Numerical Integration in Python
The discussion revolves around finding a numerical solution to a nested integral in Python, which is related to the cumulative distribution function (CDF) of a random variable. Participants explore the implementation details, potential errors in the code, and comparisons with Monte Carlo simulations.
  • One participant presents a Python implementation for evaluating a nested integral but notes that the results are not constrained between 0 and 1, suggesting an error in the code.
  • Another participant points out that with M=2, the area of integration is limited and questions how many points are being integrated over, suggesting that the area size should be accounted for in the calculations.
  • There is a discussion about the need for a proper count of points in the integration and the area represented by each point, with a suggestion that the recursion depth may be insufficient.
  • One participant suggests starting the recursion with m=0 to potentially address the issues raised, while another elaborates on the area of integration and the number of points needed.
  • Concerns are raised about the placement of the factorial multiplication in the code, with a suggestion to move it outside the recursive function to ensure it is applied correctly.
  • Participants discuss the accuracy of the numerical results compared to Monte Carlo simulations and question the correctness of the while loop condition in the code.
  • There is a suggestion to calculate an analytic value for comparison with the numerical and simulation results, as well as a request for clarification on the original integral's formulation.
Participants express differing views on the errors in the implementation and the correct approach to the integration. There is no consensus on the resolution of the issues raised, and multiple competing views remain regarding the accuracy and formulation of the integral.
Participants note that the original integral's formulation may have inaccuracies, and there are unresolved questions about the assumptions made in the code and the integration limits.
  • #31
Yes, there is a missing ##f_Y(y_2)## in the first formula. ##z_{m-1}=z_{m-2}-\sum_{l=1}^{m-1}\frac{x_l}{y_l}## for ##m=2,\,\ldots,\,M## and ##z_0=z##, which is passed as parameter. I get ##1.44\times 10^{-6}## from the program. The MC simulations is tractable, and the results make more sense. Basically, I want to evaluate
\text{Pr}\left[\frac{X_{(1)}}{Y_1}+\frac{X_{(2)}}{Y_2}\leq z\right]
where (##K\geq 2##)
X_{(1)}\leq X_{(2)} \leq \cdots X_{(K)}
are the order statistics of the RVs ##\{X_k\}_{k=1}^K##, which are i.i.d. exponential random variables with parameter 1, and ##Y_1## and ##Y_2## are also i.i.d. exponential random variables with parameter 1.
Setting dx and or dy smaller that 0.01, makes the running time significantly longer.
I think there is a problem in the logic of the program, and probably something to do with the argument ##z-ux/uy##, but not sure what it is!
Technology news on Phys.org
  • #32
What other forums I can use to get help on this? I tried Stack Overflow, but didn't get help there!
  • #33
As the saying goes, you'll find the helping hand at the end of your arm.
After 5 minutes of debugging, it seems that you need to reset ux to x_prev_lim inside the uy-loop rather than before it.
Now I'm getting 1.999329 with the code you posted, or 1.999993 with dx & dy=0.001. Are you using K=3, M=2?
But seriously, get rid of z and start from the first formula again.
In programming, you can't just wave your hands and hope the program will work. Move in small, careful steps.
  • #34
Oh, that is right. ux must start from x_prev_lim for each uy value. This is a CDF, and the value should be between 0 and 1. In the simulations I am using this code
Python:
import numpy as np
count = 0
N=100000
for n in range(0, N):
    X = np.random.exponential(1, (1, K))
    Y = np.random.exponential(1, (1, K))
    X=np.sort(X)
    Z = X/Y
    if np.sum(Z[:M]) <= 1:
        count += 1
print(count/N)
and yes for K=3, and M=2.
I am trying to run the code now for dx=dy=0.001, but it has been more than 90 minutes and it is still not finished. How long did the program take on your machine? Mine is a bit old (i5@2.4 with 6GB RAM).
  • #35
I've rewritten your code to C. It took like 20 seconds to run with 0.001 .
I'm not all that good with statistics but it seems the sort function is somehow missing in the other version. Are you sure that the first formula in #29 is correct?
  • #36
OK, that explains it. I will switch to C++. This is taking too much time in Python, and this is only to set the parameters right, and for one point!
The first formula in post #29 is missing ##f_Y(y_2)##, and thus it should be
<br /> K(K-2)\int_{y_1=0}^{\infty}\int_{x_1=x_0}^{\max(x_0,\,y_1z_0)}\left[\int_{y_2=0}^{\infty}\int_{x_2=x_1}^{\max(x_1,\,y_2z_1)}\left[1-F_X(x_2)\right]^{K-2}f_X(x_2)f_Y(y_2)\,dx_2\,dy_2\right]f_X(x_1)\,f_Y(y_1)\,dx_1\,dy_1<br />
but the code is correct, because it accounts for it. It was a mistake of typing the formula from my notes.
  • #37
Could you post your C code here? Probably it is because of the machine and how efficient the program was written (I am no expert in programming in general, and C++ in particular), but my C++ code takes (way) longer than 20s, and I assume there is no speed difference between C and C++, or that what I read at least. This is my code
Code:
#include <iostream>
#include <cmath>
using namespace std;
double F(double x, int K, int M){
    return exp(-x * (K - M));
double f(double x){
    return exp(-x);
double G(double z, int m, int M, int K, double x_prev_lim, double y_current_lim){
    double res (0);
    double y_upper_lim (7);
    double uy = y_current_lim;
    double dx (0.001);
    double delta (0.001);
    while (uy < y_upper_lim){
        double ux = x_prev_lim;
        double dy = max(0.001, uy * (1/(1 - uy * delta) - 1));
        while (ux < uy * z){
            if (m == M){
                res += F(ux, K, M) * f(ux) * f(uy) * dx * dy;
            }else{
                res += G(z - (ux/uy), m+1, M, K, ux, (ux / z)) * f(ux) * f(uy) * dx * dy;
            ux += dx;
        uy += dy;
    return res;
int fact (int A){
     if (A == 0) {
         return 1;
     return A*fact(A-1);
}int main(){
    int K (3);
    int M (2);
    count << (fact(K) / fact(K-M)) * G(1, 1, M, K, 0, 0.001)<<endl;
    return 0;
Note that when ##y_{m-1}<\frac{x_{m-2}}{z_{m-2}}##, the inner integration in the formula
<br /> G_{m-1}(z_{m-2})=\int_{y_{m-1}=0}^{\infty}\left[\int_{x_{m-1}=x_{m-2}}^{\max(x_{m-2},\,y_{m-1}\,z_{m-2})}G_{m}(z_{m-2}-\frac{x_{m-1}}{y_{m-1}})\,f_X(x_{m-1})dx_{m-1}\right]f_Y(y_{m-1})\,dy_{m-1}<br />
is 0, and ##\max(x_{m-2},\,y_{m-1}\,z_{m-2}) = y_{m-1} z_{m-2}## for ##y_{m-1}\geq\frac{x_{m-2}}{z_{m-2}}##. I tested it for dx = delta = 0.01 (delta is related to dy somehow), and it gives a result between 0 and 1, it is 0.33, which is not 0.048 as in the MC simulation. I am not sure if it will give better results with smaller dx and delta with 0.001. I am waiting to see, but as I said, it still takes a long time to run, even in C++.
  • #38
Unfortunately I don't have it here, I did it at work. But I rewrote your Python program pretty much 1:1.
I guess it doesn't help that you carry around all the parameters. It would be better to declare K, M, dx, dy as constants as you did in Python (using #define).
I remember I added a test at the beginning of G() to return 0 if z<0 but it didn't seem to change much.
I'm still trying to understand how the sort function is "accounted for".
Do you have some intermediate steps between the Monte Carlo program and the integral formula? I can't really see how they can be the same thing.
  • #39
In the mathematical formulation, the sort function is accounted for by saying that ##X_{(1)}## and ##X_{(2)}## are the minimum two values. The derivation of the integration is straightforward from the probability in post #31. The simulation is a different approach, and thus there is no intermediary steps between the two. But basically, I have two set of random variables ##\{X_k\}_{k=1}^{K}##, and ##\{Y_k\}_{k=1}^{K}##. Then I order the first set of random variable in ascending order, and pick the first two after ordering. Then I formed the random variable ##\frac{X_{(1)}}{Y_1}+\frac{X_{(2)}}{Y_2}##, whose CDF I want to calculate.
What is your machine specifications on which you ran the code, if I may ask? It takes way too long on my machine, which isn't a good news, because I need to evaluate this for different values of z, which will be much larger than 1!
  • #40
I derived a semi-analytical result (as far as I could) for the case ##M=2##, and it turned out that the numerical evaluation is correct as presented in post #37, and the simulation is not. In the simulation I should wrote
Python:
if np.sum(Z[0][:M]) <= 1:
instead of
Python:
So, my only mistake was not resetting ux for each uy value. Thanks @SlowThinker for pointing that out. I don't know how I missed it.
The programs is still running too slow, but for dx = delta = 0.01 it gives close results to the simulation (numerical is 0.33, and MC simulations is 0.31). I will change to Simpson's rule for more optimization.
  • #41
Interesting. For me, the G(1,1,0) call returned 0.333 but multiplying by 3!/(3-1)! changed it to 2.00 .
BTW my computer is i7 @ 2.3GHz. RAM or number of cores don't really matter here.
  • #42
I changed the code a little in the C++ version compared to the Python version, but the Python version should work also, but slower. I will check the latter in C++ and see.
I think the number of cores doesn't matter much, but I think the RAM makes a difference. At my my office I have i7 with 8 GB RAM, and it is much faster than my laptop for the same code, which is i5 @2.4 GHz and 6 GB RAM.
  • #43
The C++ code corresponding to the Python version for dx=dy=0.01 gave a result of 0.302535, and it took around an hour on my laptop! This is the code
Code:
#include <iostream>
#include <cmath>
const int K (3);
const int M (2);
const double dx (0.01);
const double dy (0.01);
const double y_upper_lim (7);
double F(double x){
double f(double x){
    return exp(-x);
double G(double z, int m, double x_prev_lim){
    double res (0);
    double uy = 0;
    double ux;
    //double dy;
        uy += dy;
        ux = x_prev_lim;
            ux += dx;
            if (m == M){
                res += F(ux) * f(ux) * f(uy) * dx * dy;
            }else{
                res += G(z - (ux/uy), m+1, ux) * f(ux) * f(uy) * dx * dy;
    return res;
int fact (int A){
     if (A == 0) {
         return 1;
     return A*fact(A-1);
}int main(){
    count << (fact(K) / fact(K-M)) * G(1, 1, 0)<<endl;
    return 0;
Maybe you multiplied K!/(K-M)! twice!
  • #44
Also it should be 3!/(3-2)! = 6.
  • #45
EngWiPy said:
C:
int fact (int A){
     if (A == 0) {
         return 1;
     return A*fact(A-1);
I haven't followed this thread for a while, but if you're dealing with somewhat large numbers, the recursive function you're using is not efficient, and might be the reason your code takes so long to run. In addition, the int return value will overflow for 13! and larger values of the factorial argument.
A better (because it's non-recursive), version follows.
C:
int fact (int n){
   if (n == 0 || n == 1) {
       return 1;
   int prod = 1;
   for (int i = n; i > 1; i--)
       prod *= i;
   return prod;
  • #46
C:
int fact (int n){
       return 1;
   int prod = 1;
       prod *= i;
   return prod;
I usually have small K and M, that are <= 5. The main reason why the code is slow is because of the large number of recursions for the G function. The function fact is called only twice to compute K! and (K-M)!.
By the way, can I parallelize the C++ code using multi threading?
  • #47
If there's some way to rewrite G() so that it's not recursive, that likely would speed up your program.
Sure, if you can figure out what each thread needs to do, and that the results from each thread don't rely on results from other threads.
  • #48
I want to evaluate the above function for different values of z. They are independent of each others, but in a for loop I need to do this sequentially.
  • #49
If the result from each loop iteration depends on the value from the previous iteration, I don't see how you can do things with multiple threads.
  • #50
I need to evaluate say G(1,1,0), G(2,1,0) ... G(10,1,0). These function are independent of each others. But in for loop these will look something like
Code:
for(int i=1; i <= 10; i++){
count  <<  G(i, 1,0);
which are evaluated sequentially. These can be evaluated in parallel. But how? I am not familiar with multithreading, but I think we can get Kx speed up, where K is the number of cores.
  • #51
Code:
count  <<  G(i, 1,0);
My computer, which I've had for five years, has an Intel Quad Core Duo processor, with each of the four cores having effectively two processors. This means that eight threads can be running. You're not going to have K cores, with K being an arbitrary integer. Your program also can't be using all the cores, as some of them will be used by the OS and other processes.
If I were going to write the code, I wouldn't have it iterate 10 times. Instead, I would iterate 4, or 8, or some power of 2, times, and I wouldn't use a loop. If I had four threads to play with, I would create four thread objects to evaluate G(1, 1.0), G(2, 1.0), G(3, 1.0), and G(4, 1.0). When the last one of these is finished, I would use the threads to evaluate G with a first argument of 5, 6, 7, and 8.
Also, I wouldn't output them in the loop. Instead, I would store the return values from G() in an array, and print them out when the array is full.
I can't say too much more about threads and such, since there's quite a bit more than I have explained. Threads are pretty low level. At a higher level of abstraction are async objects, which are easier to work with.
  • · Replies 18 ·
