High School Is Understanding 'dx' Just a Heuristic in Calculus?
  • Thread starter Thread starter archaic
    Calculus Dx
The discussion centers on the interpretation of the differential notation 'dx' in calculus, particularly in the context of Riemann integration. Participants argue that while 'dx' represents an infinitesimally small change in 'x', it should not be treated as an independent entity but rather as part of a limit process. The equation L = α.dx is deemed meaningless, as it misrepresents the nature of real numbers and their distances. The conversation emphasizes the importance of distinguishing between finite changes (Δx) and differentials (dx) for a proper understanding of calculus.
  • Understanding of Riemann integration
  • Familiarity with the concept of limits in calculus
  • Knowledge of real number properties
  • Basic understanding of differentials and their notation
  • Study the properties of Riemann integrals and their limitations
  • Learn about measure theory and Lebesgue integrals for a deeper understanding of integration
  • Explore the differences between differentials (dx) and finite changes (Δx)
  • Examine the role of differentials in vector analysis and differential forms
Mathematics students, educators, and anyone seeking to deepen their understanding of calculus, particularly in the areas of integration and the interpretation of infinitesimals.
archaic
Hello!
Let ##I## be an interval of size ##L##, suppose we divide it into bits of ##dx## then ##L=dx+dx+... =\alpha.dx##
Since ##dx## is by definition infinitesimally small is it correct to imply that for each ##x## there's a corresponding ##dx## hence, here, ##\alpha## would be, theoretically, the total number of ##x##s?
Because, as I see it, that's how the average value of a function is calculated :
$$\frac{\sum{f(x)}}{\alpha} = \frac{1}{L}.\sum{f(x).dx} = \frac{1}{L}. \int f(x).dx$$
$${1 \over L} \int f(x)\ dx$$
The integral is the area, you always want to remember that. The area divided by the length of the interval is the average height.
I don't think you will find a book that says there are ##\alpha## many ##f(x)\ dx##'s. There are uncountably many, too many to ever count.
Hence the "theoretically", I think the logic I used is quite sound, and it's just like the concept of the integral, you add the area of a bunch of rectangles of width ##dx## and that would give you the area under the curve ##\Leftrightarrow## for each rectangle of height ##f(x)##, i.e for each ##x##, we assign a width ##dx## which seems like saying that for each ##x## there's a corresponding ##dx##.
Your imagination might be o.k. for a physicist and a while, i.e. as long as ##dx## doesn't become a basis vector or linear form; for a mathematician it is misleading, since it indicates an entire procedure of a limit, i.e. it is always a context sensitive abbreviation of something more general and as such should not be treated as an independent entity.
A comment on notation:
I don't think that there is any official notation convention. I normally interprite ##dx## as an infinitely small change in ##x##. When I want to indicate an arbitrarily small, but not infinitely small, change in ##x##, I would use ##\Delta x##. In any case, it is sometimes important to distinguish between the two concepts.
I'll restate the question differently :
With the integral, the concept is to sum up the area of rectangles of height ##f(x)## and width ##dx##. Considering that the area under the curve covers up all ##x##s then is it safe to assume that, since each all ##f(x)##s possible (theoretically) are being used in the calculation of the area under the curve, the sum of all ##dx##s is equal to the interval on which we're applying the integral, i.e if ##L## is the length of that interval, is ##L = \alpha.dx## a safe assumption?
Because explaining the average value formula with what I'm saying seems logical; average = sum of everything / how many is everything.
My approach to this is that ##\Delta x## indicates a (small) change in ##x## and ##dx## is notationally used in the limit as ##\Delta x \rightarrow 0##. In a sum, you are always summing with respect to ##\Delta x##; and, the ##dx## makes its appearance in a integral, which is defined as the limit of these sums.
In particular, ##L = \alpha dx## has no meaning.
##dx## can also have a meaning as a "differential", which is discussed here:
http://tutorial.math.lamar.edu/Classes/CalcI/Differentials.aspx
In any case, it is essential that you distinguish between the finite quantity ##\Delta x## and the differential ##dx##.
Likes FactChecker
I, in fact, do distinguish between the two.
It's just that the ##L = \alpha.dx## seems logical to me.
If ##\int f(x).dx =## area under the curve then it follows that we calculated the area formed by each point ##x## of the interval, hence, somehow, I see it as though for each ##x## there's a corresponding ##dx##, i.e as if there's this imaginary space between two neighboring ##x##s (even if numbers are infinite, it's just a supposition) of length ##dx = x_2 - x_1## with, in some sens, ##x2## and ##x1## atom like real numbers and that difference between them is some kind of microscopic indivisible distance.
Unfortunately, this is not the way the mathematics of the Riemann integral works.
Within the Real numbers, there is no no such thing as "neighboring" points. Any two points have a finite distance between them, and an (uncountable) infinity of other points between them.
If you want to understand Real Analysis, you will need to revise your ideas about the real number line.
Let ##F'(x) = f(x)## and ##dx = g(t)\ dt##. Then: $$\int dF = \int f(x)\ dx = \int f(x(t))\ g(t)\ dt$$ The first step is justified because ##dF = f(x)\ dx##. How would you apply your theory to this?
Of course I know that.
He explains it better than me (in the context of ##\bar{f}##) :
https://image.noelshack.com/fichiers/2018/37/6/1537028762-eza.png
That last sentence is interesting. I would suggest that the following is better:
"Now take the limit as ##\Delta t \rightarrow 0## and you get the integral."
excuse me I don't have an answer
Keep learning and don't worry about what the stuff means. Later you'll figure it out.
Likes fresh_42
It is the differential of ##x##. If you are asking for a definition - a differential is 'vanishingly small'. There you go. You can also have something like ##\int g(t) d(f(t)) = \int g(t)f'(t)dt ##. If you start thinking what the **** ##dx## means ..you won't get very far. Riemann integrals are evil. Learn measure theory and Lebesgue(-Stieltjes) integrals at your earliest convenience and everything becomes much clearer, none of this infinitesimally small mumbo jumbo.
You can also view it as a differential form (vector analysis) - it represents some tiny tiny tiny piece of a curve or something.
The differential business happens to be very useful at least as a heuristic. So, don't take it for more than a heuristic and don't try to get too rigorous.
Reminds me of a quote by, I think it's von Neumann's: you don't understand it, you just get used to it.
Likes archaic
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 38 ·
