Parametrizing a Circle: Solving |z-z_o| = r for z(t)
  • Thread starter Thread starter squaremeplz
    Circle
To parametrize the circle defined by |z - 2 + i| = 3, the correct center is identified as 2 - i. The proposed solution is z(t) = 2 + i + 3e^(it), but there is uncertainty regarding the center's position. The adjustment to z - (2 - i) clarifies the center's location. This leads to the conclusion that the parametrization should be adjusted accordingly for accuracy. The discussion emphasizes the importance of correctly identifying the center in circle parametrization.
squaremeplz
trying to parametrize |z - 2 + i | = 3
|z - z_o| = r
im not sure if 2 + i is correct, or 2 - i.
z - 2 + i = z - (2 - i), so the center is at 2 - i.
With that change, I think you have what you need.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
