Op-Amp basic problem with a LED diode
  • Thread starter Thread starter Femme_physics
    Diode Led Op-amp
89 replies · 12K views
Ah, okay.
I was also wondering what the question of the problem was, since it was missing from your OP.
Ah, was it? Heh, my bad... :blushing: :oops:
Which resistor is RL?
In your diagram you have 2 of them, one of 2 kOhm, and one of 1 kOhm.
Well, I've made a mistake in my last sketch drawing 2 resistors called RL. One of them shouldn't be there. Here's the corrected version with me pointing out the RL.
http://img839.imageshack.us/img839/4700/therez.jpg
FULL correction
http://img194.imageshack.us/img194/3141/dd750full.jpg
And if I read your IL correctly, it is in micro-ampere.
Is that intended?
That's mili-ampere.
Oh there it is (x)! :-p
Femme_physics said:
FULL correction
That's mili-ampere.
Looks good now, except for the micro-ampere, or if that is an "M", the mega-ampere.
An "m" should have round caps!
Just like a pi should have nice legs when you use it!
Well according to this it's just mA
http://www.convertunits.com/info/mili+ampere
Oh, and wait!
You used Vin, Vout, Rin, and Rf in your calculations, but they are not in your drawing!
Nor do you explain why and how you use them.
Vin = V1
Rf = R2
Rin = R1
Vout = well it doesn't really equal anything. it's just Vout :P
Well it looks like either μA or MA, but is should be mA.
Notice how round it looks (also in your link)?
Femme_physics said:
Vin = V1
Rf = R2
Rin = R1
I know! But you should put something like that in your calculation.
Femme_physics said:
I'll just fix the mA later... :) forgot
Now if you'd only add Vout to your drawing (and preferably Vin too), you're set!
(Since Vout still drops from out of the air now.)
Edit: You might even mention it's a non-inverting amplifier. That would make a grand impression!
Oh, and while you're at it, perhaps you can prettify my little milli...
Now it truly looks like micro (μ or u)!
Do you want to make me cry? :cry:
And apparently you forgot the second time.
Oh, and I just noticed.
At the top you write "RL = ?".
But you already know RL. I think you meant "ILS = ?".
Ah, ok ok! Got it now :wink:
http://img580.imageshack.us/img580/8129/finalfixe.jpg
Femme_physics said:
Good :smile: :wink:
Thanks a bunch!
So now I could move on to my next exercise...think I'll keep it with this thread. Does it all look right? I got to find Vout when the switch is in state 1 and when it's in state 2
http://img36.imageshack.us/img36/1464/blackblacke.jpg
Not quite.
First, I get a different value for V+ (only by a little).
And I believe it's not in mV, but in V.
(Nice "m" by the way! :smile:)
Then you need to know that the real response of an op-amp is given by:
Vout = (V+ - V-) AOL
where AOL is literally "a zillion", but if you want, you can substitute "a million".
You should substitute this in your formula.
There is one catch.
If Vout becomes to high or too low, the op-amp is "saturated".
So Vout can never become higher that the positive voltage supply.
And Vout can never become lower than the negative voltage supply.
In practice this means that if V+ is higher than V-, then Vout is the positive power supply.
And if V+ is lower than V-, then Vout is the negative power supply.
Btw, how is it that you still have access to the scanner?
Still? I'm at home. Dad's napping. I ain't bothering him. :)
Not quite.
(Nice "m" by the way! )
hehe. had to do a last minute fix-up!
Well, you're right, I got a different result too. V = 5.5263V
I guess I must've mistyped something in the calculator the first time. I should've known that result doesn't make sense.
Is that the only mistake?
There is one catch.
Oh yea, I remember that!
Got it! :smile:
Okay, I just remember that at other times you could not get to the scanner any more...
That's the only calculation error.
But your answers are wrong due to my other remark.
Got it! :smile:
Got it? Then what's your conclusion?
Hmm...yea you're right. Oh! That's because we moved the scanner and stationary PC to the livingroom, so I'm not bothering anyone here much. Heh, yea, I forgot! I couldn't use the scanner back then... damn, good old days :smile:
But my Vout results don't exceed the 7.8V I see signified on the op-amp.
I've got a couple of good memories and pictures from those days. ;)
That's because you did not calculate Vout properly.
Try: [itex]V_{out} = (V_+ - V_-) \times 1000000[/itex].
I don't have have that formula you just gave me on my chart.
Hmm, maybe you can help me with something before I continue to solve it. I want to make a proper list of the op-amp formulas I need. Do you think that's enough?
http://img27.imageshack.us/img27/9494/forform.jpg
Here's the corresponding wiki page that I recommend:
http://en.wikipedia.org/wiki/Operational_amplifier_applications
It has really nice pictures, a nice overview, and pretty formulas.
I recommend adding the Comparator (the first one, which you would use for the problem at hand).
You probably won't need the others.
And the formula I gave, is the one formula that exactly describes the behavior of an op-amp (up to saturation).
All the other formulas can be derived from that one.
Btw, this is the first time that we've been up so late! ;)
Any particular occasion?
http://en.wikipedia.org/wiki/Operati...r_applications
Great link! will do. Appears to have everything I need.
Will do as well.
You mean this?[itex]V_{out} = (V_+ - V_-) \times 1000000[/itex]
Oh, sorry, I missed the question :smile: No, just got into a solving shvoong! Can't stop! Should I?
Certainly not!
I like it!
Anyway, I have an hour on you and I don't have to work tomorrow.
(Don't you?)
I do actually, and starting to feel kinda tired. Will continue this tomorrow, hopefully. Thank you Klaas!
And I love it!
G'night for now :)
Femme_physics said:
So, I think I finally got it :)
Yep. That's it... only one problem... the power supply of the op-amp can not yield so many volts. ;)
Femme_physics said:
EDIT: In the wiki article you linked me, there's no reference for the formula of the voltage gain of a non-inverter op-amp. Should we add it?
No reference? Isn't it already there in the 3rd circuit application (Non-inverting amplifier)?
Yeah, otherwise we should add it!
Yea, I didn't thought that made much sense...otherwise one amplifier and I could run this entire world!
So, what did I do wrong?
Think we should too! But I already added it to my own notes and that's what matters :) thanks.
In the diagram you can see that the op-amp has a positive and negative power supply.
Vout is capped between those 2.
The op-amp is saturated then.
