Object 18cm in Front of Lens to Reduce Image by 2.0
  • Thread starter Thread starter physicsdawg
    Lenses
The problem involves a diverging lens with a focal length of -12cm and an object initially placed 18cm in front of it. The objective is to determine the new object distance required to reduce the image size by a factor of 2.0.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to apply the lens formula and magnification equations to find the correct object distance. There are discussions about the correctness of the calculations and the interpretation of the image distance.
Multiple participants are arriving at the same numerical answer of 36, but there is uncertainty regarding its correctness. Some participants are questioning the initial values used and whether the signs in the calculations are appropriate. Suggestions have been made to reconsider the object distance and the implications of the magnification factor.
There is a mention of a textbook providing a different answer (48), which adds to the confusion. Participants are also reflecting on the conditions of the problem and the nature of the images produced by a diverging lens.
physicsdawg
An object is 18cm in front of a diverging lens that has a focal length of -12cm. How far in front of the lens should the object be placed so that the size of its image is reduced by a factor of 2.0?
1/do + 1/di = 1/f
m= -di/do
i keep solving and getting 36 using those equations, but the answer says its 48 ...i donno how to get 48
1/18 + 1/di = 1/-12
di=7.2
m= -7.2/18
m=-.4
1/2m=-0.2
-.2= -7.2/do
do=36
Can you show your calculations, please? I can't find your mistake if I can't see your work.
k i edited it
Hmmm. I am also getting 36 as my answer. I know this is a stupid question, but are you sure your numbers are correct? It doesn't hurt to check. Also where are you getting the answer from?
physics textbook
Hi physicsdawg! :smile:
Try using 8cm instead of 18cm. :wink:
Hi physicsdawg,
1/do + 1/di = 1/f
m= -di/do
1/18 + 1/di = 1/-12
di=7.2
I believe this answer is incorrect. The numerical value is right, but it needs to be a negative number.
m= -7.2/18
m=-.4
1/2m=-0.2
With di=-7.2, all of these magnifications will be positive numbers (which checks out, since a single diverging lens creates upright images).
-.2= -7.2/do
The second image will not be in the same place as the first image, and so the di for the second case is an unknown quantity. This equation should therefore be:
[tex] 0.2 = - di/do[/tex]
and you need to find do. Do you see how to find it?
alphysicist said:
Hi physicsdawg,I believe this answer is incorrect. The numerical value is right, but it needs to be a negative number.With di=-7.2, all of these magnifications will be positive numbers (which checks out, since a single diverging lens creates upright images).The second image will not be in the same place as the first image, and so the di for the second case is an unknown quantity. This equation should therefore be:
Ahh, of course. The second image is not in the same place as the first. I made that mistake as well. ( For some reason, I thought that was a condition in the problem. Guess I read into it too much.) Nice catch alphysicist.
