hey123a said:
Oh east of north, so what i did in my calculation was north of east?
would i still get a right answer if did 90-38 = 52 degrees to have the y component opposite to the angle
Yes you would - but why would you bother?
Why your strong desire for the y component to be a sine - eventually (like here) you are going to get it backwards and get it wrong.
My approach is to work out both components - you often need them both anyway - then do a quick sketch - ensuring that if an angle is less than 45 degrees make sure it is sketched as such (better to make it too small than too big.
From the sketch you can see whether you want the smaller or larger component, and so just select the smaller or larger one as appropriate.
ie. don't spend time deciding whether you should be using sin or cos, concentrate on whether you want the small component or the large component.
example: a projectile is fired at 200m/s at an angle of 60 degrees to the horizontal - what is the vertical component of its initial velocity.
ans: the two components are 200.sin60 and 200.cos60 or 173.2m/s and 100 m/s
A quick sketch (perhaps just an imagined sketch) shows that the projectile is traveling faster up than horizontally, so the vertical component must be 173.2 m/s
compare that to: a cannonball is fired at 200m/s at an angle of 60 degrees to the vertical - what is the vertical component of its initial velocity.
A quick sketch (perhaps just an imagined sketch) shows that the projectile is traveling faster horizontally than vertically, so the vertical component must be 100 m/s
