Oscillations of Dipole in Electric Field: Stability & SHM
  • Context: High School
  • Thread starter Thread starter gracy
    Dipole Oscillations
The discussion revolves around the behavior of a dipole in electric fields, specifically focusing on the conditions under which it executes angular simple harmonic motion (SHM) when displaced from equilibrium positions. The scope includes theoretical considerations and mathematical reasoning related to stable and unstable equilibrium positions in both uniform and non-uniform electric fields.
  • Some participants propose that a dipole displaced from a stable equilibrium position will execute angular SHM, while the behavior from an unstable equilibrium position remains uncertain.
  • One participant suggests that for larger displacements, the motion is not well approximated by SHM and involves elliptic integrals.
  • There is a discussion about whether a dipole initially aligned at 180 degrees to the electric field will execute SHM upon displacement, with conflicting views on this point.
  • Some participants argue that in a non-uniform electric field, the dipole will not execute angular SHM regardless of the angle of displacement, suggesting a combination of translatory and rotatory motion instead.
  • Others note that small displacements from stable equilibrium can be modeled as SHM, applicable to various systems, not just dipoles.
  • There is a query about the potential function in non-uniform electric fields, with references to the net force experienced by the dipole.
Participants express differing views on the conditions under which a dipole executes SHM, particularly regarding stable versus unstable equilibrium positions and the effects of uniform versus non-uniform electric fields. The discussion remains unresolved with multiple competing perspectives.
Limitations include the lack of specific details regarding the potential functions in non-uniform fields and the assumptions underlying the approximations made for SHM. The discussion also highlights the dependence on the definitions of stable and unstable equilibrium.
gracy
In a uniform electric field if a dipole is slightly displaced from it's stable equilibrium position it executes angular SHM.
What if a dipole is slightly displaced from it's unstable equilibrium position ,will it execute angular SHM?
Do you mean like in a situation where the dipole is hold at an arbitrary angle from the field and then released?
The SHM resulting from a small initial displacement from the equilibrium position is actually an approximation. For significantly bigger starting angle, the solution of the equation of motion is no longer well approximated by SHM. For this kind of problem, the solution involves certain type of elliptic integral.
blue_leaf77 said:
Do you mean like in a situation where the dipole is hold at an arbitrary angle from the field?
I mean if the dipole initially makes 180 degrees with electric field and then it is displaced from there will it execute SHM?
That example is also included in the situation I described above.
You mean it won't execute SHM?
It will not.
In a uniform electric field if a dipole is displaced for a large angle from it's stable equilibrium position will it execute angular SHM?I think no.
The only logical difference between "slightly displaced from it's unstable equilibrium position" and "displaced for a large angle from it's stable equilibrium position" is that the second statement being just a special case of the first. If you want to know which case is an approximate SHM which is not, you should go to the equation of motion and see whether any approximation can be assumed. On the whole, a pendulum-type motion under uniform force field is strictly speaking not SHM.
In a non uniform electric field if a dipole is displaced it won't execute angular SHM(no matter what it's starting angle is and whether it is displaced for a larger or smaller angle )
In this case motion of dipole is combination of translatory and rotatory motion .
Right?
Right?
What does your trained intuition tell you? Try to trust yourself if you know your reasoning can be supported by the known physics formula.
If the displacement from stable equilibrium is small enough you can model the motion as a SHO. This is valid for any system, not restricted to dipole in a specific type of field.
Right. For many potential functions, particularly in the case of one dimensional motion, a small displacement from a stable equilibrium position results in SHM, Simple Harmonic Motion.
Even in non uniform electric field?
What is the potential function in this case?
I just know dipole in non uniform electric field experiences a net force given by
##F##=##Δ(P.E)##
where p is the dipole moment and E is the electric field.I don't know abut potential.
##F##=##Δ(P.E)##
where p is the dipole moment and E is the electric field.I don't know about potential.
(In Post #12, I was commenting on Post #11.)
That should be ##\displaystyle \vec F = -\vec \nabla (\vec p \cdot \vec E) \ ## .
Do you understand what all of those symbols mean ?For the case of a non-uniform field, whatever happens will depend on the details, details which are not specified here.
Please answer my post #13 .
I did.
Last sentence in Post #16.
Thread closed for Moderation...
