Number Patterns: 11,13,17,19,23,29,31,....?
  • Thread starter Thread starter lahirurana
    Patterns
16 replies · 4K views
lahirurana
Moved form a technical forum, so homework template missing
Im little bit new to number patterns. Can anyone please solve this for me
11,13,17,19,23,29,31,?
This maybe pretty easy one but I am little bit confused.
BvU said:
What have you tried to do to solve it, so far ?
Different between consecutive numbers are 2 4 2 4 6 2
As my opinion next should be 4. So the answer should be 31+4=35
If the pattern go further it should be like 2 4 2 4 6 2 4 6 8 2 4 likewise. But the answe is given as 37
In my first attempt, I got the same number as you did. But looking at the numbers again, I realized that this is not a sequence based on a progression, but is related to an inherent property of the numbers (in other words, it has nothing to do with the difference or any other mathematical relation between two consecutive numbers). Hope this is a helpful hint.
Ohhhh s*** How could i miss that. Thank you very much sir. Primary Numbers
There are more like this ill add them later. First i have to try something on them. thank you very much.
BvU said:
If it's any consolation: I went for 35 too !
That shows that such problems can have multiple solutions. Unless a context is given, I see no reason why 35 wouldn't be a valid answer.
Does that actually count as a "sequence" given there isn't an equation for the nth term?
I don't think that it can be take from nth term
The OP never used the term sequence, only pattern.
Yep All sequences are patterns but not all patterns will be squences
SammyS said:
That is definitely a sequence. There is no such requirement that an equation is needed for the nth term.
I agree.
37 seemed to me to be the obvious next number in the sequence, for the reason that DrClaude gave.
lahirurana said:
Primary Numbers
We call them prime numbers in English.
And here's a formula for the whole sequence, starting with ##2,~3,~5,~7~...##
