Optimization problems from Yahoo Answers
  • Topic:
  • Thread starter Thread starter MarkFL
    Optimization
3 replies · 7K views · last reply
MarkFL
MHB
Here are the questions:
What is the function and answer to these optimization questions?
1. A piece of wire 40 cm long is to be cut into two pieces. One will be bent to form a circle; the other will be bent to form a square. Find the lengths of the two pieces that cause the sum of the area of the circle and the area of a square to be a minimum.
2. A manufacturer wants to design an open box having a square base and a surface area of 108 square inches. What dimensions will produce a box with maximum value?
3. The concentration in mg/cm^3, of a particular drug in a patient's bloodstream is given by the formula C(t) = (0.12t) / (t^2+2t+2), where t represents the number of hours after the drug is taken.
a) Find the maximum concentration on the interval 0<=t<=4.
b) Determine when the maximum concentration occurs
I have posted a link to this topic so the OP can see my work.
Re: ?'s questions at Yahoo Answers regarding optimization
Hello ?,
1.) A piece of wire 40 cm long is to be cut into two pieces. One will be bent to form a circle; the other will be bent to form a square. Find the lengths of the two pieces that cause the sum of the area of the circle and the area of a square to be a minimum.
Let's let the length of the wire be $0<L$, and the let $0\le S$ be the portion of the wire used to form the square, and let the portion of the wire that is the circumference of the circle be $0\le C$
Each side of the square will be $\dfrac{S}{4}$, and so the area of the square is:
$$A_S=\left(\frac{S}{4} \right)^2=\frac{S^2}{16}$$
The area of the circle is:
$$ A_C=\pi r^2$$
Now, the circumference of the circle is $C$ and so the radius of the circle is:
$$r=\frac{C}{2\pi}$$
hence the area of the circle in terms of $C$ is:
$$A_C=\pi\left(\frac{C}{2\pi} \right)^2=\frac{C^2}{4\pi}$$
Adding the two areas, we find the total area of the two shapes is:
$$A=A_S+A_C=\frac{S^2}{16}+\frac{C^2}{4\pi}$$
To find the absolute extrema, we first observe we must have:
$0\le S\le L$ which also means $0\le C\le L$
So, we will find the local extrema within this interval, and also look at the area at the end-points of the interval as possible absolute extrema as well.
There are 3 ways to find the local extremum, since the area is a quadratic in $S$.
For the first two methods, we wish to have an area function in one variable, and so we may use:
$C=L-S$
and we have:
$$A(S)=\frac{S^2}{16}+\frac{(L-S)^2}{4\pi}$$
Method 1: find the axis of symmetry
We will write the area function in standard quadratic form:
$$A(S)=\frac{4+\pi}{16\pi}S^2-\frac{L}{2\pi}S+\frac{L^2}{4\pi}$$
Thus, the axis of symmetry is at:
$$S=-\frac{-\frac{L}{2\pi}}{2\left(\frac{4+\pi}{16\pi} \right)}=\frac{4L}{4+\pi}$$
Since the parabola opens upward, we know the global minimum is at this value of $S$.
Thus, this is the amount of the wire that should go to the square to minimize the total area. Analysis of the end-points reveals:
$$A(0)=\frac{L^2}{4\pi}$$
$$A(L)=\frac{L^2}{16}$$
Since $A(0)>A(L)$, we find that to maximize the area, none of the wire should go to the square, and this makes sense as a circle will enclose more area per perimeter than a square.
Method 2: Equate derivative of area function to zero and solve for $S$ to get critical value.
$$A'(S)=\frac{S}{8}-\frac{L-S}{2\pi}=\frac{\pi S-4(L-S)}{8\pi}=0$$
This implies:
$$ \pi S-4(L-S)=0$$
$$ S=\frac{4L}{4+\pi}$$
To determine the nature of the associated extremum, we may use either the first or second derivative tests.
First derivative test:
$$A'(0)=\frac{\pi(0)-4(L-0)}{8\pi}=-\frac{L}{2\pi}<0$$
$$A'(L)=\frac{\pi L-4(L-L)}{8\pi}=\frac{L}{8}>0$$
Thus, the first derivative test shows the extremum is a minimum.
Second derivative test:
$$A''(S)=\frac{d}{dS}\left(\frac{\pi S-4(L-S)}{8\pi} \right)=\frac{p+4}{8\pi}>0$$
This shows the area function is concave up everywhere, and thus the extremum must be a global minimum.
Method 3: Use optimization with constraint
We have the objective function:
$$A(C,S)=\frac{S^2}{16}+\frac{C^2}{4\pi}$$
subject to the constraint:
$$g(C,S)=C+S-L=0$$
Using Lagrange multipliers, we find:
$$\frac{C}{2\pi}=\lambda$$
$$\frac{S}{8}=\lambda$$
this implies:
$$\frac{C}{2\pi}=\frac{S}{8}$$
$$C=\frac{\pi S}{4}$$
Substituting this into the constraint, we find:
$$\frac{\pi S}{4}+S-L=0$$
Solving for $S$, we find:
$$S=\frac{4L}{4+\pi}$$
The remaining analysis is the same as for Method 1.
In conclusion, we have found to minimize the area, we need:
$$C=\frac{\pi}{4}S=\frac{\pi}{4}\cdot\frac{4L}{4+\pi}=\frac{\pi L}{4+\pi}$$
Using the given value $L=40\text{ cm}$ we find then:
$$S=\frac{160}{4+\pi}\,\text{cm}$$
$$C=\frac{40\pi}{4+\pi}\,\text{cm}$$
2.) A manufacturer wants to design an open box having a square base and a surface area of 108 square inches. What dimensions will produce a box with maximum value?
I am assuming two things here...we wish to maximize the volume and the sirface area is the outer surface area only.
Let's let $0\le L$ be the lengths of the sides of the square base and $0<S$ be the outer surface area. We will let $0\le h$ be the height of the box. We may then write:
(1) $$V(h,L)=hL^2$$
(2) $$S(h,L)=L^2+4hL$$
We should observe that we require:
$$0\le L\le\sqrt{S}$$
Method 1: Single variable calculus
Solving (2) for $h$, we find:
$$h=\frac{S-L^2}{4L}$$
Substituting for $h$ into (1) we have:
$$V(L)=\left(\frac{S-L^2}{4L} \right)L^2=\frac{1}{4}\left(SL-L^3 \right)$$
Differentiating with respect to $L$ and equating to zero, we find:
$$V'(L)=\frac{1}{4}\left(S-3L^2 \right)=0$$
And this implies:
$$S-3L^2=0$$
Taking the positive root since $L$ represents a measurement of length, we have:
$$L=\sqrt{\frac{S}{3}}$$
and so:
$$h=\frac{S-\left(\sqrt{\frac{S}{3}} \right)^2}{4\sqrt{\frac{S}{3}}}= \frac{1}{2}\sqrt{\frac{S}{3}}$$
To determine the nature of the extremum associated with this critical value,we may use the first and second derivative tests.
$$V'(0)=\frac{1}{4}\left(S-3(0)^2 \right)=\frac{S}{4}>0$$
$$V'(\sqrt{S})=\frac{1}{4}\left(S-3(\sqrt{S})^2 \right)=-\frac{S}{2}<0$$
Thus, the first derivative test shows the extremum is a maximum. Since we have:
$$V(0)=V(\sqrt{S})=0$$, we know this is the absolute maximum on the restricted domain of $L$.
$$V''(L)=\frac{d}{dL}\left(\frac{1}{4}\left(S-3L^2 \right) \right)=-\frac{6L}{4}$$
Thus, on the restricted domain, the volume function is concave down, hence the extremum is a maximum.
Method 2: Multi-variable calculus (optimization with constraint)
$$V(h,L)=hL^2$$
$$g(h,L)=L^2+4hL-S=0$$
$$L^2=4L\lambda$$
$$2hL=(2L+4h)\lambda$$
This implies:
$$\lambda=\frac{L^2}{4L}=\frac{hL}{L+2h}$$
$$\frac{L^2(L+2h)-4hL^2}{4L(L+2h)}=0$$
$$\frac{L^2(L-2h)}{4L(L+2h)}=0$$
Thus, knowing $L=0$ is a minimum, we are left with:
$$L=2h$$
and substitution of this into the constraint reveals:
$$(2h)^2+4h(2h)-S=0$$
$$h=\frac{1}{2}\sqrt{\frac{S}{3}}$$
and so:
$$L=2h=\sqrt{\frac{S}{3}}$$
So, in conclusion, we have found that the volume of the box is maximized for:
Using the given value of $$S=108\text{ in}^2$$, we then have:
$$L=6\text{ in}$$
$$h=3\text{ in}$$
3.) The concentration in $$\frac{\text{mg}}{\text{cm}^3}$$, of a particular drug in a patient's bloodstream is given by the formula $$C(t)=\frac{0.12t}{t^2+2t+2}$$, where $t$ represents the number of hours after the drug is taken.
a) Find the maximum concentration on the interval $0\le t\le4$.
b) Determine when the maximum concentration occurs.
First, we want to find the critical values by equating the derivative of the concentration function to zero. Use of the quotient rule gives:
$$C'(t)=\frac{0.12(t^2+2t+2)-0.12t(2t+2}{(t^2+2t+2)^2}=\frac{0.12(2-t^2)}{(t^2+2t+2)^2}=0$$
The denominator has no real roots, and for the given interval the only critical value is then:
$$t=\sqrt{2}$$
To determine the nature of the extremum associated with this critical value, we may use the first and second derivative tests.
$$C'(0)=\frac{0.12(2-0^2)}{(0^2+2(0)+2)^2}=0.06>0$$
$$C'(4)=\frac{0.12(2-4^2)}{(4^2+2(4)+2)^2}=-\frac{21}{8450}<0$$
Thus, the first derivative test shows that the extremum is the absolute maximum.
$$C''(t)=\frac{d}{dt}\left(\frac{0.12(2-t^2)}{(t^2+2t+2)^2} \right)=0.12\left(\frac{(t^2+2t+2)^2(-2t)-(2-t^2)(2(t^2+2t+2)(2t+2))}{(t^2+2t+2)^4} \right)=\frac{0.24(t^3-6t-4)}{(t^2+2t+2)^3}$$
Knowing the denominator is positive for all real $t$, we need only look at:
$$(\sqrt{2})^3-6(\sqrt{2})-4=-4\sqrt{2}-4<0$$
And so we know the extremum is a maximum. Thus, we have found:
a) The maximum concentration in $$\frac{\text{mg}}{\text{cm}^3}$$ is
$$C_{\max}=C(\sqrt{2})=\frac{3}{50}(\sqrt{2}-1)\approx0.0248528137423857$$
b) This maximum occurs for $t$:
$$t=\sqrt{2}\text{ hr}\approx1\text{ hr }24\text{ min }51.1688245432\text{ sec }$$.
