Number theory ideals proof, where am I going wrong?
19 replies · 3K views · last reply
Firepanda
I'm trying to prove part iii)
So far:
Show x irreducible => no y in D-Dx where <x> is a proper subset of <y>
Suppose the contrary that x is reducible
=> x = ay for some a,y in D-Dx
=> x is an element of <y>
=> <x> is a subset of <y>
By part i) we showed that if <x>=<y> then a must be a unit, but this contradicts the fact that a is in D-Dx.
=> <x> must be a proper subset of <y>
Here is where I'm stuck
How do I complete this, or have I just gone the wrong way about it? I think I may be proving the converse of the iff statement in reverse, instead of proving this part of it.
Thanks!
So this tells me that x cannot be a unit and then what? :)
No, follow your train of logic. You have proven this:
x reducible => <x> is a proper subset of D
which is logically equivalent to this:
<x> = D => x is not reducible
Hmm hang on, for the whole thing wouldn't it be simpler for me to suppose x is irrecudible
=> x = ay for some unit a, y is in D-Dx else x=1
=> x is in <y>
=> <x> is contained in <y>
by part i) then <x> =<y> since x and y are associates.
So there can be no y in D-Dx such that <x> is a proper subset of <y>
Then i just prove in the other direction! No?
I'm not sure why you are focusing on reducible vs. irreducible. (ii) asks you to prove that <x> = D if and only if x is a unit. So why not start by assuming that x is a unit, and showing that this implies <x> = D?
I'm trying to prove part iii)! :)
LOL, sorry! I misread your original post. I'll go back and read it again with this in mind.
Suppose x is irreducible, and suppose x = ay for some elements a and y of D. If y is not a unit, then a must be a unit since x is irreducible.
Therefore, [itex]y = a^{-1}x[/itex], so [itex]<x> \subset <y>[/itex] and [itex]<y> \subset <x>[/itex]. Therefore <x> = <y>.
Now, for the other direction, you can do it one of two ways.
1. Assume x is NOT irreducible. Thus x is either a unit or a product of two non-units. Consider both cases and try to prove the conclusion.
or
2. Assume that there IS a nonunit y such that <x> is properly contained in <y>. Prove that x is irreducible.
or
Ok, I'm using option 2 here
So by part i) we have y divides x where x&y are not associate
=> x=ay where a is non unit
=> x is reducible
Then my argument is 'so there are no cases where y is a non unit such that x is irreducible, so x can only be irreducible if y is a unit'
Is that ok? I'm having a hard time believing I've proved it all
What I see is that I proved if there IS a nonunit y such that <x> is properly contained in <y> then x is reducible, and that if y is a non unit then x may be irreducible, and not what I set out to prove!
=> x is reducible
Yes, your proof looks OK to me. Let's recap what you have proved.
"if there IS a nonunit y such that <x> is properly contained in <y> then x is reducible"
This is logically equivalent to:
"if x is irreducible, then there is NO nonunit y such that <x> is properly contained in <y>"
which is precisely the => direction of the statement you are trying to prove.
In post #9, I also proved the => direction, using a different approach.
But you still need to prove the <= direction.
I listed two options to prove the <= direction, but unfortunately I made a typo in my option 2! Not enough coffee this morning, I guess.
It should have been:
or
2. Assume that there is NO nonunit y such that <x> is properly contained in <y>. Prove that x is irreducible.
You took my original option 2 ("Assume that there IS a nonunit y such that <x> is properly contained in <y>. Prove that x is irreducible." - a false statement) and turned it into "Assume that there IS a nonunit y such that <x> is properly contained in <y>. Prove that x is reducible" - a true statement, but equivalent to the => direction!
Ah, so I still need to prove the <= direction?
So using 1) this time
I assume this is logically equivalent to
The negation of (so I need to prove this following statement is not the case): [x reducible => there is a y non unit (where <x> is a proper subset of <y>)]
Which is equal to: [there is no such y non unit (where <x> is a proper subset of <y>) => x irreducible]
I'm taking this from what I believe:
-(A=>B) = (-B=>-A)
Is this true, and is this what you want me to do?
ok perhaps I'm complicating it, if I just do number 2)
if thre were such y then by part i) we have y divides x where x&y are not associate
But no such y exists in our assumption so x&y have to be associate, which means x=ay for all y, so x is irreducible.
Is that ok?
Sorry the fact that there is NO nonunit y is very confusing to me, making this proof very confusing!
Yes, that's correct. Your negation "[there is no such y non unit (where <x> is a proper subset of <y>) => x irreducible]" is the same as my revised option 2:
Is that ok?
I think you're running in circles. If the thing you are supposed to prove starts with "Assume that there is NO nonunit y such that..." then your proof can't start with "If there were such y..."
I think option 1 will be easier to work with:
i.e. If x is a unit or a product of non-units, then there is a nonunit y such that <x> is properly contained in <y>.
I suggest considering the two cases separately: first assume x is a unit, and show that there is a nonunit y such that <x> is properly contained in <y>.
Then assume x is a product of two nonunits, and show the same conclusion.
I thought by post #12 we are trying to show the negation of (so disprove)
'If x is a unit or a product of non-units, then there is a nonunit y such that <x> is properly contained in <y>.'
but you're asking me to prove it!
Also as a side note, why do I have to prove if x is a unit? If x is a unit then it's irreducible isn't it?
This is the second half of the "if and only if"!
You are trying to show that "A if and only if B."
You have already proven "if A, then B."
Now you want to prove "if B, then A", or equivalently, "if not A, then not B."
This statement: 'If x is a unit or a product of non-units, then there is a nonunit y such that <x> is properly contained in <y>.' is the "if not A, then not B" I am referring to.
No, by definition an irreducible element is NOT a unit. This is easiest to remember if you think of the special case of the integers. The units are +/-1, and the irreducibles are +/-p where p is any prime number.
Ohh I see now!
I can do it now I'm sure!
But last question about the unit case
If x is a unit, then the ideal generated by x is the domain D, which is certainly not a proper subset of whatever the ideal generated by y is. Are you sure I need this case?
Firepanda said:
Ohh I see now!
Yes, I just noticed this too. I think the statement is actually not correct as stated.
I think (iii) should read:
"x is irreducible OR A UNIT if and only if there is no nonunit y such that <x> is properly contained in <y>"
Maybe your instructor or book is allowing units to be irreducible? I don't think that is a standard definition, but if that is their definition then the statement would be valid.
yes. only non-units are irreducible.
i think that (iii) should be:
a non-unit x is irreducible iff...
because a unit certainly has the property that there is no non-unit y (indeed no unit nor non-unit y) such that <x> is a proper subset of <y>, but units are not generally considered irreducible.
