Is Axiom 2 a Special Case of Axiom 1 in Vector Spaces?
The discussion centers on the relationship between the axioms defining a vector space, specifically Axiom (1) λ·(μ·X) = (λμ)·X and Axiom (2) 1·X = X. The participant questions whether Axiom (2) can be derived from Axiom (1) by substituting λ and μ with 1, leading to the conclusion that Axiom (2) may not be necessary. However, the consensus is that Axiom (2) is independent and essential, as it asserts that every vector in the space can be represented in the form 1·X, which is not guaranteed by Axiom (1) alone. The flaw in the initial reasoning is clarified, emphasizing the necessity of Axiom (2) for the completeness of vector space definitions.
  • Understanding of vector space axioms
  • Familiarity with scalar multiplication in vector spaces
  • Knowledge of mathematical notation and operations
  • Basic concepts of surjectivity in functions
  • Study the properties of vector spaces in linear algebra
  • Explore the implications of scalar multiplication on vector spaces
  • Learn about surjective functions and their role in mathematical proofs
  • Investigate other axioms of vector spaces and their interdependencies
Mathematicians, students of linear algebra, and educators seeking a deeper understanding of vector space axioms and their implications.
cosmic dust
Hello, I'd like to make a, probably stupid, question regarding the axioms that define a vetor space. Among them, there are the axioms:
λ\cdot(μ\cdotX) = (λμ)\cdotΧ (1) and 1\cdotΧ=Χ (2)
for all λ,μ in the field and for all X in the vector space, where 1 is the identity of the multiplication on the field and "\cdot" indicates the multiplication of a scalar with a vector. So, my question is: can axiom (2) derived as a special case of (1) and, therefore, is not really an axiom?
I ask this because, setting λ = μ = 1 in (1), we get:
1\cdot(1\cdotX) = 1\cdotΧ
Since X is an abitrary vector, 1\cdotΧ will also be an arbitrary vector, say Y. Then the above equation reads:
1\cdotY = Y
for all Y in the vector space. But this is "axiom" (2)! I understand that, since both axioms are used in the standard definition of vector space, they should indeed be indepentend, despite the above objection. So what is the flaw in my thought about this?
As far as showing it for all vectors in the vector space, is it obvious that if I give you an arbitrary vector Y that you can find some vector X such that 1⋅X = Y?In fact here's a simple counterexample: Let my "vector space" be R2 with regular addition and with scalar multiplication defined by
\lambda(a,b) = (\lambda a, 0)
Let's check the other axioms. Since addition is untouched all the addition only axioms are still true. For scalar multiplication:
Distributivity:
(\lambda+\mu)(a,b) = \left( (\lambda+\mu)a,0 \right) = (\lambda a,0) + (\mu a, 0) = \lambda(a,b) + \mu(a,b)
Other distributivity:
\lambda\left( (a,b) + (c,d) \right) = \lambda(a+c,b+d) = (\lambda a+\lambda c, 0) = (\lambda a,0) + (\lambda c,0) = \lambda(a,b) + \lambda(c,d)
Associativity of multiplication:
\mu \left( \lambda(a,b) \right) = \mu (\lambda a, 0) = (\mu \lambda a, 0) = \left( \mu \lambda \right) (a,b)
So great! We have ourselves a good ol' fashion vector space
1\cdotY = Y
The flaw is that Y is not an arbitrary vector in the space. It is a member of the subset of the vector space that can be expressed as 1 \cdot X, where X is some member of the vector space. What axiom (2) adds is that it says all members of of the vector space can be expressed in this form, and in particular, 1 \cdot X = X.
So, that would be true if the function:
1\cdot : V→V , 1\cdot:X→1\cdotX
is surjective? But this is an extra axiom, more complicated than it's substitute (that is (2)). Better keep (2) as it is... :smile:
Thank's for your replies!
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 26 ·
