Numerical Analysis in C: Solving a sum
4 replies · 2K views
chill_factor
Solve the following sum: Ʃ f(0.01k) from k=1 to k=100000 where f(k) = √minimum of (1,k) * exponential(maximum of (1.5, k)*maximum of (1.5,k))
See above.
/*I've written a C program to solve this problem. it compiles. However, when I run it, the answer is 0 which is incorrect. What's wrong with either my methodology or coding?*/
#include<stdio.h>
#include<math.h>
main(){
int k; /*declare k variable */
double min; /*declare minimum variable*/
double max; /*declare maximum variable*/
double funcResult; /*declare function result*/
double sum; /*declare sum result*/
/*create minimum function*/
if(0.01*k<1){
min=0.01*k;
else{
min=1;
/*create maximum function*/
if(0.01*k>1.5){
max=0.01*k;
else{
max=1.5;
/*create funcResult function*/
funcResult=sqrt(min*exp(-max*max));
/*compute the sum */
sum=0;
for(k=1;k<=100000;k++){
sum=(sum+funcResult);
printf("The answer to this sum is: %lf\n and the funcResult is %lf",sum,funcResult);
See above.
#include<stdio.h>
#include<math.h>
main(){
if(0.01*k<1){
min=0.01*k;
else{
min=1;
if(0.01*k>1.5){
max=0.01*k;
else{
max=1.5;
sum=0;
You are setting sum to sum + funcResult 100,000 times, but funcResult keeps the value that it was given before the loop started.
You need to code funcResult as an actual function, not as a variable. Either that, or do the computation inside your loop.
Thank you! I obtained non-zero answers!
From your comments, you seem to believe that you are writing functions, but you're not.
For example, there's this code:
Code:
if(0.01*k<1){
 min=0.01*k;
 else{
 min=1;
 [/quote]
This code gets executed once, with garbage (uninitialized) values for k and min. I can't predict what min will be set to, since you haven't put a known value into k.
The situation is the same for max and funcResult. The values for these three variables are set before the loop begins execution, so any changes to k inside the loop have no effect on min, max, or funcResult.
See above.
#include<stdio.h>
#include<math.h>
main(){
if(0.01*k<1){
min=0.01*k;
else{
min=1;
if(0.01*k>1.5){
max=0.01*k;
else{
max=1.5;
sum=0;
Unless I misunderstand your f(k), it looks like this problem will involve serious numerical overflow. I think you are saying
[tex]f(k) = \sqrt{\min(1,5) \exp(\max(1.5,k)^2)},[/tex] and you want to evaluate f up to f(100000/100) = f(1000). However, f(1000) = 0.1741612873e217148, so the last terms in your sum will be immense. Are you sure you have not mis-stated the problem?
RGV
