Numpy multidimensional array assigment unknown logic error
The user is experiencing an issue with their bubble sort implementation on a multidimensional NumPy array, where all elements end up being set to the same value. This problem arises from the way NumPy handles array assignments, particularly with references to the same object rather than creating copies. The sorting logic is flawed because it swaps references instead of creating new copies of the elements, leading to all entries being the same after sorting. The user is advised to ensure proper array definition and consider using NumPy's built-in sorting functions for multidimensional arrays to avoid such issues. Understanding how NumPy manages memory and references is crucial for resolving this type of error.
NotASmurf
I'm confused as to why this bubble sort I'm implementing is setting _all_ items to one of the items (I have no idea which one as array is too big)
the data type is of
Python:
[[1128 1026 1192 1023]]
[[ 771  195  858  196]]
[[ 953 1799  955 1738]]]
when I have an array of int, this same algorithm sorts it perfectly, I presume my issue is that I do not understand multidimensional numpy array element assigment, please explain why this breaks:
Python:
lines = cv2.HoughLinesP(edges, rho, theta, threshold, np.array([]),
                    min_line_length, max_line_gap)
#sort by y
if(0==0):
    for i in range(0,len(lines)):
        for j in range(0,len(lines)):
            if(lines[i][0][1]<lines[j][0][1]):
                cnt = lines[i][0]
                lines[i][0] = lines[j][0]
                lines[j][0] = cnt
now the array is
Python:
[[[ 738 1831  867 1831]]
[[ 738 1831  867 1831]]]
why?
Technology news on Phys.org
the data type is of
Python:
Python:
#sort by y
if(0==0):
                cnt = lines[i][0]
                lines[j][0] = cnt
now the array is
Python:
why?
I think it's likely that you haven't defined your array correctly. See http://cs231n.github.io/python-numpy-tutorial/#numpy-arrays
Here's an example from the page in the link:
Python:
a = np.array([[1,2,3,4], [5,6,7,8], [9,10,11,12]])
This is a two-dimensional array. In Python-speak, it's a list of lists. Notice that the elements in each list are separated by commas, and that the sublists themselves are also separated by commas.
When an arrays is printed, commas aren't used, but they need to be there when you define the array.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
