Parallel and Series Circuit
This means that the parallel circuit will create more light than the series circuit. In summary, a parallel circuit with two 150-Watt light bulbs will have a total resistance of 48.077 Ohms and a current of 0.25 A, resulting in a power output of 3.005 Watts. In comparison, a series circuit with the same light bulbs will have a total resistance of 192 Ohms and a current of 0.625 A, resulting in a power output of 0.75 Watts. Therefore, the parallel circuit will produce more light than the series circuit.
lampshader
39
If you were to make a circuit with two 150-Watt light bulbs in parallel -- how much current would flow through each bulb? Compare that to the amount of current which would flow through the bulbs if they were connected in series. Which way would create more light?
1/R (base eq) = 1 / R (base1) + 1 / R (base2) + 1 / R(Base N) ...
I = E (base eq) / R (base eq)
P (base w) = I^2*R
We can find the total resistance by:
1/R (base eq) = 1 / R (base1) + 1 / R (base2) = 1/96 Ohms + 1/96 Ohms
= 1/48 Ohms = 0.2080 Ohms^-1
= R (base eq) = 1 / 0.2080 Ohms^-1 = 4.8077 Ohms.
We can now find the current by using:
E (base eq) = 12V
R (base eq) = 4.8077 Ohms;
I = E (base eq) / R (base eq) = 12V / 4.8077 Ohms. = 2.496 =~ 2.5 A
P (base w) = I^2*R = (2.5 A)^2 * (4.8077 Ohms) = 30.0481 W
Therefore, 30.0481 Watt’s are flowing through each bulb during a live parallel circuit.
To find the current of two 150 Watt light bulbs in a series we can use:
R (base eq) = 96 Ohms + 96 Ohms = 192 Ohms.
and:
I = E (base eq) / R (base eq) = 12V / 192 Ohms = 0.625 A
So, P (base w) = I^2*R = (0.625 A)^2 * 192 Ohms = 0.75 W.
My Conclusion, therefore, is the parallel circuit with two light bulbs has more current than that of the series circuit.
Just wondering if I have done this problem correctly..
You missed a 0
here too.
but now you end up with the right answer for the series case.
BTW Nothing in the problem says what voltage is the power source used.
IF they are 110V bulbs I'd connect the parallel circuit to 110V and the series
one to 220V and you'd get 300W total in each case.
= 1/48 Ohms = 0.02080 Ohms^-1
= R (base eq) = 1 / 0.02080 Ohms^-1 = 48.077 Ohms.
E (base eq) = 12V
R (base eq) = 48.077 Ohms;
I = E (base eq) / R (base eq) = 12V / 48.077 Ohms. = 0.2496 =~ 0.25 A
P (base w) = I^2*R = (0.25 A)^2 * (48.077 Ohms) = 3.00481 =~ 3.005 W
Therefore, 3.005 Watt’s are flowing through each bulb during a live parallel circuit.
and:
1. What is the difference between a parallel and series circuit?
A parallel circuit is a type of electrical circuit where the components are connected in such a way that the current has multiple paths to flow through. In contrast, a series circuit is a type of electrical circuit where the components are connected in a single path, so the current has to flow through each component in order.
2. Which type of circuit is more commonly used in household wiring?
Parallel circuits are more commonly used in household wiring. This is because if one component in a series circuit fails, the entire circuit will fail, while in a parallel circuit, the other components will continue to function. Additionally, parallel circuits allow for more flexibility in terms of adding or removing components without disrupting the entire circuit.
3. How do the voltage and current behave in a parallel circuit?
In a parallel circuit, the voltage remains the same across each component, while the current is divided among the different branches of the circuit. This means that the total current entering the circuit is equal to the sum of the currents in each branch.
4. What is the benefit of using a series circuit?
One benefit of using a series circuit is that the total resistance of the circuit is equal to the sum of the individual resistances. This makes it easier to calculate the overall resistance and design the circuit accordingly. Series circuits are also commonly used in simple electronic devices.
5. Can a circuit be both parallel and series?
Yes, circuits can have both parallel and series components. In this case, the circuit is called a combination circuit. For example, a series circuit can have multiple branches of parallel components, or a parallel circuit can have series components connected in each branch. These combinations are commonly used in electronic devices to achieve specific functions.
