One dimensional Kinematics help
An elevator accelerates upward at 4.0 ft/s², and a bolt drops from a height of 9.0 ft when the elevator's speed is 8.0 ft/s. The equations for the bolt's motion and the elevator's floor were set equal to find the time of flight, which was calculated to be 1.14 seconds. However, a discrepancy arose regarding the value of gravitational acceleration used, as the problem requires imperial units rather than metric. Additionally, the reference point for the y-coordinate should be adjusted to where the elevator reaches 8 ft/s, not the bottom of the shaft. Proper unit management is essential to avoid such errors in calculations.
toesockshoe
2. An elevator ascends with an upward acceleration of 4.0 ft/s2. At the instant its upward speed is 8.0 ft/s, a loose bolt drops from the ceiling of the elevator 9.0 ft from the floor. Calculate:
a. the time of flight of the bolt from ceiling to floor.
b. the distance it has fallen relative to the elevator shaft.
y=yinitial+vt+1/2at2
assuming that elevator starts at bottom of shaft and y=0 is at bottom of shaft.
a) y value of bolt has to equal the y value of the elevator.
BOLT EQUATION:
y = 9+8t-(1/2)gt^2
FLOOR OF ELEVATOR EQUATION:
y=8t+2t^2
set bolt and floor equation equal to each other to get t = 1.14 seconds.
b) delta y of bolt respect to shaft = 8t -1/2gt^2
plug in 1.14 for t to get 2.75 meter increase?
please tell me if i am going wrong and where...
toesockshoe said:
BOLT EQUATION:
y = 9+8t-(1/2)gt^2
y=8t+2t^2
Looks right so far..
toesockshoe said:
t = 1.14 seconds
Too long. Did you try substituting this back in both equations as a check?
are you sure its wrong? i double checked the arithmetic and i found it correct. i also plugged the numbers back into both equations, and they are equal.
Something seems off. What value are you using for g? The problem uses imperial units but in part b) you give the answer in metric.
The other catch is that in part a) you define the distance y=0 to be the bottom of the shaft. But clearly it must have traveled some distance first before reaching the speed of 8ft/s. So I would redefine y=0 to be the point at which the elevator reaches 8 ft/s.
yeah dang. i was using 9.8. my bad...
My suggestion is to get into the habit of always, always plug in the units along with the numbers. You can catch lots of mistakes this way.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
13K
  • · Replies 18 ·
