Number of moles = volume/molar mass?
  • Context: Chemistry
  • Thread starter Thread starter Tiptronic
    Mass Moles
The discussion centers on calculating the number of moles of glucose in a 0.2 mL solution, given its molar mass of 180 g/mol. The participants clarify that grams and milliliters are not equivalent, and emphasize the need for concentration (mol/L) to use the formula n = concentration x volume. The final calculation shows that 0.2 mL of the glucose solution contains 0.025 g of glucose, resulting in approximately 0.000139 moles. The justification for using this amount in a chemical reaction involving Phenylhydrazine hydrochloride is also discussed, confirming that the reagent is in excess.
  • Understanding of molar mass and its calculation
  • Knowledge of concentration units (mol/L)
  • Familiarity with stoichiometry and mole ratios in chemical reactions
  • Basic principles of solution chemistry and solubility
  • Learn about calculating molarity and its applications in solution chemistry
  • Study stoichiometry in chemical reactions, focusing on limiting and excess reagents
  • Explore the properties of osazones and their formation in organic chemistry
  • Investigate the relationship between molecular structure and physical properties, such as solubility and boiling points
Chemistry students, laboratory technicians, and researchers involved in organic chemistry experiments, particularly those studying carbohydrate reactions and solution calculations.
Tiptronic
Question:
0.2ml glucose solution.
Molar mass of glucose = 180 g/mol
How many moles?
If it was a mass in grams it would be easy:
n = mass/molar mass
But what do I do now its a volume?
Can I still use the same relationship, since grams is equivalent to ml isn't it?
If yes, then what does the unit of 'n' become...ml/mol?
Please help. Thanks.
Tiptronic said:
Question:
How many moles?
n = mass/molar mass
Grams are not equal to mL. cm^{3} are equal to mL.
Are you given the concentration (measured as M or mol/L)?
Tiptronic said:
Question:
How many moles?
The question is either incomplete or wrong. Please post the COMPLETE question, EXACTLY as it is given to you.
n = mass/molar mass
Correct.
No, you can't.
The number of moles only has one unit : "moles". Anything that is dimensionally different from this can not be a unit for the number of moles.
Thanks for the quick replies guys.
Glucose + 3 Phenylhydrazine hydrochloride --> Osazone + Phenylamine + Ammonia + Water
These are what I am using in this reaction:
0.2ml of a Lucozade drink (not diluted, so its 100% concentrated as you'd buy it off the shelf)
0.4g Phenylhydrazine hydrochloride
0.6g crystallized sodium acetate
4ml distilled water.
What i need to do is justify the use of 0.2ml of the glucose drink by using the ratio in the equation (1:3) and by working out the no. of moles of Phenylhydrazine Hydrochloride... n = 0.4/142.5 = 2.8 x 10^23
Now I need to work out the number of moles of the Glucose drink.
Any ideas?
Just thought of something:
Could i use this:
Though i doubt "100%" is a concentration that can be used in the above relationship?
Could i use this:
No, 100% is not a concentration (since n = concentration x volume, with n in units of moles and volume in units of L, then concentration must have units of mol/L).
So, there is no way I can work out the concentration from the information I have?
So could you tell me how I can justify the use of 0.2ml of the Lucozade Glucose drink?
My head hurts. :(
Sorry I am an idiot. http://www.tamscc.org/forum/images/smilies/bang_head.gif
The whole point of this investigation was to find the glucose amount: I did an experiment and found that in one bottle (380ml) there is 47g of glucose.
Thus, if 380ml contained 47g, then 0.2ml would contain: (0.2ml/380ml) x 47g = 0.025g
So now I know this:
0.2ml of 100% concentrated glucose containing 0.025g glucose.
Glucose molar mass = 180 g/mol
So can I now find 'n'?
n = mass/Molar mass
n = 0.025/180
n = 0.000139 mol
Please tell me this works now? And does this get me any closer to justifying why I've used 0.2ml in this Osazone test?
The Glucose is 0.000139 mol and the Phenylhydrazine hydrochloride is 0.0028 mol.
According to the equation the ratio is 1:3.
0.0028/0.000139 = 20 so its not as if there is three times as many molecules in the Phenylhydrazine hydrochloride than the glucose...
Help...
So now I know this:
n = mass/Molar mass
n = 0.025/180
n = 0.000139 mol
Thanks.
Get rid of "100% concentrated glucose"; it is wrong (you have a solution of glucose, meaning dissolved solute [glucose] in a solvent [likely water]).
Assuming your molar mass is exactly 180 g/mol, then I get 1.37E-4 (not 1.39E-4, as you get, although it might not matter much in the end, depending on sig figs).
Based on what you said you needed to do, you can take this amount and determine whether or not it is a reasonable amount of glucose needed in the reaction. If it is, you have justified yourself.
Thank you for the reply geoffjb.
Would this be a good explanation?
0.0028/0.000139 = 20 (2sf)
This means that the phenylhydrazine hydrochloride is more than 3 times the amount of glucose (in terms of mols) thus satisfying the ratio of the equation.
Looking at the equation:
The Phenylhydrazine hydrochloride should be in excess so that all the glucose is turned into the osazone. I have shown that the Phenylhydrazine hydrochloride is definitely in excess, satisfying the ratio of the equation, and thus this justifies using a small quantity of glucose drink (0.2ml) for the osazone test.
How does that sound?
If the theoretical ratio is 1:3 and the actual ratio is 1:20, are you justified in using only 0.2 mL of glucose?
If this is a scientific lab report, don't use "I".
Firstly, do I not need to multiply the 0.0028 mol by 3, if the equation says that 3 mols reacts with 1 mol of glucose?
So you're saying 0.2ml is too little? Doesnt 1:20 means that the phenylhydrazine hydrochloride is in excess? Then isn't that ok, since there is enough to react with all of the glucose? I don't quite understand.
Based on your equation, three moles of phenylhydrazine hydrochloride are required to react with one mole of glucose. Your multiplication factors must account for this.
You're right; it's definitely enough to react with all the glucose. However, since I don't know the original wording of the question, I don't know if such excess is "justified", as you were initially asking. Only you can determine this.
Sorry, I didnt understand. So do I multiply the 0.0028 mol of Phenylhydrazine hydrochloride by 3, and then form a ratio from that?
Its part of my write-up of my investigation. So I am ok in saying that such a small amount is justified, as the Phenylhydrazine hydrochloride should be in excess anyway for best results of this Osazone test?
Yes, in determining limiting reagents, you use a multiplication factor.
Okay.
Thanks for that, really appreciate it.
Btw, you wouldn't happen to know of any websites with information on the osazone, why its solid at room temperature and why it precipitates out? I've looked a lot but to no avail.
Thanks.
Thanks.
The physical state of osazone at room temperature would be dependent on the intermolecular forces between the molecules.
It would precipitate out simply because it is insoluble in the solvent. Remember that "like dissolves like".
More information on either question requires more in-depth analysis of the molecular structure of osazone.
http://jchemed.chem.wisc.edu/jcesoft/cca/cca5/MAIN/1ORGANIC/ORG18/TRAM18/C/THUMBS.HTM might help.
Thanks again. I hope I haven't taken up too much of your time.
It was my pleasure.
Hi again. I've stayed up all night and I've nearly lost the will to live.
Is the science of this ok?
The osazone that is precipitated in this reaction is a solid at room temperature. It has a high boiling point due to its structure and the intermolecular forces acting on it. There are a number of reasons for its high boiling point. Firstly, the size of this osazone molecule is quite big (its molecular mass is 358 gmol-1), which means that it has more electrons and more nuclei that create more Van der Waals forces. Molecular shape is another factor – molecules linear in shape have higher boiling points than their isomers with spherical shapes because the former has a greater contact surface area and thus relatively greater Van der Waals attractive forces.
This osazone is not soluble in water, because “like dissolves like”, and since water is a polar solvent and osazone is a non-polar molecule, the osazone will stay as a precipitate.
Can i add any more? This osazone is not polar is it - so it can't have permanant dipoles? And it doesn't do hydrogen bonding does it?
http://jchemed.chem.wisc.edu/jcesoft/cca/cca5/GRAPHTRAM/TRAM18/18C.GIF
Thanks once again.
12K
  • · Replies 51 ·
