole principle.
For the other question, if $F^{2}\cap (t-F^{2})$ is non empty, then there exists some $b,c \in F$ such that $b^{2}=t-c^{2}$, and this holds for every $t\in F$
In 3. Yes, $-1\in F$ becaus is the inverse with respect to the addition of the neutral element with respect to the multiplication.
And now by 2. you got it
Fallen Angel said:
Hi,
1. Is correct
1. How can I show that conclude that if $t \in F$ the set $t-F^2=\{t-a^2, a \in F\}$ has $\frac{p^n+1}{2}$ elements??
2. How can I show that the intersection is non-empty?? (Wondering)
$-1 \in F$
By $2.$ we have that $c=a^2+b^2, a,b,c \in F \Rightarrow a^2=c-b^2$
For $a^2=x^2, c=-1, b^2=y^2$ we have that $x^2=-1-y^2$.
But how can we justify that the equation has a non-trivial solution in $F$ ?? (Wondering)
Hi,
1. The set $t-F^{2}$ it's just a traslation of $F^{2}$ so it has the same cardinality
2.I told you to use the pidgeonhole principle, you have two sets of $\frac{p^{n}+1}{2}$ elements contained in a set of $p^{n}$ elements, so ...
3.Since you have a solution with $z=1$ (by 2.) the solution is non trivial
Ok! (Smile)
Do you mean that $F^2 \subseteq F$ and $t-F^2 \subseteq F$ ?? (Wondering)
And is the way I formulated it correct?? (Wondering)
We set $z=1$, then we have the equation $x^2+y^2+1=0 \Rightarrow x^2=−1−y^2$.
$−1 \in F$
By $2.$ we have that $c=a^2+b^2,a,b,c \in F⇒a^2=c−b^2$
For $a^2=x^2,c=−1,b^2=y^2$ we have that $x^2=−1−y^2$.
Or could I improve something?? (Wondering)
I'm a little dubious about your proof of 1. Where do you use the fact that p is odd? For p=2, $F^2=F$. So I think you need to expand your proof.
For 2, as was pointed out, if A is any subset of an additive group, then the cardinality of $t-A=\{t-a:a\in A\}$ is the same as the cardinality of A. (You can easily define a one to one function from A to t-A.) So suppose $(t-F^2)\cap F^2$ is empty. Then $p^{n+1}=2\,{p^n+1\over 2}=|t-F^2|+|F^2|=|(t-F^2)\cup F^2|\leq p^n$, a contradiction. (The last inequality since $(t-F^2)\cup F^2\subseteq F$)
Yes
It's ok
How could I expand the proof?? (Wondering)
So, to show that $A$ and $t-A$ have the same cardinality do we have to show that this function is $1-1$ and onto?? (Wondering)
When we suppose that $(t-F^2)\cap F^2$ is empty, does it mean that $|(t-F^2)\cap F^2|=|t-F^2|+|F^2|$ ?? (Wondering)
Also, why does it stand that $(t-F^2)\cup F^2\subseteq F$ ?? (Wondering)
