Pair production: Has it been observed experimentally?
The discussion centers on the experimental observation of pair production, specifically the creation of electron-positron pairs from photons. It is established that pair production occurs when high-energy photons interact with a nucleus, leading to the formation of these particles. The conversation highlights the necessity of momentum transfer and the role of nuclei in this process, clarifying that photons alone cannot create pairs without additional interactions. The phenomenon is well-documented and utilized in particle physics, such as in the International Linear Collider (ILC) design.
  • Understanding of pair production in particle physics
  • Knowledge of photon interactions with matter
  • Familiarity with energy-momentum conservation principles
  • Basic concepts of fermions and bosons
  • Research "pair production in high-energy physics" for detailed mechanisms
  • Study "photon-nucleus interactions" to understand the role of nuclei
  • Explore "momentum transfer in particle collisions" for deeper insights
  • Investigate the "International Linear Collider (ILC) design" and its applications
Physicists, particle physicists, students of nuclear physics, and anyone interested in the experimental aspects of high-energy particle interactions.
damianpaz
I was reading about electron-positron annihilation and I got to the part where it says that this is a reversible process, meaning that an electron and a positron could be created from photons.
About this reverse process the article says "In nuclear physics, this occurs when a high-energy photon interacts with a nucleus".
But that doesn't sound like the reverse of annihilating an electron and a positron to produce photons.
Has ever been observed in the laboratory the creation of a "pair" only from photons?
If no, why not? If yes any source to the experiment would be appreciated.
Thanks in advance.
I work with gamma ray astronomers and they see it all the time, in fact it creates an annoying background when trying to observe very high energy gamma rays from space. Basically a cosmic ray, a proton or atomic nucleus moving near the speed of light through space strikes the upper atmosphere. It his the nucleus of one one of the atoms in our atmosphere and leads to pair production of an electron and positron (and perhaps other particles as well) which then in turn strike other nuclei creating a shower of electrons and positrons. Even more cool is that these particle showers created by cosmic rays they think seed clouds in thunderstorms with strong enough electrical fields to trigger lightning. So basically:
particle + nucleus --> electron + positron + nucleus
You need the nucleus to conserve energy and momentum, although only it's motion is altered in this reaction usually (ie. it's momentum and kenetic energy).
Thanks in advance.
This is so well-known and verified that they are being used as positron sources for accelerators. The ILC design used this concept, for example.
Here's an example of the same pair production principle being used to produced polarized positrons:
http://www.slac.stanford.edu/exp/e166/
Zz.
So WAIT.
Fermions are made up of bosons? Why didn't anyone say so?
LostConjugate said:
So WAIT.
Sir you must be joking!
Your saying that you can make electrons out of photons and you can make photons out of electrons?
Huh?
Pair production is electron-positron pairs out of photons, with some momentum transfer! That's why they passed gamma photon through high-Z crystals to get e-p pairs! No one said anything about fermions being made out of bosons!
Zz.
ZapperZ said:
Huh?
Zz.
The reverse of this is annihilating a photon to produce electrons and positrons.
Once again mention of fermions (electrons / positrons) being created from bosons (photons).
Now your response to these statements was:
It is so well-known and verified that electrons and positrons are created from photons? This is new to me.
Could you show where, for example, in that experiment that I cited that they "annihilate" a photon?
Once again mention of fermions being created from bosons.
Yes, but created using something does NOT mean that fermions are MADE of it! There are EXTRA INGREDIENTS required beyond JUST photons (momentum transfer). And how many bosons can you add and subtract to give you a net spin of 1/2?
Zz.
I just made that up to keep in reference with the "opposite" of. I don't really know what they do.
Zz.
What about this quote: "by converting the positrons back to photons"
What in the world does that mean?
I understand that positrons / electrons are permutations in an electron field and photons are obviously permutations in the electromagnetic field. Two different things entirely.
I also understand that an electron and a proton can become a neutron in the construction of a neutron star, however both those particles are bosons.
So you made something up?
I converted $4 today into a burrito. You're saying that my burrito is made up of $4 bills?
Zz.
Thanks in advance.
Zapper your the one that replied to this post and stated that it has been verified. This post is speaking of annihilation of photon, creating electrons and positrons from photons, and the creation of a "pair" ONLY from photons.
I have never heard of such a thing, so I am confused.
I have no idea what you read in that post that caused you to conclude that fermions are made of bosons.
The "reverse" means that it must be photon-photon annihilation? How about reverse as in "run the movie backwards"?
Zz.
Zz.
I read this
meaning that an electron[fermion] and a positron could be created from photons[boson]
LostConjugate said:
I read this
... and other stuff, such as a momentum transfer.
But is an electron made up of photons? Nope! Nothing in the conversion process implies that one is made up of the other.
Zz.
Zz.
Ok now we are on the right path.
What do you mean by momentum transfer, certainly electrons are not made up of photons and momentum. What other stuff?
No, he means that electrons can be created by momentum transfer. For example, colliding two protons together at high energies results in the creation of many particles, including electrons, positrons, photons, ETC.
Where to they come from?
I think we are messing up something here.
\gamma \rightarrow e^- + e^+ is mass creation from energy: E=m_0 c^2 + p^2c^2. If the photons have less energy than twice the rest mass of electrons this creation process will not occur except maybe as vacuum fluctuations.
The energy of the collisions!
That doesn't conserve energy-momentum.
Did you perhaps mean
\gamma + \gamma \leftrightarrow e^- + e^+
It does in pair production thanks to the nucleus the photon interacts with.
Hopefully someone can help me understand this http://www.hep.ucl.ac.uk/~opal/gammagamma/gg-tutorial.html
Is it saying that due to the uncertainty principle a photon may at anytime fluctuate into a fermion/anti-fermion pair into which another high energy photon can interact with and cause pair production?
This is why I kept emphasizing the phrase with momentum transfer. If you look at the article that I cited, the high energy gamma have to pass through a crystal. This is because it needs to interact with something "heavy", such as the nucleus, for there to be a momentum transfer to conserve momentum. The gamma doesn't spontaneously produce e-p pair in vacuum!
Zz.
The photon is the quanta of the energy transferred in a perturbation of the electromagnetic field.
The momentum of a photon is simply a measurement of the rate of perturbation.
How are you taking these two concepts and creating an electron and a positron which have rest mass.
I think pair production is a well documented and explained event but I think people here are straying from the original question where reference was made to the electron positron pair being created not as an event involving a single photon but as an event involving photon(s) as a reversible process of annihilation.(as exemplified by strangereps equation post 21)
Ok I will start a new thread, this pair production thing is new to me.
The key here is that all energy has mass. When the photon was created, an amount of mass was removed from whatever created it and will be transferred to whatever the photon is absorbed by. When we talk about mass we *usually* talk about rest mass. Since a photon cannot be at rest it cannot have rest mass and is considered massless. However, it still is affected by and produces gravity just like things that do have mass. It has momentum and energy though, and these things are conserved in any particle created event.
This is effectively no different really than smashing to electrons together and getting a shower of particles. The total mass of the created particles can be MORE than the mass of the 2 electrons! So they certainly weren't created from JUST the mass, but from the energy!
So where did I go wrong when I said that fermions were made from bosons..?
Because they are not. Just like bosons are not made of fermions. They all have different fundamental properties such as charge, mass, etc. If two electrons collide at 5 ev, they simply bounce off each other. If they collided at 14 TeV, entire nucleons and heavier particles are produced! So are electrons made of protons? No!
Also, consider the fact that accelerating a charge produces EM waves, aka photons. Does this mean that the electron is disappearing and turning into photons? No!
  • · Replies 19 ·
