Orbital Velocities and Mass Distribution in Galaxies
The discussion revolves around the relationship between stellar orbital speeds and the required mass distribution in the Milky Way galaxy. Participants explore the implications of mass density profiles on orbital velocities, considering both visible and dark matter contributions. The scope includes theoretical calculations, observational evidence, and references to existing studies.
  • One participant proposes that a linear relationship between mass and radius in the galaxy could lead to constant orbital speeds, aligning with observed data.
  • Another participant asserts that dark matter plays a significant role in affecting orbital dynamics, suggesting that most of the mass is not visible.
  • Several participants reference existing studies on galactic mass densities, indicating a wealth of research on the topic.
  • There is mention of evidence for dark-matter-free galaxies, which raises questions about the assumptions made regarding mass distribution.
  • A participant expresses confusion over the transition from density profile calculations to estimates of visible versus invisible matter in spiral galaxies, questioning the conclusions drawn in a referenced paper.
Participants do not reach a consensus, as there are competing views regarding the role of dark matter and the implications of mass density profiles on orbital speeds. Some participants emphasize the importance of dark matter, while others question its necessity based on specific observations.
There are unresolved questions regarding the assumptions underlying mass density calculations and the implications for the presence of dark matter in galaxies. The discussion highlights the complexity of linking observational data to theoretical models.
This discussion may be of interest to those studying astrophysics, particularly in the areas of galactic dynamics, dark matter research, and observational astronomy.
cosmologyscience
TL;DR
The necessary visible mass density distributions to obtain static observed orbital speeds in the Milky Way.
Has anyone looked into the details of stellar orbital speeds and required (visible) mass distribution in the Milky Way?
Doing some math here - if the local mass density is significantly higher in the inner 10-15% of the galaxy, and then lower and gradually thinning outwards in the disk, we will get a linear relation between mass and radius in the galaxy. (2x more radius, 2x more mass. While 2x more radius, 8x more volume).
If the mass is adjusted so we have a linear radius to mass relation, you get a constant orbital speed v at every point in the disk (which is roughly what is observed).
The local densities in the milky way would then be (given orbital speeds c. 220km/s):
0-1 kly from the center: 1.728 E-18 kg/m^3
9-10 kly from the center: 6.378 E-21 kg/m^3
49-50kly from the center: 2.351 E-22 kg/m^3
Meaning the local density at radius 0-1 kly is about 270x more dense than at 9-10kly. And then out in the disk, 49-50 kly is just 27x more dense than at 9-10 kly radius.
Given that the bulge is a dense ball, and the "shells" outwards mostly only have (visible) mass in a thin sliver with the disk, this might still maintain the requirement that each "shell" needs to have the same amount of mass.
Wonder if anyone has done any work on this, or what the calculations are that imply up to 90% mass deficiency to obtain the observed orbital speeds.Richard
Astronomy news on Phys.org
Most of the matter is dark matter, seriously affecting orbits, etc.
For a fun time, see this recent thread. :oldbiggrin:
That's a collection of great references. Thank you!
vanhees71 said:
Note that there's evidence for dark-matter-free galaxies:
https://www.nature.com/articles/s41586-022-04665-6 (open access!)
Very interesting, thank you.
And I'm still struggling to see the jump from density profile calculations to estimations of percentages visible matter/invisible matter in spiral galaxies. In the linked paper in an earlier comment (https://iopscience.iop.org/article/10.3847/1538-4357/aaf57b) - they seem to do everything right including estimating the mass density profile, which indicates that about 80-85% of the mass is in the disk.
But then it jumps to: "The outer halo mass is significant and it is four times more than the mass of the inner (more dense) regions, which confirm the existence of a massive halo and giving evidence as to the existence of dark matter." But looking at the galaxy NGC 3198 (attached), estimating the visible mass in the disk accounting for 80-85% of the total mass of the galaxy looks quite reasonable. And even if the star density "thins out" further out from the center, that is what Kepler's law predicts given a stable velocity - the density has to fall by 1/r^2 to maintain a constant amount of mass added pr. increment.
  • · Replies 29 ·
