Operator in Quantum Mechanics: Bra & Ket Reordering?
  • Thread starter Thread starter Niles
    Qm
The discussion revolves around the manipulation of operators in quantum mechanics, specifically focusing on the reordering of bra and ket vectors within an operator expression. The original poster presents a question regarding the validity of moving bra and ket vectors in a given operator formulation.
  • Participants explore the implications of moving bra and ket vectors, questioning whether such manipulations are mathematically valid. Some express confusion about the nature of inner and outer products and the significance of indexing in the context of operators.
The discussion is ongoing, with various perspectives being shared. Some participants emphasize the importance of treating bras and kets as vectors in Hilbert space and caution against assuming they can be interchanged freely. Others provide insights into the implications of matrix multiplication and the non-commutative nature of operator algebra.
There is a noted ambiguity regarding the notation and the interpretation of summations involving bras and kets, which may lead to misunderstandings about their mathematical properties. Participants are also reflecting on the implications of using indices in this context.
Niles
Hi all.
An operator is given by:
<br /> \widehat O = \sum\limits_i {\sum\limits_j {O_{ij} \left| {\psi _i } \right\rangle \left\langle {\psi _j } \right|} } <br />
Am I allowed to move the bra and the ket around to achieve the following?
<br /> \widehat O = \sum\limits_i {\sum\limits_j {O_{ij} \left\langle {\psi _j } \right|\left| {\psi _i } \right\rangle } }.<br />
Thanks in advance.Niles.
It looks a little odd. As long you know that
isn't an inner product.
Usually written
\widehat O = \left\langle {\psi _j } \right| {O_{ji} \left| {\psi _i } \right\rangle
or without indices
\widehat O = \left\langle {\psi} \right| O \left| {\psi} \right\rangle\ .
What do you mean by "contract"? And in general, is it allowed to interchange bra's and ket's as one wishes?
Thanks for replying.
Ok, I see that you changed your post. I thought that a bra and a ket gave an inner product? Why is it not like that in this case?
Yeah, bad terminology on my part, sorry.
I was a little uncertain, before, because I hadn't seen others use indexing on bras, kets, and operators before.
Without getting too technical, A ket is a column vector and a bra is a row vector in matrix notation.
In matrix notation, a row vector times column vector is a scalar.
Also, a column vector times a row vector is a matrix.
As soon as you add the subscripts, the notational meaning changes, and the associative properties of matrix multiplication no longer hold--because the elements are no longer maxrices. With the indices, the objects in question are really the elements of matrices, bras and kets.
For matrices, in general, \ AB \neq BA \, \ \ \ ABC \neq ACB \neq BAC \, etc.
\ C=AB \ in matrices is the same as \ C_{ik} \sum\limits_j {A_{ij} B_{jk} }
The columns of A are multiplied by the rows of B.
With indexing, the order doesn't matter, the indexing overrides the matrix multiplication rules. With indexing the result is the same, no matter the ordering. The summation takes care of that.
C_{ik} = \sum\limits_j {A_{ij} B_{jk} }
C_{ik} = \sum\limits_j {B_{jk} A_{ij} }
This holds, for matrices and kets.
\left| U \right&gt; = A \left| V \right&gt;
\left| U_{i} \right&gt; = \sum\limits_j { A_{ij} \left| V_{j} \right&gt; }
\left| U_{i} \right&gt; = \sum\limits_j { \left| V_{j} \right&gt; A_{ij} }
And matrices and bras.
\left&lt; U \right| = \left&lt; V \right| } A \
\left&lt; U_{j} \right| = \sum\limits_i { \left&lt; V_{i} \right| A_{ij} }
\left&lt; U_{j} \right| = \sum\limits_i { A_{ij} \left&lt; V_{i} \right| }
The inner product of a bra and a ket is a scalar.
S = \left&lt; U \right| \left| V \right&gt;
\left| N = \sum\limits_i { \left&lt; U_{i} \right| \left| V_{i} \right&gt; }
\left| N = \sum\limits_i { \left| V_{i} \right&gt; \left&lt; U_{i} \right|}
This last equation is not the same as \ W = \left| V \right&gt; \left&lt; U \right| !
And finally the inner product of a ket and bra is a matrix of some sort--not a quantum mechanical operator--but a product space.
W = \left| U \right&gt; \left&lt; V \right| }
\left| W_{ij} = \left| U_{i} \right&gt; \left&lt; V_{j} \right|
\left| W_{ij} = \left&lt; V_{j} \right| \left| U_{i} \right&gt;
Hope this helps.
I am a little uncertain of why the following is true:
<br /> \left| N = \sum\limits_i { \left&lt; U_{i} \right| \left| V_{i} \right&gt; } = \sum\limits_i { \left| V_{i} \right&gt; \left&lt; U_{i} \right|}.<br />
The first part is the sum of some scalars, so N is a number. Then we sum over outer products, which you say is a scalar as well?
The rest is very good!
Thanks in advance.
I strongly doubt whether you can do that...
Think about it purely in mathematical sense. Ket vector is a column vector (n x 1 vector) while bra vector is a row vector. (1 x n vector) Usually operators are n x n square matrix, so if you have a \left&lt; U_{i} \right|\hat Q \left| V_{i} \right&gt;, you end up with a scalar value while \left| V_{i} \right&gt;| \hat Q |\left&lt; U_{i} \right| results in a matrix . The former is the inner product, and the latter is the outer product. They are different things, of course. In your case, you are given:
\left| V_{i} \right&gt;\left&lt; U_{i} \right|
which is, essentially a matrix, and your desired goal is:
\left&lt; U_{i} \right|\left| V_{i} \right&gt;
which is a scalar. So if you stick a test bra in front and test ket after the operator, you'd get a product of two inner products in the given situation, while the other one will give you a scalar multiple of the inner products between test vectors. They cannot be the same in general. Also... if you have:
<br /> <br /> \left|U\right&gt; = \sum\limits_i {A_{i} \left|U_{i}\right&gt; }
Then...
<br /> \left&lt;U\right| = (\left|U\right&gt;)^+ = \sum\limits_i {A_{i}^*\left&lt;U_{i}\right|}
Niles said:
Hi all.
Thanks in advance.
Niles.
No, you are not allowed to do that, and I think some of the earlier replies gave you bad advice. You are never allowed to assume any bra or ket is an ordinary number. They must always be considered vectors in Hilbert space, and the notation is a way of denoting abstract matrix algebra, where multiplication is NOT commutative. The products
\langle \psi | \phi \rangle
and
| \psi \rangle \langle \phi |
give completely different objects! The first is a scalar, while the second is a matrix. They cannot be used interchangeably.
The expression
\hat O = \sum_{m,n} O_{mn} |m \rangle \langle n|
is just the expansion of O in some basis |m \rangle. When plugged into an inner product, it means this:
\langle \phi | \hat O | \psi \rangle = \sum_{m,n} \langle \phi | O_{mn} |m \rangle \langle n| \psi \rangle
= \sum_{m,n} O_{mn} \langle m | \phi \rangle^* \langle n| \psi \rangle
which is now finally the sum of products of ordinary scalars.
Great, I guess that is the definitive answer to my question. Thanks for replying.
And thanks to all for participating. I really appreciate your help.
and
That was, of course, one of the points I was making. But you've missed the entire issue of the ambiguity that arises with an explicit summation, which nullifies the advantage of using bra ket notation in the first place.
Of course, doing this
\sum\limits_i { \left| v_{i} \right&gt; \left&lt; u_{i} \right|} \ ,
should be avoided. Either it results in a scalar, or it's meaningless.
Huh? What's ambiguous? That looks like a perfectly meaningful expression to me -- the summand expresses a linear operator, a type of object for which addition (and thus finite summation) is well-defined. Even infinite-summation can be defined if you include a notion of convergence.
Which is it then? Do you want to operate the ket on the bra and then take the summation, or the other way around?
Phrak said:
Which is it then? Do you want to operate the bra on the ket and then take the summation, or the other way around?
The one that is usually specified by such an expression. If the u's and v's represent real numbers, there is no ambiguity in \sum_i v_i u_i, is there? The semantics here is exactly the same: for each i, you multiply the ket and bra to get a linear operator, and then sum the resulting operators.
I don't think any other reading could make sense, because both the ket and bra involve the index of summation...
Yes, yes. I should have said confusing rather than ambiguous. So what's your answer to Niles' question?
My answer would have been "no", since {bra}*{ket} is (AFAIK) always used to represent the 'inner product', so the two expressions are of different types, so they couldn't possibly be equal, even by chance. I've never seen {bra}*{ket} used to represent a linear functional like you suggested, but that is yet another type of object.
Such a thing is quite awkward to write, but I would expect some other notation to be used. If someone insisted on keeping the notation as similar as possible, I would expect something like \langle \psi_i \mid \_\_ \mid \psi_j \rangle with a underscore or dash to emphasize that there is a place to plug in something, rather than just expressing a product of the bra with the ket.
Ah, now that I think of it, the notation I would expect to actually see is the trace. What you express as the result of plugging an operator T into the expression \langle \psi_i \mid \mid \psi_j \rangle, I would expect to see as \mathrm{Tr}\left( \mid \psi_j \rangle \langle \psi_i \mid T \right).
... That's not to be avoided...
It's called "Projection Operator", with
\sum\limits_n { \left| n \right&gt; \left&lt; n \right|} \ = \hat 1,
where \{ \left | n \right &gt; | n = 1, 2, 3... \} represents orthonormal basis, and \hat 1 represents an identity matrix...
I know this is bad banter; don't use apostrophes to pluralise!
is there always a "bra" for a "ket"? Can u please justify?
thanking you.
  • · Replies 21 ·
