Orbital velocities in the Schwartzschild geometry
536 replies · 68K views · last reply
espen180
I'm trying to use the tensor formulation of GR to calculate the velocity of a particle in a circular orbit around a black hole.
Here is the work I have done so far.
What concerns me is that I end up getting zero velocity when applying the metric to the differential equations I get from the geodesic equation. I wonder if I have made a miscalculation, but I am unable to find any, so maybe there is a misunderstanding on my part.
Any help is appreciated.
There seems to be a problem with signs in (13), because both terms are negative-definite.
Using (12), and choosing t=0 to coincide with [itex]\tau=0[/itex], you can set [itex]t=\beta \tau[/itex], where [itex]\beta[/itex] is a constant. Let's also set [itex]\omega=d\phi/der t[/itex]. Then (13) gives [itex]\omega=\pm i\sqrt{2m/r^3}[/itex], where [itex]m=r_s/2[/itex]. This seems sort of right, since it coincides with Kepler's law of periods. However, it's imaginary due to the sign issue. It would also surprise me if Kepler's law of periods was relativistically exact when expressed in terms of the Schwarzschild coordinates, but maybe that's the case.
If you can fix the sign problem, then you seem to have the right result in the nonrelativistic limit of large r. You might then want to check the result in the case of r=3m, where I believe you should obtain lightlike circular orbits.
You are right, his equation (13) is in the "not-even-wrong" category. It is easu to see that since the correct Lagrangian, for the simplified case he's considering is:
[tex]L=(1-r_s/r)\frac{dt^2}{ds^2}-r^2\frac{d\phi^2}{ds^2}[/tex]
@George Jones , bcrowell
Thanks for pointing that out, and thank you for the reference. I traced the sign error back to a differentiation error when calculating the Christoffel symbol.
As for writing [itex]t=\beta\tau[/itex] I don't see how that will help since t does not appear in the other equations. I must be missing something.
I will try to arrive at a result and do the "reality checks" you mentioned.
@Starthaus
Thanks for your input. I am afraid I don't know how to arrive at or what to do with the Lagrangian. From it's appearance it looks just like the metric, so L=1 here, I imagine?EDIT:
I arrived at [tex]\frac{\text{d}\phi}{\text{d}\tau}=\frac{c}{r}\sqrt{\frac{r_s}{r-r_s}}[/tex]. The units match, but I doubt this is correct, since letting r=3m gives [tex]\frac{\text{d}\phi}{\text{d}\tau}=\frac{c}{\sqrt{2m}}[/tex] while my intuition tells me it should be c.
espen180 said:
EDIT:
No, the correct equations are:
[tex]\frac{d^2t}{ds^2}=0[/tex]
and
[tex]\frac{d^2\phi}{ds^2}=0[/tex]
Hint: in your writeup you made [tex]dr=d\theta=0[/tex], remember? You need to think what that means.
and
Yes, I arrived at these as well when I made the assumptions you mentioned. As for their meaning, I interpret it as circular (constant radial coordinate) motion around the equator ([itex]\theta=\pi/2[/itex]) with constant velocity. In addition, there was a third equation I arrived at,
[tex]\frac{c^2r_s}{r^2}\left(\frac{\text{d}t}{\text{d}\tau}\right)^2-r\left(\frac{\text{d}\phi}{\text{d}\tau}\right)^2=0[/tex]
which, when I used the substitution
[tex]\left(\frac{\text{d}t}{d\tau}\right)^2=1+\frac{r^2}{c^2}\left(\frac{\text{d}\phi}{\text{d}\tau}\right)^2[/tex]
which I got from the metric, gave me
[tex]\frac{c^2r_s}{r^2}+(r_s-r)\left(\frac{\text{d}\phi}{\text{d}\tau}\right)^2=0[/tex]
which solves to
So now I am unsure about where I made my mistake.
There are only two independent equations, the ones I mentioned to you.
The third Lagrange equation, exists only if r is variable and its correct form would have been:
[tex]\frac{r_s}{r^2}\frac{dt^2}{ds^2}-2r\frac{d\phi^2}{ds^2}=0[/tex]
But you made [tex]dr=0[/tex] (this is why I gave you the hint), so the third equation does not exist. This is the root of your errors.
I don't understand why it shouldn't exist. I derived the general case, then assumed dr=0 and substituted that into the equations. dr doesn't even appear in that equation anymore, do I don't see how it has any influence.
EDIT: Where does the factor of 2 come from there? I somehow didn't appear in my calculations.
For the velocity, I obtained
[tex]v=\frac{\text{d}\phi}{\text{d}\tau}r=c\sqrt{\frac{r_s}{r-r_s}}=\sqrt{\frac{2GM}{r-\frac{2GM}{c^2}}}[/tex]
My intuition says that this is wrong by a factor of [itex]\sqrt{2}[/tex], since then it would give v=c at [itex]r=\frac{3GM}{c^2}[/itex], but I don't see how that factor dissapeared.[/itex]
You started with the metric that has [tex]dr=0[/tex]. therefore all your attempts to differentiate wrt [tex]r[/tex] should result in null terms. Yet, you clearly differentaite wrt [tex]r[/tex] in your derivation and this renders your derivation wrong.
From the Euler-Lagrange equations.
[itex] <br /> Yes, it is very wrong.<br /> From the correct equation [tex]\frac{d^2\phi}{ds^2}=0[/tex] you should obtain (no surprise):<br /> <br /> [tex]\frac{d\phi}{ds}=constant=\omega[/tex]<br /> <br /> The trajectory is completed by the other obvious equation<br /> <br /> [tex]r=R=constant[/tex]<br /> <br /> You get one more interesting equation, that gives u the time dilation. Start with:<br /> <br /> [tex]ds^2=(1-r_s/R)dt^2-(Rd\phi)^2[/tex] and you get:<br /> <br /> [tex]\frac{dt}{ds}=\sqrt{\frac{1+(R\omega)^2}{1-r_s/R}}[/tex]<br /> <br /> or:<br /> <br /> [tex]\frac{ds}{dt}=\sqrt{1-r_s/R}\sqrt{1-\frac{(R\omega)^2}{1-r_s/R}[/tex]<br /> <br /> The last equation gives you the hint that:<br /> <br /> [tex]v=\frac{R\omega}{\sqrt{1-r_s/R}}[/tex]<br /> <br /> The last expression is what you were looking for.[/itex]
The only thing I said is that I have constant r. If you have a function, say f(x)=x2, you can say that x is fixed at three, but you can still get the slope at x=3 by differentiating wrt x.As for the last equation you posted. I don't doubt its validity, but I don't see how it will get me anywhere, since neither v nor [tex]\omega[/tex] are known. In fact, since [tex]v=\omega R[/tex], v cancels on both sides.
Umm, no. If you did things correctly, then you'd have realized that [tex]dr=d\theta=0[/tex] reduces the metric to :
[tex]ds^2=(1-r_s/R)dt^2-R^2d\phi^2[/tex]
So, your Christoffel symbols need to reflect that. They don't.
Yet, the result is extremely important since it tells you that the orbiting object has constant angukar speed and the trajectory is a circle.
No, [tex]v[/tex] is not [tex]\omega R[/tex].
How do you define v?
Of course the trajectory is a circle. I imposed that restriction by setting r=constant after deriving the general case geodesic equations. The equations saying d2t/ds2=0 and d2φ/ds2=0 are neccesary consequences.
What I am seeking is an expression which gives the orbital velocity as a function of r. I define [tex]v=\frac{\text{d}\phi}{\text{d}\tau}r[/tex], and except for the factor [tex]\sqrt{2}[/tex] my result reduces to the Newtonian formula at large r, which makes me believe my derivation is valid, the erronous factor [tex]\sqrt{2}[/tex] notwithstanding.
espen180 said:
.I define [tex]v=\frac{\text{d}\phi}{\text{d}\tau}r[/tex], and except for the factor [tex]\sqrt{2}[/tex] my result reduces to the Newtonian formula at large r, which makes me believe my derivation is valid, the erronous factor [tex]\sqrt{2}[/tex] notwithstanding.
You don't get to "define", you need to "derive" :
since, in GR:[tex]\frac{ds}{dt}=\sqrt{1-r_s/r}\sqrt{1-v^2}[/tex]
And is v, in your case, measured by an observer from infinity? You have to give a definition. [tex]v=\frac{\text{d}\phi}{\text{d}\tau}r[/tex] and [tex]\frac{\text{d}\phi}{\text{d}t}r[/tex], for example, aren't the same, so you have to specify.
Aside from that, how can your equation be used to calculate the orbital period as a function of r only?
You can do it all by yourself by remembering that [tex]\frac{d\phi}{d\tau}=\omega[/tex] (see the derivation from the Euler-Lagrange equation)
[tex]\phi=\omega \tau[/tex]. Make [tex]\phi=2\pi[/tex]
The orbital period is not a function of r.
For circular motion, it is easy to obtain the relationship [tex]v=\omega r[/tex]. You get it directly from the definition of the radian. Do you claim [tex]v=\frac{\text{d}\phi}{\text{d}\tau} r[/tex] is not a valid definition of v? If so, please explain.
Please link to the Euler-Lagrange derivation, and I'll do my best to understand it.
How do you arrive at that conclusion? It is obvious that the orbital period is a function of r. That's why Mercury's orbital period is shorter that Earth's.
Not in GR. You are fixated on galilean physics. I am sorry, until you get off your fixations, I can't help you.
Then please explain the situation in GR.
What do u think I've been doing for you starting with post 4?
espen180 said:
For circular motion, ...
Certainly true since neither the Earth nor Mercury move in circles. You are trying to analyze circular motion. The rules of elliptical motion don't apply. You can't force your preconceptions on solving the problem.
So if Earth and Mercury were moving in circular paths they would have the same orbital period? How does that work? A circle is just a spatial case of an ellipse anyway.As for your earlier equation:
[tex]v=\frac{r\omega}{\sqrt{1-r_s/r}}[/tex]
If I use this definition with my calculations I get
[tex]v=c\sqrt{\frac{\frac{r_s}{2}}{\left(r-\frac{r_s}{2}\right)\left(1-\frac{r_s}{r}\right)}}=\sqrt{\frac{GM}{\left(r-\frac{GM}{c^2}\right)\left(1-\frac{2GM}{rc^2}\right)}}[/tex]
If I let [tex]r=\frac{3GM}{c^2}[/tex] I get [tex]v=\sqrt{\frac{3}{2}}c[/tex] where it is expected to be v=c.
So my calculations must be wrong since it produces that factor of [tex]\sqrt{\frac{3}{2}}[/tex]. The equations I based my calculations off of are identical to the ones given in George Jones' reference in post #2, so I don't get what's wrong here. I also don't understand your argument that the equations don't exist.
which solves to
The substitution you got from the metric (equation 15 in your document) contains a typo that causes an error to propagate.
You state "From the Shwarschild metric we can , by imposing dr/ds=0 and theta=pi/2 obtain the relation":
[tex]ds^2 = dt^2 - r^2 d\phi^2 \;\;\; (15)[/tex]
where I am using units of G=c=1 and ds to mean proper time of the test particle.
That should read:
[tex]ds^2 = (1-2M/r) dt^2 - r^2 d\phi^2 \;\;\; (15)[/tex]
which gives:
[tex]\left(\frac{dt}{ds}\right)^2 = \frac{1}{(1-2M/r)}\left(1 + r^2 \left(\frac{d\phi}{ds}\right)^2\right) \;\;\; (16)[/tex]
I am not quite sure how you got equation (13) from (10) but there seems to be a problem there somewhere when cos(pi/2)=0 and dr/ds=0.
I introduced the idea that L=1 in several other threads so perhaps I should clarify a little. This is valid for massive particles and is obtained directly from the metric as:
[tex]1 = \alpha \dot{t}^2 - \alpha^{-1}\dot{r}^2 - r^2 \dot{\phi}^2[/tex]
We can of course multiply both sides by some multiple and obtain a different constant on the left. Eg if I use a multiple of 1/2 then:
[tex]1/2 = (\alpha \dot{t}^2 - \alpha^{-1}\dot{r}^2 - r^2 \dot{\phi}^2)/2[/tex]
I can now declare L=1/2 and proceed from there if I wish. The important thing is that I arrive at an equation in a form with a constant on one side.
For a massless particle such as a photon, ds=0 and I can write the metric as:
[tex]0 = \alpha - \alpha^{-1}\dot{r}^2 - r^2 \dot{\phi}^2[/tex]
and in this case I can use L=0. I can also obtain non-zero values of L here by adding a constant to both sides. Note that for a masslesss particle, the over-dot means the derivative with respect to coordinate time (t) rather than proper time (s). Obtain a new constant of motion for the angular velocity of a photon in the Schwarzschild metric by taking the partial differential of the right hand side with respect to [tex]\dot{\phi}[/tex]. Using the constant, solve for dr^2/dt^2 and differentiate both sides with respect to r and divide both sides by 2 to obtain the radial acceleration of a light particle. For a circular orbit d^2(r)/d(t)^2 = 0 and by setting the acceleration to zero and solving for r, the result that the photon radius is r=3M comes out very simply and clearly.
Thank you very much for pointing that error out for me.
As for (13), it was derived from (9), not (10). (10) reduces to 0=0 when the restrictions are imposed.
Updated article.
I corrected the error you pointed out, and another regarding a constant factor in one of the Christoffel symbol's entries.
The new (19), though, still does not do what it's supposed to, giving infinite velocity at the photosphere radius.
Regarding Starthaus' last equation in post #10, doesn't the two angular terms indicate that v=ωr , being the same as for flat spherical coordinates?
Yes..sort of.. so that w=v/r, but you must bear in mind that starthaus uses a definition of w=d(theta)/ds and not the normal Newtonian w=d(theta)/dt. In spherical coordinates in SR, ds includes a time dilation factor of 1/sqrt(1-v^2/c^2) and in Schwarzschild coordinates ds includes an additional factor of 1/(sqrt(1-2M/r) so it is no longer the same as the SR case.
You have to be careful when using ds rather than dt. In the example below for something moving at the speed of light, you should expect to obtain an infinite velocity r*d(phi)/0 rather than c.
Bearing that in mind an infinite result for (19) in the case of a photon, might well be a correct result, as it is in terms of proper time.
I am a bit short of time and that is why post #25 is a bit cryptic, but it might be interesting to carry out the calculations and obtain coordinate velocity = c for a photon at r=3m using the method described.
P.S. There still seems to be a problem with (13) derived from (9) but I do not have time to check that at the moment.
I have had another look at your revised document and checked all the calculations from (9) onwards and they all seem to be correct. Your final result can be simplified to:
[tex]\frac{rd\phi}{ds} = c \sqrt{\frac{GM}{rc^2 - 3GM}[/tex]
which gives the correct result that the velocity with respect to proper time (ds) of a particle orbiting at r=3GM/c^2 is infinite.
If you convert the above equation to local velocity as measured by a stationary observer at r by using [tex]ds = dt'\sqrt{1-(rd\phi)^2/(cdt')^2}[/tex] you get:
[tex]\frac{rd\phi}{dt'} = c \sqrt{\frac{GM}{rc^2 - 2GM}[/tex]
which gives the result that the local velocity of a particle orbiting at r=3GM/c^2 is c.
If you convert the equation to coordinate velocity using [tex]dt = dt'\sqrt{1-2M/(rc^2)}[/itex] you get:<br /> <br /> [tex]\frac{rd\phi}{dt} = c \sqrt{\frac{GM}{r}[/tex]<br /> <br /> which is the same as the Newtonian result (if you use units of c=1).<br /> <br /> All the above are well known solutions, so it seems all is in order with your revised document (from (9) onwards anyway - I have not checked the preceding calculations).[/tex]
Updated article.
It is just as wrong as I explained to you in post 12. If you did things correctly, then you'd have realized that [tex]dr=d\theta=0[/tex] reduces the metric to :
where [tex]R[/tex] is a constant. This is important in the correct derivation of the Christoffel symbols, since you should get a lot more "zeroes" than you have in your writeup.
So, your Christoffel symbols need to reflect that. They don't. You need to recalculate the Christoffel symbols based on the correct metric.
I think Espen makes it clear that he is deriving the general case in section 1 using Christoffel symbols and then in section 2 analyses the specific case of pure circular motion. Espen's updated document contains the corrected metric (15) for the special case.
Section 1 has no bearing on the subject.
This is not how things are done. You start with the correct metric, you construct the associated metric tensor and you calculate the appropriate Christoffel symbols. If you do all this correctly you will get two (not three) very simple equations that are identical to the ones already shown in post 6.
Covariant derivatives and lagrangian methods, if done correctly, should produce the same results.
Yet, it contains the wrong Christoffel coefficients associated with the metric (15). This is the source of his errors as explained already in post 12.
