One dimensional problems. More particles.
5 replies · 2K views · last reply
LagrangeEuler
If I have one dimensional problem with many particles that are all in same ##|\psi\rangle## state is it equal to one dimensional problem of one particle in state ##|\psi\rangle##.
If I have for example 50 particles in some state ##\psi(x)## in infinite potential well and that state is symmetric around ##\frac{a}{2}## such that ##\int^{\frac{a}{2}}_0|\psi(x)|^2dx=\frac{1}{2}##. Is in that case true statement that ##25## particles are in the region ##0<x<\frac{a}{2}## and 25 are in the region ##\frac{a}{2}<x<a##?
I would say not. The average may be 25 on each side though.
Think about the classical case. 50 particles, each independently with probability 1/2 to be on the left, probability 1/2 to be on the right. How many do you expect to find on each side? Hint: can you say "binomial distribution"? :wink:
The quantum case is no different.
My question is if I have coin, probability to get head is ##\frac{1}{2}##. If I throw the coin 100 times I could get for example 60 times head. Then in this case is it possible that ##60## particles be in the region ##0<x<\frac{a}{2}## and 40 in the region ##\frac{a}{2}<x<a##?
You need to count all the permutations which are the same, hence use the binomial distribution.
Yes, this is certainly possible.
