ODE with Dirac Delta and conditions at infinity
The discussion revolves around solving a first-order ordinary differential equation (ODE) involving a Dirac delta function and specific boundary conditions at infinity. The equation is presented as \(\partial_{x} \, y(x) + a(x)\, y(x) = \delta(x)\), with the condition that \(\lim_{x \rightarrow \pm \infty}y(x) = 0\). Participants express uncertainty about the well-posedness of the problem and how to appropriately account for the Dirac delta and boundary conditions.
  • Participants discuss the possibility of integrating the equation and the implications of doing so, leading to an integral equation. There are mentions of solving the homogeneous part of the ODE and considering the behavior of the solution around the Dirac delta function, particularly the jump discontinuity at \(x=0\). Questions arise about how to determine constants in the solution and the behavior of the integral terms at infinity.
The conversation is ongoing, with various approaches being explored, including the integration of the equation and the implications of boundary conditions. Some participants suggest methods for addressing the jump discontinuity and the need for continuity in the function, while others express uncertainty about the constants involved in the solution. There is no explicit consensus yet, but several productive lines of reasoning have been proposed.
Participants note that the Dirac delta function introduces complexities in the solution, particularly at \(x=0\), and that the behavior of the function at infinity is also a critical aspect of the problem. There is an acknowledgment of the regularity of \(a(x)\) and its implications for the solution's behavior.
Gallo
I'm trying to solve the following equation (even if I'm not sure if it's well posed)
[tex]\partial_{x} \, y(x) + a(x)\, y(x) = \delta(x)[/tex]
with ##\quad \lim_{x \rightarrow \pm \infty}y(x) = 0##
It would be a classical first order ODE If it were not for the boundary conditions and the Dirac Delta. How should I take account of them?
One idea might be to integrate over x.
I'm not sure, what you meant...I would get some kind of integral equation ..
Right - often solutions will involve an integral of some sort.
Can you solve the homogeneous problem ## y_x + ay = 0?##
Then, for the dirac delta, you enforce continuity in the function at x=0, and a jump condition in the first derivative at x=0.
It is a classical ODE except for what must happen at x=0. y(x) must have a jump discontinuity at x=0 assuming a(x) is regular function. Just solve y'(x)+a(x)*y(x)=0 in the domains x>0 and x<0 and patch in the discontinuity.
Right...thanks Dick. Sorry for the error in my last post. First order ODE has jump in the 0th derivative, i.e. the function itself. I have been spending too much time in 2nd order problems.
Thanks, following your hint this is I would go:
if ##y_{\pm}## solve ##y'_{\pm}(x)+a(x)*y_{\pm}(x)=0## in ## \pm x> 0## then ##y_{\pm} = C_{\pm} \, e^{-A_{\pm}(x)} ## and a solution is given by
[tex]y(x) = y_{-}(x) + H(x) (u_{+}(x) - u_{-}(x))[/tex]
where
[tex]A_{+}(x) = \int_{0^{+}}^{x} a(z) dz[/tex]
[tex]A_{-}(x) = \int_{x}^{0^{-}} a(z) dz[/tex]
and ##H(x)## is the Heaviside step function.
Now I need a jump of one in 0, so I impose ##C_{+} - C_{-} = 1##
How do I fix the remaining constant? Moreover I guess that at infinity ##A_{\pm}(x)## has to blow up
where
I don't think you want to reverse the limits in your definition of ##A_{-}(x)##. But otherwise, I generally agree. I don't think you have enough information to fix the constants any better than that.
The Dirac delta right-hand-side is exactly what you would use when calculating a Green's Function. Since ##\delta(x) = 0## when ##x \neq 0##, you need ##y'(x) + a(x) y(x) = 0## for ##x < 0## and for ##x > 0##. If you integrate the de from ##-\epsilon## to ##+\epsilon##, you get
[tex]\int_{-\epsilon}^{+\epsilon} y'(x) \, dx + \int_{-\epsilon}^{+\epsilon} a(x) y(x) \, dx = 1.[/tex]
If ##y(x)## is bounded around ##x = 0##, the second term above vanishes in the limit ##\epsilon \to 0##, while the first term is ##y(+\epsilon) - y(-\epsilon)##, which approaches ##y(+0) - y(-0)## as ##\epsilon \to 0##. In other words, ##y(x)## has a jump discontinuity of magnitude 1 as ##x## passes from left to right through 0.
Thanks, that's what I thought!
