Particle motion in a magnetic field
etotheipi
A particle of mass ##m##, charge ##q## and position ##\mathbf{r}(t)## moves in a magnetic field ##\mathbf{B}## pointing horizontally, and a uniform gravitational field ##\mathbf{g}## pointing vertically downward.
Derive that the particle undergoes helical motion with constant drift ##\bot## to ##\mathbf{B}##.
N/A
The equation of motion can be integrated w.r.t. ##t## since ##\frac{d}{dt} (\mathbf{r} \times \mathbf{B}) = \dot{\mathbf{r}} \times \mathbf{B} + \mathbf{0}## $$\int (q\dot{\mathbf{r}} \times \mathbf{B} + m\mathbf{g}) dt = \int m\ddot{\mathbf{r}}(t) dt$$ $$\frac{q}{m} \mathbf{r} \times \mathbf{B} + t\mathbf{g} + \mathbf{c} = \dot{\mathbf{r}}$$ I thought it might help to put a basis to it, so I let ##\mathbf{B} = B\mathbf{\hat{x}}## and ##\mathbf{g} = -g\mathbf{\hat{y}}##, so that $$\dot{\mathbf{r}} = \frac{qB}{m} \mathbf{r} \times \mathbf{\hat{x}} -gt \mathbf{\hat{y}} + \mathbf{c}$$The ##\frac{qB}{m} \mathbf{r} \times \mathbf{\hat{x}}## is a component of the velocity perpendicular to the ##\mathbf{x}## axis which I assume contributes to the 'circular' part of the motion. It's not obvious to me what the ##\mathbf{c} - gt\mathbf{\hat{y}}## component of velocity will cause. I don't think I can integrate this equation again either.
I wondered whether anyone could point me in the right direction (vector pun not intended)? Thanks!
Thanks for the reply! It's easier to visualise without the constant term, so yes let's say we boost into another frame with ##\dot{\mathbf{r}}' = \dot{\mathbf{r}} - \mathbf{c}## so that we are left with ##\dot{\mathbf{r}'} = \frac{qB}{m} \mathbf{r}' \times \mathbf{\hat{x}} -gt \mathbf{\hat{y}}##. In the absence of the weight, ##\dot{\mathbf{r}}' \cdot \ddot{\mathbf{r}}' = 0## so we would end up with helical motion.
With the weight added back in, conceptually I can see why it will be helical motion with constant vertical translation, though I wonder if there is any way of deriving the equation of the helix to show this?
sorry about previous post, i completely misread your question
Ah no worries, I thought it was useful :smile:. Didn't even notice!
  • Haha
