Parameterization, Folium of Descartes, etc.
  • Thread starter Thread starter dr721
The discussion focuses on two mathematical problems involving surfaces and curves defined by specific equations. The first problem examines the surface defined by z = f(x, y) = xy and requires demonstrating that lines with direction vectors u = [1, 0, b] and v = [0, 1, a] through point P = [a, b, ab] lie entirely on the surface. The second problem involves the curve x³ + y³ = 3axy, analyzing its behavior as t approaches -1 and verifying its symmetry through parametrization with x = 3at / (1 + t³) and y = 3at² / (1 + t³).
  • Understanding of multivariable calculus, specifically surfaces and curves.
  • Familiarity with vector direction and parametrization techniques.
  • Knowledge of limits and asymptotic behavior in calculus.
  • Ability to analyze symmetry in mathematical equations.
  • Explore the concept of surface parameterization in multivariable calculus.
  • Study the properties of asymptotic behavior in limits, particularly in relation to curves.
  • Investigate symmetry in mathematical functions and how to prove it using parametrization.
  • Learn about vector calculus and its applications in analyzing direction vectors on surfaces.
Students studying multivariable calculus, mathematicians interested in surface and curve analysis, and educators seeking to enhance their understanding of parametrization and symmetry in mathematical contexts.
dr721
Consider the surface z = f\left(x y\right) = xy. Given a point P = \left[a, b, ab\right] on this surface, show that the lines with direction vectors u = \left[1, 0, b\right] and v = \left[0, 1, a\right] through P are entirely contained in the surface.
2. The attempt at a solution
To be honest, I'm not really sure what I'm supposed to do here or how to go about doing it, if someone could explain it and/or give me a starting point, that'd be very helpful.
Consider the curve given by x3 + y3 = 3axy.
What happens as t\rightarrow-1? Consider the limit as t\rightarrow-1 of x(t) + y(t). What do you conclude?
The curve has obvious symmetry. Verify this using your parametrization.
The parametrized equations are:
x = 3at / 1 + t3
y = 3at2 / 1 + t3
For the limit, after adding and simplifying the equations, it equals -a. I believe the equation is asymptotic at t = -1, but I guess I'm not quite sure what I'm supposed to conclude or what -a means.
For the symmetry part, it is symmetric about y = x, so that for every point (x, y) there is a point (y, x). How do I show this with the parametric equations?
Sorry for the poor formatting. I don't know how to format column vectors or fractions.
