Number of independent entries of a matrix
  • Context: High School
  • Thread starter Thread starter kent davidge
    Independent Matrix
The discussion focuses on determining the number of independent parameters in matrices, specifically orthogonal matrices. A general n x n matrix has n² entries. For orthogonal matrices, the constraints include normalization of rows and orthogonality conditions, leading to a reduction of degrees of freedom calculated as n(n-1)/2. The conclusion is that a 2 x 2 orthogonal matrix has one degree of freedom, while a 3 x 3 orthogonal matrix has three degrees of freedom, confirming that these matrices can be represented as rotation matrices.
  • Understanding of matrix theory and properties
  • Familiarity with orthogonal matrices and their characteristics
  • Knowledge of linear algebra concepts such as degrees of freedom and constraints
  • Basic understanding of rotation matrices in three-dimensional space
  • Explore the derivation of degrees of freedom in orthogonal matrices
  • Learn about the properties of rotation matrices in 2D and 3D
  • Investigate the implications of matrix symmetry on independent parameters
  • Study the application of orthogonal matrices in computer graphics and robotics
Mathematicians, physicists, engineers, and students studying linear algebra or matrix theory who are interested in understanding the constraints and parameters of matrices, particularly orthogonal and rotation matrices.
kent davidge
Is there an easy way to figure out the number of independent parameters a given matrix has?
For example, a general, real, n x n matrix has n^2 entries and that's easy to realize cause we have a squared array of real numbers. What if this matrix is orthogonal?
For an orthogonal matrix:
Consider the rows, call them ##A_i, i = 1,...,n##. You have the requirement that the rows are normalized, ##A_i A_i^T = 1## for all i. That's ##n## conditions.
And you have that ##A_i A_j^T = 0## for all ##i \neq j##. That's ##n(n-1)/2## conditions. So I believe that removes ##n + n(n-1)/2## degrees of freedom from the entries of ##A##, leaving ##n^2 - n - n(n-1)/2 ## ##= n(n - 1) - n(n-1)/2## ##= n(n-1)/2##. Of course those are nonlinear constraints so I'm not sure the arithmetic must work out exactly that way.
But assuming that it does, then a 2 x 2 has one degree of freedom and a 3 x 3 has three. Are the most general 2 x 2 and 3 x 3 matrices rotation matrices? I think so, and that would make sense. A 2 x 2 rotation matrix has one parameter, the angle. A 3 x 3 rotation matrix has two angles specifying the direction of the rotation axis, and a third expressing the amount of rotation.
You can definitely do this kind of counting for linear constraints. For instance, requiring that a matrix be symmetric , ##a_{ij} = a_{ji}## for ##j \neq i## means that you have ##n^2 - n(n-1)/2## ## = n^2 - (n^2/2) + (n/2)## ## = (n^2/2) + (n/2)## ## = n(n+1)/2## free parameters, the upper triangle (or lower triangle) of the matrix.
How many conditions do you get out of ##A^\tau\cdot A=I\,?##
  • · Replies 33 ·
