How can I parametrize a paraboloid using two or one parameter?
  • Thread starter Thread starter goleafsgo113
    Paraboloid
To parametrize the paraboloid defined by z = x^2 + y^2, two common methods are discussed. The first uses two parameters, u and v, where x = u, y = v, and z = u^2 + v^2, allowing for representation of any point on the surface. An example provided shows how to find a specific point on the paraboloid using this method. Alternatively, a single parameter t can be used, with the equations x = t, y = t, and z = 2t^2, yielding a different set of points on the same surface. Various parametrization methods exist, and the choice depends on the specific application.
goleafsgo113
how do I parametrize the paraboloid z = x^2 + y^2 ? thx
x= r*cos(theta)
y=r*sin(theta)
z=z
x^2 + y^2 = r^2
z = r^2
0 <= theta <= 2*pi
0 <= r <= 1
so your new function is now f(r,theta)
To parametrize a paraboloid, we need to express the coordinates of the points on the surface in terms of two parameters, usually denoted as u and v. In this case, we can use the parameters as follows:
x = u
y = v
z = u^2 + v^2
This parametrization allows us to represent any point on the paraboloid by plugging in different values for u and v. For example, if we want to find the point (1,2,5) on the paraboloid, we can set u = 1 and v = 2, which gives us the parametric equation:
x = 1
y = 2
z = 1^2 + 2^2 = 5
Alternatively, we can also use a single parameter, such as t, to parametrize the paraboloid. In this case, the equations would be:
x = t
y = t
z = t^2 + t^2 = 2t^2
This parametrization would give us a different set of points on the paraboloid, but they would still lie on the same surface. It is important to note that there are many possible ways to parametrize a paraboloid, and the choice of parameters may vary depending on the situation.
Hope this helps!
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 30 ·
