Particle Decay: Understanding Energies and Four-Momentum | Physics Homework
The discussion centers on particle decay in physics, specifically the decay of a particle of rest mass M into two photons. The user seeks to understand the energies of the photons emitted in both the x-direction and y-direction relative to the original particle's motion. Key equations provided include E1=(M^2+m1^2-m2^2)/2M for photon energies. The user concludes that a massive particle cannot decay into a single photon due to conservation of four-momentum, affirming that decay requires at least two photons regardless of the particle's speed.
  • Understanding of particle physics concepts, particularly particle decay.
  • Familiarity with the concept of four-momentum in relativistic physics.
  • Knowledge of relativistic velocity addition.
  • Basic equations related to energy conservation in particle decay.
  • Study the principles of four-momentum conservation in particle physics.
  • Learn about relativistic energy-momentum relations for particles and photons.
  • Explore the implications of particle decay in different reference frames.
  • Investigate the role of conservation laws in particle interactions.
Students of particle physics, particularly freshmen seeking to understand particle decay processes and the conservation laws governing them.
Gargars
Hello everybody, I'm assigned to do particle physics home, which I don't really understant because I'm a freshman and I have choosen it as a free subject. Obviously, that was a mistake. I have been reading a book, but I'm not sure if I understand everything.
A particle of rest mass M, traveling at speed v in the x-direction, decays into two photons, moving in the positive and negative x-direction relative to the original particle. What are their energies? What are the photon energies and directions if the photons are emitted in the positive and negative y-direction relative to the original particle (i.e., perpendicular to the direction of motion, in the particles rest frame).
I previously solved an equation for particle decay products energies when parent particle is ant rest. These are E1=(M^2+m1^2-m2^2)/2M, and analogicaly for E2, just -m1 squered and +m2 squered.
I'm considering photon which is moving in the positive x-direction to have less energy than the other one. Maybe I should use relatyvistic velocity addition to find these energies?
There is another problem related to the previous one.
If a massive particle decays into photons, explain using 4-momenta why it cannot decay into a single photon, but must decay into two or more. Does your explanation still hold if the particle is moving at high speed when it decays?
The four-momentum:
As far as I understand no particle can decay into another particle without nothing else. But that's not an explanation.
I get it now. Thread closed.
