Operator mapping in Hilbert space
35 replies · 5K views · last reply
SeM
Hi, I have an operator given by the expression:
L = (d/dx +ia) where a is some constant. Applying this on x, gives a result in the subspace C and R. Can I safely conclude that the operator L can be given as:
\begin{equation}
L: \mathcal{H} \rightarrow \mathcal{H}
\end{equation}
where H is Hilbert space, with subspaces C and R ?
I think you have a confusion of ideas here. I'm not sure where the subspaces come into it.
I thought C and R , being complex and real, are both subspace to the entire space H, composed of R and C. Disregarding the term "subspace", does this look reasonable?
The reason I am not sure is because the projection of L on x (which can be any real value) goes from R to R and C. Is this generalized form right?
\begin{equation}
L : \mathcal{H} \rightarrow \mathcal{H}
\end{equation}
The reason I am not sure is whether the projection of L on x, being from x (which can be any real value) onto R and C, is correctly given by the form:
\begin{equation}
\end{equation}
What Hilbert space are we talking about here?
Lx, where x are real values.
L is doing something to z, it is transforming it to 1 +i ax. If x is in R, and R is Hilbert space, then Lx is R and C, still Hilbert space?
Sorry, none of that makes much sense. If ##L## is a differential operator it must be acting on functions, not on real or complex numbers.
SeM said:
It is acting on a function y(x) = x. It is written above
In that case, as you have defined it, we have:
##Lx = iax +1##
Which is another function.
So, iax+1 and x are both two functions , respectively in C and R and in R. What can one say about this, in a Hilbert space?
But you've written something with the variable ##x##, then ##z## and now ##y##. Can you just say, which spaces you're talking about? Perhaps with a complete example.
There is nothing exotic about Hilbert spaces and examples are many. So again:
Me neither.
No, in this context ##\mathbb{C}## and ##\mathbb{R}## are fields of scalars. They are not subspaces of a Hilbert Space of functions.
I have this operator, L, and I Have to explain what it does in a Hilbert space on two other operators, the position operator x, and the momentum operator d/dx.
In Kreyszig Functional Analaysis it says:
Let T: H -> H be a bounded inear operator on a complex Hilbert space H.
How does this NOT apply on L? Can't I write:
L: H -> H ?
L: H -> H ?
Your grasp of the material is such that it is difficult to follow what you are asking.
Have you jumped into a functional analysis text on a digression from QM?
I don't think it is a digression indeed. QM and Hilbert spaces go hand in hand. I have to analyze an operator for its properties in a Hilbert space, and its commutation with other operators. The latter is OK. The former, I am not sure.
If the Operator L is acting on say the position operator x, and it is composed of d/dx + ia, what can one say about this operator in a Hilbert space? And please answer at least something instead of asking me more questions, if possible.
Thanks
Thanks
A study of pure functional analysis requires considerable mathematical prerequisites. And, although QM relies on Hilbert Spaces, the mathematical treatment of Hilbert Spaces goes much deeper than is required for an initial study of QM.
In this case, you are confused by the concepts of operators acting on functions in your Hilbert space and operators being combined through functional composition.
I believe you have jumped in the mathematical deep end here.
Your question might be:
What is the commutator of ##L## and ##\hat{x}##?
L: H -> H ?
Are you trying do do a particular problem in Kreysyzig? If so, which one?
Echoing PeroK;
As functional analysis books go, Kreyszig (my text as a student long before my beard turned white) requires less mathematical prerequisites (e.g., no measure theory or topology) and is more pedagogical than most other functional analysis texts, but even it requires a dose of mathematical sophistication that is administered through material like elementary real analysis.
Quantum mechanics can provide motivation to learn a bit of functional analysis for interest's sake, but the functional analysis does not often help with quantum mechanics, and can actually hinder one's progress in quantum mechanics, i.e., the rigour gained can cause rigour mortis to set in.
Personal digression: Kreyszig's son was a fellow student in a numerical analysis course that I took.
Hi Perok, I have investigated the commutation algebra, and it is fine. I found out , as another post I put on the QM section, that this operator has more algebraic combinations with the imaginary position operator, ix, which is what you write here?
This goes a little bit out of the scope of the project. My project is simply to answer the very general request by the tutor:
"The set up of the Hamiltonian requires a proper set up (i.e. Hilbert space etc)". Can you imagine now, why I am am confused?
I'm confused! In any case, I don't understand what question you are asking.
Me neither, because I don't understand the tutor's request, and he doesn't want to specify more...
Specifically he says " "The set up of the Hamitonian requires a proper set up (Hilbert space, etc). Since the student does not motivate a concrete system in which the newly proposed Hamiltonian could be explored, this point is crucial."
No, I am using Kreyszig Operator Algebra to list up the properties of an own operator. I have gone through the commutation algebra. However, when I try to show the operator's properties in a Hilbert space, I am not sure my proof shows that the operator is applicable (or acting) in a Hilbert space. How does one prove that an operator can transform a function, say f= e^ipx in a Hilbert space, even though it is evident from doing a simple operation with it on f?
Dear Perok, why did you bring in the hat operator? Is it because of the mapping of L: H-> H ? Sorry, but much of this is new to me.
I'm sure something must be lost in translation here. In any case, this statement is not a question or problem that I can help you with.
Note that I used ##\hat{x}## as the position operator, to distinguish it from a point ##x## or the function ##f(x) = x##.
You need to talk to your tutor and straighten out what exactly it is that he wants you to learn.
Thanks for the clarification. Yes, this and the momentum operators have been clarified already for commutation. All well!
Well, if ##x## lives in the set of real numbers, then ##e^{ipx}## does not live in the standard Hilbert space of (equivalence classes of) square-integrable functions. Restricting ##x## (i.e., the domain of the functions) to the bounded interval ##\left[a , b\right]## seems to help, but, in this case, the momentum operator is unbounded (see page 569). Then, by page 525, a self-adjoint moment momentum operator can't have the Hilbert space all the square-integrable functions on ##\left[a , b\right]## as its domain. Done "properly", this stuff is quite subtle.
This is what I was hoping for! Thanks! I will give this a thought for a few days.
PS: The restriction to L^2[a,b] works for the operator, and that makes it Hilbert space. If the wavefunction is completely different from the given, and is hermitian, and it normalizes to 1 in the interval a b, then both the Operator and the hermitian solution are all in the Hilbert space, right?
PS: George, does this mean that any solution to a Hamiltonian in a Hilbert space must be continuous and square-integrable and must satisfy ALL the fundamental prescriptions of quantum mechanics, or just the two mentioned here?
A second thing: A Hamitlonian transforms a wavefunction to give a result, whether it is the energy in the Schrödinger eqn, or some other solution. That function is transformed by a i.e derivation. If the Hamiltonian (L) is deriving a wavefunction, and that wavefunction is hermitian, does it automatically mean that L is projecting the wavefunction into its derivative (in the same space)? So L: H-> H , where the wfn is in H before and after the operation? Is the plain and simple confirmation of the action of an operator in Hilbert space?
PS: Being entirely frank, I need to clarify a thing. What does this really mean?
\begin{equation}
\end{equation}
I thought it means that an operator L is doing some operation on some function in Hilbert space H, and its product is still in Hilbert space. For instance, a square integrable function is operated on, and it yields a second square-integrable function, where both, before and after the arrow, are in Hilbert space?
Thanks!
\begin{equation}
\end{equation}
Thanks!
Yes, that's what it means. It's really just the definition of a function, ##L##, from a set ##\mathcal{H}## to itself (*).
Note that ##\mathcal{H}## is the Hilbert space (in this case of square integrable functions).
But, you know, if you need to ask these questions, you need a crash course in pure mathematics before you dive into functional analysis.
(*) Note that mathematically unless you specify more, then that is all it means. However, in this case there are probably other statements like:
Let ##L## be a linear operator. Or let ##L## be defined by ... etc.
