High School Parallex Method: Struggling in 11th Class?
  • Thread starter Thread starter rtd
    Class Method
The discussion centers on the challenges faced by a student in understanding the parallax method in astronomy, particularly in the context of measuring distances to stars. The parallax method involves observing an object from two different positions to determine its distance based on the apparent shift in position against a distant background. Key points include the concept that faraway objects, like stars, appear to move less compared to closer objects, which shift more noticeably. The mathematical relationship involving the parallax angle and the radius of Earth's orbit is also discussed, emphasizing the need to correctly interpret the angles and distances involved. Overall, the conversation highlights the complexities of grasping this astronomical measurement technique.
rtd
iam in class 11th iam suffering from a great difficulty to understand parallex method , inspite of book's example
Explain what you think the parallax (not "parallex") method is and what it does. That is, tell us how you see it and be more explicit about what you aren't following in the explanation in your book.
In the parallax method you look at something(prabably a star) from different positions.
The trick is that an approximately infinitely far away object does not seem to move anywhere.
Even if you change your position.
For example you don't see the sun move in response to your movement.
It stays where it is in the sky, no matter where you are or how you move.
(assuming you don't move somewhere entirely different on the planet)
The thing you are looking at however does move if you change your position.
Just take your finger somewhere in front of your face.
Now move your head without moving the finger.
You will see that the finger seems to change its position relative to the background.
By examining how much its position changes you can determine the distance you are away from it.
http://lcogt.net/files/styles/fourcol-image/public/spacebook/Parallax%20schematic.png
In astronomy the "moving your head" is done by looking at the object from two opposite points on the Earth's orbit.
You might be able to see that the parallax angle does not only appear where it is drawn in but it is also half the difference in apparent position in the object.
So by measuring the angle and because we know the diameter of the Earth's orbit we can determine the distance from the star.
Likes rtd
will you please tell me a solved example ?
Well i have never solved one of these ...
But i am going to give it a try.
## tan(\Phi)=\frac {r}{d} ##
would make sense to me
(it might be wrong)
Phi is the parallax angle drawn in in the picture
r is the radius of the Earth's orbit
d is the distance to the star
solve it and you're done
thank u so much
Remember it might be wrong ...
Especially since the Earth's orbit is elliptical.(that makes the "radius" thing an approximation )
And you'll have to be careful to check whether your parallax angle is the one drawn in or the difference in position of the star.(that is just twice the angle that has been drawn in) Then you use twice the radius or just the diameter of the Earth's orbit
okkk
ok
The equation seems to be right...
You see the parallax angle is always half the angle between the position of the stars.(that would be the angles drawn in in this one)
so don't worry about that thing with the angle.
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 23 ·
