Oscillation of a coil in a Magnetic Field
The discussion centers on the oscillation of a circular coil in a magnetic field, specifically a coil with a radius of 20mm and a mass of 50g, carrying a current of 400mA in a magnetic field of 100mT. The participants confirm that the coil will undergo simple harmonic motion when rotated by a small angle from its minimum torque position. The frequency of oscillation is derived using the formula f = ω/2π, where ω² = NAIB/I_M, with N representing the number of turns in the coil and I_M as the moment of inertia.
  • Understanding of torque in magnetic fields
  • Knowledge of simple harmonic motion principles
  • Familiarity with moment of inertia calculations
  • Basic proficiency in angular frequency and oscillation equations
  • Calculate the moment of inertia for a circular coil using I = (1/4)mr²
  • Explore the derivation of angular frequency in oscillatory systems
  • Investigate the effects of varying magnetic field strength on coil oscillation
  • Learn about the applications of electromagnetic coils in engineering
Students in physics or engineering courses, particularly those studying electromagnetism and oscillatory motion, as well as educators seeking to explain the principles of magnetic fields and harmonic motion.
mydir
Hi I am really stuck on this question. It got handed out to us this morning and is due in Wednesday of this week. Any help would be great thanks.
A circular solid coil consisting of a circular disk of radius R = 20mm and mass M =
50 g pivoted through its diameter. It has 10 loop of thin wire round it circumference carry a current i = 400mA.
This coil is placed in a constant magnetic field of B = 100mT orientated such that the
torque on the coil is a minumum.
Show that if the coil is rotated by a small angle and released, it will undergo simple
harmonic motion about the minimum torque position. calculate the frequency of the
oscillation.
Torque =μ(magnetic monent) ×B [Vector equation]
F(magnetic) = qv B
F(central) =(mv^2)/r
Torque= AIB sin(theta) [A is the area of the loop]
I don't really know where to start. When it says the torque is a minimum does that its 0?
Should i solve the two force equations for r: r =mv/q B? Then solve for the frequency w=qB/m? Could the moment of inertia I = (1/4)mr^2, help me in this question? I mean I really don't know where to start and any help whatsoever would be much appreciated.
Thanks
mydir
hi dymir,
We know that the restoring torque of this system is:
τ=-NAIBsin(θ), (where N is the number of turns in the coil)
This means,
I_M*a ̈=-NAIBsin(θ), (where I_M is the moment of inertia, and a is the angular acceleration)
So for small angles:
I_M*a ̈=-NAIBθ,
Hence the EOM is of the form,
a+(ω^2)*θ, (where ω^2=NAIB/I_M)
This means there is harmonic motion,
To find the frequency of oscillation, we have angular frequency ω,
So the frequency is just;
f=ω/2pi
Now u have the method, You can do the math^^
Thank you very much for the help. I had spotted thta torque was alsoe I_M*a but I hadnt realized that w^2 = NAIB/I_M. Now however all is fine.
Thanks again brainstorm!
mydir
