Opening Files in Python - Newbie Question
  • Topic: Python
  • Thread starter Thread starter zeion
    Python
4 replies · 2K views
zeion
Hi, this might be silly but I'm not sure what the syntax is for the read function...
I'm trying to open a file on my desktop, it is a text file called testfile.txt, how do I make python know where to find it?
I go:
f = open('C:\Users\Truman\Desktop\testfile.txt', 'r')
or
f = open('testfile.txt', 'r')
but neither works.
Does the file need to be in the same directory as where I installed Python?
Thanks.
Code:
f = open(filename, mode)
should work if you specify the file path.
Are you getting an IOError? Also, if you directly use the file() constructor, can you open the file?
Ok I realized I couldn't open the file in IDLE.. but only with the actual program.
Either use double backslashes, '\\', or single forward slashes, '/'. Otherwise you have characters like '\t', which is the tab character, embedded in your filename.
Wow...it's been so long since I've used Python on Windows that I forgot about that.
