Orbital velocity and rotational velocity
mun
Hi
Is "orbital velocity" supposed to be the same as "rotational velocity"? it seems that a "rotation curve" is supposed to plot the rotational velocity of a star, but then some articles e.g. http://en.wikipedia.org/wiki/Galaxy_rotation_problem claim "orbital speed" is plotted.
The equation for rotational velocity seems to be in the shape of V sin(i) but the equation for orbital velocity doesn't depend on sin.
Any help will be much appreciated.
Thanks!
In this case the "orbital velocity" and "rotational velocity" refer to different objects. Galactic rotation refers to rotation of a galaxy, which is in turn composed of many stars. It is the orbital motion of these stars around the center of mass that corresponds to the rotation of the galaxy as a whole. So the rotational velocity of a galaxy is related to the the orbital speed of the constituent stars.
Hi
Thanks for the reply. So how is the rotational velocity of a galaxy related to the orbital speed of the constituent stars? It's probably not as simple as being related by a factor of a constant. What are the dependent factors here?
Thanks
Actually, some speak about the rotational velocity of stars: http://astro.berkeley.edu/~mwhite/darkmatter/rotcurve.html
"To make a rotation curve one calculates the rotational velocity of e.g. stars along the length of a galaxy by measuring their Doppler shifts..."
I thought a rotation curve plots the orbital velocity of stars (?)
Thanks
mun said:
Hi
Thanks
In practice what is measured are the orbital speeds of stars at a given distance from the galactic center. The orbital speeds are found to be roughly constant, but that means that the angular speeds are still decreasing as we go to further distances. So the different parts of the galaxy are not moving together like a solid object. Therefore, it's not straightforward to just convert the orbital motion into a rotation of the galaxy at a whole.
It still makes sense to talk about a rotational speed at a given distance, since the orbital speed at a fixed distance is essentially the same for any star because of the relationship between the centripetal force and gravitational force. Some stars may have orbits that deviate from the galactic plane, though, so the reported rotational velocity at a given distance is an average of several measurements.
Thanks
It seems to be just an abuse of terminology. It's clear from the discussion there that no one is measuring the rotation of the individual stars about their own axes.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
