Ordinary DE using integrating factor?
19 replies · 4K views · last reply
cheddacheeze
solve the following initial condition problem
[tex]x (d/dx) y(x) + 4xy(x) = -8-y(x)[/tex]
[tex]y(4)=-6[/tex]
first i rearranged
[tex]xy'+y+4xy=-8[/tex]
[tex]xy'+y(1+4x)=-8[/tex]
[tex]y'+y(1/x+4)=-8/x[/tex]
integrating factor:[tex]e^\int(1/x+4)[/tex]
[tex]e^(lnx+4x)[/tex]
[tex]x+e^4x[/tex]
multiplying integrating factor:
[tex]d/dx(x+e^4x) y'+(1/x+4)(x+e^4x)y=-8/x(x+e^4x)[/tex]
[tex]d/dx(x+e^4x])y=-8/x(x+e^4x)[/tex]
[tex]\int d/dx(x+e^4x])y=\int-8/x(x+e^4x)[/tex]
[tex](x+e^4x)y=\int(-8-8e^4x/x)[/tex]
just wondering if I am going alright so far... and if i am how do you integrate
[tex]\int (8e^4x/x)[/tex]
[tex]x+e^4x[/tex]
Careful, [itex]e^{a+b}=e^a e^b \neq e^a+e^b[/itex]:wink:
so instead of
[tex]x+e^(4x)[/tex] its
[tex]xe^(4x)[/tex]?
Yup.:smile:
On a side note, to get exponents with more than one character to display properly in [itex]\LaTeX[/itex], simply enclose them in curly brackets. For example, [itex]xe^{4x}[/itex] is generated using xe^{4x}.
gabbagabbahey said:
Yup.:smile:
haha cheers for both advices, this should make things easier
ok after using:
[tex]xe^{4x}[/tex] as an integrating factor
i got
[tex]xe^{4x} y(x)=\int-8e^{4x}[/tex]
[tex]xe^{4x} y(x)= -2e^{4x} +C[/tex]
[tex]y(x)=-2e^{4x}/xe^{4x} + C[/tex]
[tex]y(x)=-2/x +C[/tex]
using initial conditions:
[tex]y(4) = -2/4+C = -6[/tex]
[tex]c=-11/2[/tex]
[tex]y(x)=-2/x-11/2[/tex]
and it doesn't seem to be the right answer
Shouldn't you also divide [itex]C[/itex] by [itex]xe^{4x}[/itex] here? :wink:
hmmmm tried doing that before but still didnt get the right answer
using:
[tex]y(x) = -2/x + C/(xe^{4x})[/tex]
and by substituing initial conditions i got:
[tex]y(4)=-2/4+C/(4e^{16})=-6[/tex]
[tex]-11/2=C/(4e^{16})[/tex]
[tex]C=(-22e^16)/2[/tex]
is this right or did i miss something...
cheddacheeze said:
using:
sorry there wasnt supposed to be
divide 2 there, i just simplified and got
[tex]C=(-22e^16)[/tex]
ok i must have done algebra somewhere incorrect then, can't get the right answer out
What was your final answer, and what is the answer "supposed" to be according to your assignment sheet/text?
my answer is [tex]y(x) = -2/x -22e^{-16}[/tex]
as for the solution i don't know since its a computer entered assignment
What happened to the [itex]xe^{4x}[/itex] in [itex]y(x) = -2/x + C/(xe^{4x})[/itex]?
i substituted the initial conditions into the equation and found what the value of C was and entered my answer as that, maybe i'll try keeping the constant and see if that's right
didnt think ordinary differential equations could be so annoying
haha...
You had [itex]y(x) = -2/x + C/(xe^{4x})[/itex] as your general solution, substituting your initial condition gave you [itex]C=-22e^{16}[/itex], so your particular solution should be
[tex]y(x)=-\frac{2}{x}-\frac{22e^{16}}{xe^{4x}}[/tex]
Not what you had in post #15. You need to pay more attention to basic algebra steps like substitution.
ohhhh... C was over [tex]xe^{4x}[/tex]
keep making stupid mistakes... looks like i need to look at things with more care
thanks a lot :)
