Are Time-Travel and Logical Paradoxes Connected?
  • Context: Undergrad
  • Thread starter Thread starter nomadreid
    paradox
This discussion explores the connections between the Liar Paradox and the Grandmother Paradox, focusing on their shared themes of self-reference. It highlights the Diagonal Lemma and fixed-point theorems as potential techniques for resolving these paradoxes. The conversation also distinguishes between veridical and falsidical paradoxes, emphasizing that the Grandmother Paradox is veridical, while the Liar Paradox is often considered a falsidical contradiction. The discussion references Kip Thorne's works, particularly "Black Holes and Time Warps" and "Wormholes and Time Machines," as well as the implications of Kripke frames in understanding these paradoxes.
  • Understanding of the Liar Paradox and its implications in logic.
  • Familiarity with the Grandmother Paradox in time travel narratives.
  • Knowledge of the Diagonal Lemma and fixed-point theorems.
  • Basic concepts of veridical and falsidical paradoxes.
  • Research the Diagonal Lemma and its applications in formal logic.
  • Explore Kip Thorne's "Wormholes and Time Machines" for insights on time travel paradoxes.
  • Investigate Kripke frames and their relevance to paradoxical reasoning.
  • Study the differences between veridical and falsidical paradoxes in depth.
Philosophers, logicians, and physicists interested in the intersections of logic and time travel, as well as anyone exploring the implications of paradoxes in theoretical frameworks.
nomadreid
Two paradoxes from different domains generate huge number of would-be solutions, and I am not starting this thread in order to promote one solution over the other or to proclaim that I have a new solution. I just wonder whether the techniques used for certain would-be solutions of one could be used for certain would-be solutions of the other. I don't have it worked out yet, but given that it seems a natural idea, I would be surprised if someone had not pursued this line --either successfully or otherwise.
So, here's what I have so far. The two paradoxes concerned are the Liar Paradox and the Grandmother Paradox (from time-travel fantasies) which at least superficially seem to have something in common, both referring to a type of self-reference ; whereby one refers to the code of oneself, and the other refers to a previous stage of oneself.
The techniques I am eyeing are the Diagonal Lemma (Roughly: Given a one-place first-order formula Φ(.) and a means of coding first-order sentences ".", then there is a sentence A such that Φ("A") is true iff A is true.) and the technique from umteen science-fiction movies as well as the more serious suggestion from Kip Thorne in his popular "Black Holes and Time Warps" book, not to mention the "Prisoner of Azkaban" or even ancient Greek ironic self-fulfilling prophecies: that nothing the time-traveller does in the past alters the eventual result. Both of these are essentially fixed-point theorems. However, the devil is in the detail: how best to work this out. Also, since the Grandmother paradox involves stages, I am not sure whether or not another technique which is sometimes evoked in discussions about truth, that of Kripke frames, should be factored in somehow.
Any indications are welcome, even if just to tell me I am being silly.
It's helpful to distinguish between veridical and falsidical paradoxes. The former are conclusions that are surprising and anti-intuitive, but not logical contradictions. The latter are logical contradictions.
The grandmother paradox, like in Azkaban or in Heinlein's 'All you zombies', is veridical. It doesn't seem to make sense, yet it does. The 'rule' that it seems to contradict is something like 'every sequence of events must have a cause outside the sequence'. But that is just a natural expectation based on our observation of the everyday, non-time-travelling world. It is not a rule of logic. Lay people often describe quantum mechanics as paradoxical. What they mean is that it contradicts their intuitions, not that it generates logical contradictions. The 'paradoxes' of QM are veridical.
The liar paradox is, depending on how presented, either meaningless or a falsidical contradiction. Most presentations of it are in natural language, and are meaningless. They defy attempts to formalise them. A successful formalisation of it is Russell's Paradox, formulated in the context of naïve set theory. The paradox is falsidical, meaning it generates a contradiction, and that contradiction tells us that naïve set theory is inconsistent, which is why it was replaced by Zermelo-Frankel and its successors. Other formalisations are possible using second-order and higher-order logic. Those formalisations lead to formal contradictions, which demonstrate that the particular version of logic being used is inconsistent.
Quine has a third sort of paradox, called an antinomy. Kant also played around with antinomies. According to wiki, there's a fourth type of thing that is sometimes called paradox, that has been discussed since Quine. The wiki article covering this is quite good.
Thank you, Andrewkirk, for your extensive response about paradoxes. However, it appears that I did not express myself very well, because your answer misses the point of my question. To be clearer, I am not interested in the paradoxes per se (er, well, I am of course interested in them, but not in this thread), but rather in two (possibly three) results that, while they come up in the discussion of paradoxes, are themselves not paradoxes, and appear to be equiconsistent with a standard number theory. That is, the Diagonal Theorem is not a paradox. The concept of a fixed point in recursive functions is also not paradoxical, even though Kip Thorne's solutions (to the matricide paradox) to which he referred (and briefly explained) on pages 511-515 of "Wormholes and Time Machines: Einstein's Outrageous Legacy" are curious and not simple, and I guess you could call them paradoxical (veridical) if you wish to call all counter-intuitive concepts paradoxical (thereby placing much of modern physics in this category). But that is a side point, and I am not concerned about terminology. Rather, I wish to figure out how to use the diagonal theorem or another fixed-point theorem and/or possibly Kripke frames to formalize Thorne's solution.
Ah, I did not search correctly the first time. As I surmised, I am not the first to think of doing this, and a good discussion is to be found in the following :
https://plato.stanford.edu/entries/time-travel-phys/
But I am not sure that this is the last word.
I don't see right off the bat any particular connection between time travel paradoxes and mathematical/logical paradoxes such as the Liar Paradox.
There are two. The first is that the matricide paradox (Child C goes back in time to kill her mother M before M conceives C) and the Liar paradox both involve apparent self-reference. The second is that one "solution" that would allow limited time travel would be that there would be a causal line which would be a fixed point for the transformation effected by the time travel ( C goes back in time but can't find M, so M conceives C after all: for a more detailed resolution with classical laws, see p. 512 of Kip Thorne's book cited above; for a resolution using quantum laws, see p. 515; for more fanciful solutions, see Dr. Who or Star Trek: First Contact), whereas the Diagonal Lemma (the kernel of both Tarski's Undefinability Theorem and Gödel's First Incompleteness Theorem) uses the concept of fixed point, inspired by the Liar Paradox and Richard's Paradox.
  • · Replies 98 ·
  • · Replies 276 ·
27K
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 20 ·
