~(p->q) of part of A Probabilistic Proof of Wallis's Formula for pi
  • Thread starter Thread starter Dustinsfl
    Formula Pi Proof
The discussion focuses on the negation of a theorem regarding nonnegative continuous functions and their integrals. The original statement asserts that if g(x) is a nonnegative continuous function with a finite integral, then a scaled version can serve as a probability distribution. The negation of the implication P implies Q is clarified as not P or Q, leading to confusion about how to properly negate P. It is concluded that the negation of P should encompass all conditions, resulting in the statement that g(x) is either not continuous, takes on negative values, or has a divergent integral. The clarification emphasizes the logical structure of the negation in the context of the theorem.
Dustinsfl
Write in symbols the negation of the theorem stated in part a.
part a:We immediately see that if g(x) is a nonnegative continuous function whose integral is finite, then there exists an a>0 such that a*g(x) is a continuous probability distribution (take a=1/\int g(x)dx from -\infty to \infty).
The negation of P implies Q is equivalent to not P or Q.
The issue is with the P part.
Is ~P= g(x) isn't a nonnegative continuous fuction whose integral isn't finite?
I am not sure if both is parts need to be negated or just one.
Then for the Q part it is just itself starting with the existential quantifier.
~(P => Q) is equivalent to "P and not Q."
Since you don't need the negation of P, does that solve your problem?
Just for completeness sake:
I suppose P is the statement "g(x) is a non-negative continuous function whose integral is finite." I would re-write this as "g(x) is a function which is non-negative and continuous and whose integral is finite" to emphasize the internal logical structure. Since ~(a and b and c) = ~a or ~b or ~c, the negation of P is:
"g(x) is a function which is not continuous or assumes negative values or whose integral diverges."
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 100 ·
12K
